    MQTT with 2 subscribes
    mqtt
    16 Posts 3 Posters 3.6k Views 3 Watching
      livius @luc hanneuse
      @luc-hanneuse
      what is the error message?
      and to convert from text to number simply do
      v2=float(v)
      or if you need only integer part
      v2=int(float(v))
        luc hanneuse @livius
        @livius
        For the conversion, It doesn't work :
        v2=float(v)
        I've got an error
        can't convert bytes to float
        v2=int(v)
        I've got an error
        ValueError: invalid syntax for integer with base 10
        For the previous code, the error is
        NameError: local variable referenced before assignment
          chumelnicu @luc hanneuse
          @luc-hanneuse Try to pack that two data (temperatures ) in to json format and publising after to MQTT broker
            luc hanneuse @chumelnicu
            @chumelnicu
            It comes from different devices publishing each one their temperatures.
              @luc-hanneuse said in MQTT with 2 subscribes:
              You got this error because you do this
              s.send(bytes([b,c]))
              but in the code you have if variants and one of two "b" or "c" is unassigned
              because you got 2 events - look how your code work by changing it to:
              def mytopic(topic, msg):
                  print("---start---")
                  print (topic, ':', msg)
              is your output now like this?
              "---start---"
              b'pi/sensor21/temperature' : b'21.00'
              "---start---"
              b'pi/sensor31/temperature' : b'25'
              you must put b and c outside of procedure
              and inside test if both "b" and "c" have values and only then send it
              but this can also cause minssing values if you got only "b" and once again "b" and next "c"
              PS> about simple conversion i am writing about string, if it is a bytes then
              you must catch it e.g. v2=float(str(v))
              but your way should work also byte-48{0ascii} *10...
                @livius said in MQTT with 2 subscribes:
                How can I get those variable out of "def"?
                  msg_b= None
                  msg_c= None
                    global msg_b
                    global msg_c
                    luc hanneuse
                    Finally some improvements, thanks for your help.
                    I succeed to subscribe to several topics and get some results.
                    topic_sub=["pi/sensor21/temperature","pi/sensor40/temperature","pi/sensor02/temperature","pi/sensor12/in_01","pi/sensor12/out_01"]
                    topic_length=len(topic_sub)
                    val= [0,0,0,0,0] #should be a better way to create this array from topic_length
                    update = None # used if you want to send a signal without waiting the 800s cycle
                    for i in range(0, topic_length):
                        client.subscribe(topic=topic_sub[i])
                        global update
                        global topic_length
                        global topic_sub
                        global val
                        if ubinascii.hexlify(topic) == ubinascii.hexlify(topic_sub[0]):
                            val[0] = (msg[0]-48)*10+(msg[1]-48) #ascii-to-int, to be improved
                            val[0] = val[0] % 255 #sure to be a byte
                        if ubinascii.hexlify(topic) == ubinascii.hexlify(topic_sub[1]):
                            val[1] = (msg[0]-48)*10+(msg[1]-48) #ascii-to-int, to be improved
                            val[1] = val[1] % 255 #sure to be a byte
                        if ubinascii.hexlify(topic) == ubinascii.hexlify(topic_sub[2]):
                            val[2] = (msg[0]-48)*10+(msg[1]-48) #ascii-to-int, to be improved
                            val[2] = val[2] % 255 #sure to be a byte
                        if ubinascii.hexlify(topic) == ubinascii.hexlify(topic_sub[3]):
                            val[3] = (msg[0]-48) #ascii-to-int, to be improved
                            update = 1
                        if ubinascii.hexlify(topic) == ubinascii.hexlify(topic_sub[4]):
                            val[4] = (msg[0]-48) #ascii-to-int, to be improved
                            update = 1
                    client.set_callback(mytopic)
                    chrono = Timer.Chrono()
                    chrono.start()
                        client.check_msg()
                        if chrono.read()%60 < 5 and blink == 0:#just a blinking
                            pycom.rgbled(0x0064)
                            blink = 1
                            print(".")
                        if chrono.read()%60 > 5 and blink == 1:#just a blinking
                            pycom.rgbled(0x0000)
                            blink = 0
                            print("-")
                        if chrono.read() > 800:#wait 800s to avoid the sigfox message limit per day
                            pycom.rgbled(0x007f00)
                            s.send(bytes(val))
                            print("Sigfox sent\n")
                            chrono.reset()
                        if update == 1:#send immediately if update is triger
                            s.send(bytes(val))
                            chrono.reset()
                            update = 0
                    But the exact nature of the result of topic and message are unknown. Is it a string, a byte,... ?
                    Most conversions don't works. I've tried float() or int() and get errors
                    I still have errors, certainly related to that problem :
                    And I've got the following message error when
                    s.send(bytes(val))
                    #val is filled with the several message of the topics
                    The packet is correctly sent, but the program quit with the following error message OSError: [Errno 100] ENETDOWN
                    When I send the following code, I've no error
                    val = [1,2,3,4,5]
                    s.send(bytes(val))
                      unknown = None?
                      if yes than it mean no value at all.
                      And before send put print command to see what you tried to send
                      print(str(val))
                      s.send(bytes(val))
                      and if you still have problem show what was printed
                        @livius
                        The "topic" and "message" variables are created by the mqtt library.
                        And yes, those variables don't react like string, byte,... most of the variables conversion don't work. That's why I called them "unknown".
                        I've already print them, but that doesn't help to clarify the type of variable.
                          @luc-hanneuse
                          first you can try to test if it is None
                          if v==None:
                          and also you can test for type by:
                          type(v)
