WEEKLY UPDATE W/C 7th Nov
  • administrators
    Dear all,
    A brief update for the week as promised. Last week, Daniel and the team did an awesome job getting a load of firmware updates/improvements and app launches! Namely:
    NEW firmware 0.9.3.b2: RELEASED Friday 4/11/16
    • ADC (Analog to Digital Converter)
    • PWM (Pulse Width Modulation) Timers.
    • Multi-Threading via the _thread module.
    • UART interrupts bug fix.
    NEW Pymakr 1.0.0.b6: RELEASED Tuesday 1/11/16
    • Fixed the sync feature in combination with latest LoPy and WiPy 2.0 firmware.
    • Small layout fixes.
    • Preventing multiple errors in the update plugin.
    • Added Project configuration screen to the expert version for setting default project directory.
    • Fixed a bug where REPL threw an error when using backspace and arrows combination.
    • Added some aid in the device preferences page.
    NEW Pymate IOS: RELEASED Friday 4/11/16
    Pin-Outs LoPy, WiPy 2.0 and Expansion Boards: Released 6/11/16 (New iteration released today
    Thank you Alberto Piganti
    This Friday we will release:
    • Bluetooth coexistence with WiFi. We have received from Espressif a new file which Daniel and the team will integrate into our existing code.
    • SD card support.
    • Several fixes and stability improvements (Floating point error fix, MicroPython core update, File system errors fixes).
    Some other follow up points:
    • We will launch the Pymate Android version on 18th November.
    • Opensource: We are due to receive final GPL V3 licence on 11/11/16 and will immediately released source code on Github. I will give a comprehensive detail of the licence as soon as I receive the final points from the legal people. I do believe we will have a licence which will allow our developers to continue developing freely and unhindered in the spirit of Opensource!
    • Documentation: We are working on this issue and will get some more content released shortly.
    As an FYI, we will be organising on the 17th and 18th January 2 days of intense workshops for LoRa, Sigfox, WiFi and Bluetooth connectivity applications. More details to follow but I wanted to give you the heads up.
    Thats it for now...
    Best wishes Fred
  • Hi @jonirons,
    Sorry about not responding to this issue 16 days ago, it got forgotten between all the other posts. I just responded to your message in that topic.
  • @Ralph still having the issue described below (QStackedWidget::setCurrentWidget: widget 0x7feac359e370 not contained in stack) with 0.9.4.b1 and latest PyMakr release.
    Any help for me?
  • I'm still getting the same problem with wipy1 and with wipy2
  • From my forum post 16 days ago:
    "Confirm I'm having the same problem with Pymakr and wipy1.
    Have set up boot.py to connect to my wlan
    Can connect to board using telnet.
    Can update using FTP
    Can't connect using Pymakr
    I get a popup error dialog with the message:
    Warning:
    QStackedWidget::setCurrentWidget: widget 0x7fe1ccddc0d0 not contained in stack
    Behind the error popup is:
    Connecting to a Pycom device...
    Error while communicating with the Pycom device! (click to attempt to reconnect)
    I'm not sure what to click, but if you go to preferences -> Pycom Device -> Ok
    I get the Error while communicating message again."
  • @jonirons said in WEEKLY UPDATE W/C 7th Nov:
    The "fully featured IDE that connects automatically to your Pycom" PyMakr has yet to talk to any WiPy (1 or 2) for more than a few seconds before giving an error that can't be got rid of without using "Activity Monitor".
    Can you make a forum post with the details of this error and after what actions you are getting it? Maybe we can help you resolve it.
  • Getting up a level, it would be great to have a road map so we can see when some of the staples like rtc, watch dog feeding, timer interrupts are expected (maybe these are there and I just haven't found the doco)
  • @jonirons OK, you are right about the RTC: https://docs.pycom.io/wipy2/library/machine.RTC.html somehow it filtered into the generated docs. But the pycom module is available, since the first release of the firmware.
