Grove Sensors
 Dear All,
 Is There some way to use the grove sensors (i.e https://www.seeedstudio.com/category/Sensor-for-Grove-c-24.html) with WiPy?
 For example, RaspberryPi provides the GrovePi kit.Thanks in advance
 @robert-hh Thanks a lot...I will try soon
 good point
 @francesco-gallo In addition to the hints given by @livius some notes:
 a) you can and should run the Grive sensor at Vcc of 3.3V
 b) change the linesadc = ADC(0) adc_c = adc.channel(pin='P13')to adc = ADC(0, bits=10) adc_c = adc.channel(pin='P13', attn=adc.ATTN_11DB)" ``' to cope with the 3.3V range of the sensor and set it to 10 bit, which is assumed by the code.
 i do not tested this but you can try from machine import ADC from math import log sensor_T = 4275 #T value sensor_R = 100000 # resistance adc = ADC(0) adc_c = adc.channel(pin='P13') while True: value = adc_c(); R = 1023.0/value-1.0 R = sensor_R*R temp = 1.0/(log(R/sensor_R)/sensor_T+1/298.15)-273.15; # convert to temperature print('temp: ', str(temp))
 @francesco-gallo
 I do not have this one but it look like simple analog sensor
 use ADC for it - but remember about voltage levels 3V3 not 5V!
 Hi Livius,
 thanks a lot for your answer. In particular, I need support on Temperature sensors (http://wiki.seeed.cc/Grove-Temperature_Sensor_V1.2/), but in general my question regards all grove sensors.Thanks in advance
 @francesco-gallo
 Grove have many sensors - ask about some specific then someone can hep you
