Implement your own LoRaWAN Server
@jmarcelino said in Implement your own LoRaWAN Server:
Yes, I’m replacing The Things Network server with this LoRa Server in my largest single install (15 LoRa gateways, 150 nodes)
Great! Which type of GW's are you using?
I find it much more configurable, especially if you want to use LoRaMAC commands - for example to reassign channels on the fly
What do you mean reassign channels on the fly?
@bmarkus said in Implement your own LoRaWAN Server:
It's a mix. I started with the RisingHF (9), now have 5 Laird RG186 and one MatchX.
I'm looking to stabilise on the Laird RG186 (best price/performance of all gateways out there as far as my application is concerned) but it's been hard to get stock.
Because I run a private network and all nodes are under my control I don't need to stick with a standard channel map so I optimise channel frequencies as necessary. I do this using targeted NewChannelReq downlinks.
It's also possible to force "difficult" nodes to operate on a single channel (instead of the 3 channel LoRaWAN default) via ChMask. This is all at the LoRAMAC/Network server layer so the nodes don't need any application code change (such as having add_channel() calls) and can operate normally on a public network.
The LoRa Server ability to load custom NetworkServer modules makes this relatively easy to implement.
Hi, @gas @jmarcelino could you provide some additional details about your implementation with a lorawan server and Lopy devices?. have you used nodes and nanogateways implemented with Lopy devices? i would appreciate a lot. thanks
@jmarcelino Hi ! What kind of lora server do u use ? https://www.loraserver.io/ ?
Thank you !
@chumelnicu
Yes that's the one -
@jmarcelino I use tthar server too .. very nice solution .
Have you ever test and https://github.com/gotthardp/lorawan-server . Seems very nice too
Thank you!
Hi
in my case :
loraserver + mainflux application
pi +ica card as lora GW 1
matchX as lora GW 2
lopy as GW mono channeland 3 lopy devices working as nodes (with GPS,Temp/humidity, light , mouvments, logging)
@gas said in Implement your own LoRaWAN Server:
Hi @gas , thanks a lot for your answer ... so it is possible to implement, just for integration test purposes, a loraserver, with a single Lopy as mono-channel GW, and a Lopy as LoRa node? (nowadays i only have two lopy, but i would like to test this scenario before thinking about buying some additional devices). thanks a lot. i relally appreciate yor help.
Yes, you can use the lorawan nano gateway example
https://github.com/pycom/pycom-libraries/tree/master/examples/lorawan-nano-gateway
but connect to your private LoRa Server instead of TTN
Just change the
SERVERdefined in config.py to match your private server -
Thanks @jmarcelino ... actually i've successfully implemented TTN based lorawan with a lopy acting as nanogateway and a lopy acting as a node. but i would like to ensure that there are no additional hw requirements (but the a pc running ubuntu) o move to Lora Server. in case some of you experts could share a brief tutorial describing the minimal tricks to successfully implement this alternative to TTN, it could be great!. thanks again for your support!
@gas hello Gas,
loraserver and mainflux is installed in your Pi or in your computer
did you use postgres?thank you in adavnce
Maamar -
