    The Pin Outs
    15 Posts 6 Posters 6.3k Views 6 Watching
      RicoLA
      Hi there,
      yes same for me ... it's not clear where are located the 'default' I2C pins :-)
      are P9/P10 (GPIO 12/GPIO13) ok when using example code in quickref doc i2c = I2C(0, I2C.MASTER, baudrate=100000) ?
      thanks
      Rico
      • X Offline
        Xykon administrators
        You can refer to this until the official documentation is updated :
        alt text
        Christian Ehlers
        M R 2 Replies Last reply Reply Quote 0
          michal @pighixxx
          @pighixxx
          That's OK. What I am complaining about is the fact, that I can easily see the pin usage in Wipy 1.0 layout:
          https://raw.githubusercontent.com/wipy/wipy/master/docs/PinOUT.png
          but I struggle to find the same level of information for Wipy 2.0. For example I wasn't able to identify the fact that UART_1 pins are P3 and P4. It was probably caused by the lack of my knowledge (I don't understand properly some of those pin descriptions) but I might not be the only one who will need more intuitive pin out.
          Michal
            michal @Xykon
            @Xykon
            Thanks a lot, your schema is much more intuitive for me. Will you make a Wipy version too?
              RicoLA @Xykon
              @Xykon yes that's to what I was referring to :-)
              yet given this new "official" Lopy pinout pdf file, there are plenty of other possibilities with theses multipurpose GPIOs .
              the problem is with alternate functions attached to them, we need to know precisely who is who . e.g. for I2C we need to know either the I2C bus number (like in : i2c = I2C(0, I2C.MASTER, baudrate=100000) ) , or the the SCL pin and SDA pin numbers that we can NOT mix up as we want. (as in i2c = I2C(scl=Pin(5), sda=Pin(4), freq=100000) )
              cheers
                pighixxx
                Last pinouts and quick reference cards:
                LoPy
                alt text
                Quick Reference
                alt text
                WiPy
                alt text
                Quick Reference
                alt text
                R M 2 Replies Last reply Reply Quote 2
                  RicoLA @pighixxx
                  @pighixxx WONDERFUL !! thanks a lot :-)
                    pighixxx @RicoLA
                    @RicoLA said in The Pin Outs:
                    I sent PDF's to Pycom. Look forward to publish them
                      michal @pighixxx
                      @pighixxx
                      Thanks a lot for changes!
                      Michal
                        Bettina administrators
                        Updated 08.11.16
                        LoPy Pin Out
                        https://www.pycom.io/wp-content/uploads/2016/11/lopy_pinout.pdf
                        WiPy Pin Out
                        https://www.pycom.io/wp-content/uploads/2016/11/wipy_pinout.pdf
                        Expansion Board Pin Out
                        https://www.pycom.io/wp-content/uploads/2016/11/expansion_v02_pinout.pdf
                        Bettina
                        Pylot at Pycom
                          babjerke
                          Nice to see the pinouts for the LoPy module but the link for the Expansion Board is not working!
                            Bettina administrators @babjerke
                            @babjerke hi there, I updated the expansion board again yesterday. Should be working now. Let me know if you struggle or I have missed an area. ;-)
                            Bettina
                            Pylot at Pycom
