    Mising documentation for uos.stat()
    16 Posts 5 Posters 4.2k Views 5 Watching
    • bmarkusB Offline
      bmarkus @sakis
      @sakis said in Mising documentation for uos.stat():
      @bmarkus
      About your rest points, I agree that a docs link should be added to pycom.io. And we are trying hard to improve both our documentation and our firmware.
      After 21 days Pycom doc looks the same at https://docs.pycom.io/pycom_esp32/library/uos.html
      saying only
      Get the status of a file or directory.
      So, question is still valid, what is the return value? It is a question related to your own commercial product, not related to chip vendor, LoRa Alliance, CIA, KGB, ...
      What is about making a product usable for its customers and provide documentation? How do you expect to use it (expecting we get some free RAM and stable functions instead of changing it every week, introducing new bugs, etc.)?
        sakis
        @bmarkus @livius
        Fair points. We are planning to release an update to our documentation this week and documenting the return values of os.stat will be part of it.
          robert-hh
          The returned tuple has the structure defined for Python3 os.stat(). Only not all values are populated. useful values are:
          ST_MODE
          ST_SIZE
          ST_ATIME which is teh same as ST_MTIME and ST_CTIME
          The other values are set to zero, since they do not apply in the given environment, but the full structure is returned for compatibility.
          No reason to complain. If there is not special documentation, assume Python compliance as a plausible choice.
            livius @robert-hh
            @robert-hh said in Mising documentation for uos.stat():
            it work for you in that way?
            like os.stat().ST_SIZE?
            i must check this at home - i tested this previously and i remember that it does not know ST_SIZE
              robert-hh
              No, not that way. os.stat() return a 10-tuple, and the 7th, os_stat()[6], is the size. The symbolic indices are NOT set.
                livius @robert-hh
                and that is the point
                  robert-hh
                  This is a Micro, fighting for every byte for memory. Too many features make it unusable.
                    livius @robert-hh
                    you have right but without doc you do not know what are that numbers in touple
                    you can guess but not for sure
                    but as @sakis say it will change in this week
                    • sorenS Offline
                      soren
                      Couldn't agree more.
                        robert-hh @soren
                        @soren @bmarkus I see this as a semi-commercial product.
                        The documentation is not complete and sometimes wrong, since it was taken from the micropython.org port. Then some extension were made, but no-one seemed to have checked, whether everything fits. There seem to be a person now in Pycom.io dedicated to documentation, but maybe I'm wrong.
                        But if you like, you can contribute to the documentation. Sometimes, PRs to the documentation are noticed. In case of uos.stat(), the documentation is present.
                        • bmarkusB Offline
                          bmarkus @robert-hh
                          It is a commercial product range offered in form of development and OEM moduls.