  • @daniel - Both
    following the links from https://docs.pycom.io/wipy2/ -> click on Library Reference -> Pycom boards specific features -> try importing pycom module
    From the spec sheet, try googling WiPy2 RTC - get result https://docs.pycom.io/wipy2/library/machine.RTC.html - no machine.RTC module. (admittedly I see it isn't linked directly from the above module)
    In addition, and as documented previously No success getting PyMakr ide connecting to any board at all for more that a few seconds, whether factory clean, configured or via USB. Although Telnet, Screen and FTP are working fine.
  • @jonirons what features that are documented in: https://docs.pycom.io/wipy2/ are not available in the software? Or do you mean documented in the spec sheet? Thanks.
  • The enormous potential comment still stands. I still want this to be great, and your development team have already done this before. I would prefer a ROADMAP.
    If you let me know that I'm happy to change my mind-set to a Kickstarter kind of deal. Otherwise I will likely take up your offer and send it back (and all the follow on)
    Like I said - rethink the communication strategy, and stop selling this as a finished product. This is not yet yet worthy of a beta software release.
    May of the documented features are not available (not buggy, just simply NOT THERE).
    We know software development is difficult and time consuming. TELL US WHERE YOU"RE AT.
  • administrators
    @jonirons nobody is conning anybody! Feel free to return the product and we will refund including postage. Email me on fred@pycom.io Thanks Fred
  • @Fred PyCom needs to immediately stop selling this as a product that is "enterprise grade" and has the following features: https://www.pycom.io/solutions/py-boards/wipy2/
    and realistically say "Our plan is to have the following features:" https://www.pycom.io/solutions/py-boards/wipy2/
    You also need to put those of us who've been conned into buying them in contact with your (as previously stated) really good developers. All the stuff I expect to already work on WiPy 2 already works on WiPy 1 - it took me about 15 minutes to port a weekends buggering about to WiPy 1 and it all just worked.
    GIVE US A ROADMAP
    The WiPy2 and the rest of the multi-channel devices have enormous potential with talented developers who can make it work. Tell us "Here's how it will play out". I will follow it, and re-engage, but at the moment you're wasting my time!
    PyCom needs to re-think its communication strategy!
  • administrators
    @jonirons fair enough :) My bad. We appreciate you guys have put a lot of trust into Pycom. Unfortunately hardware design can suffer these delays as you developers will know only too well. I will come back a little later with a more comprehensive update for the week. Thanks
  • @Fred ;) in the absence of information that's all I can do!
  • administrators
    @jonirons it's good to see you got it right from the beginning: HERE'S MY GUESS.
  • @jonirons Here's my guess:
    A bunch of really talented developers (I mean that) were told by some corporate freaks "have we got a deal for you!"
    The developers said - "It's not ready yet"
    The corporate freaks said "It's got to go now now now"
    The corporate freaks said "marketing have got the glossy brochures, we've got the cool web-site, we've got the online payment channel - g0 go go - Developers WORK HARDER"
    Something like that?
  • @bmarkus I now need some clarification - I've responded to a Pycom forum. Who is this "We" that is separate from Pycom? Can I rather follow the "We" and understand whats really happening, because Pycom seems to have NO idea of how to communicate.
    It was sold to me on the open market as an "Enterprise" grade product with no indication that its not yet ready, and in fact has a significant way to go. At best this is misleading. At worst its possibly fraudulent. I didn't buy this as a Kickstarter project where one understands that's where we're at.
    How do I get behind the glossy brochures and find out where this (very early stage) development is at? I don't want to waste time on stuff that is under development, and I don't have the tools to fix.
    I have faith that the "We" can get this right - The wipy gets WLAN connection in 1.9 s - the wipy2 gets connection to the same network in 10s.
    Please let us know where this is at, because right now I've been GROSSLY mislead.
    PyCom - get your act together, stop selling this as a finished product, and give those of us who've been misled an idea of when we should stop wasting our time on problems we can't solve.
    tru dat - It would be great to have a forward road-map of when features and documentation might be available. e.g. https://docs.pycom.io/wipy2/library/machine.RTC.html tells me I can do so:
    rtc = machine.RTC()
    rtc.init((2014, 5, 1, 4, 13, 0, 0, 0))
    print(rtc.now())
    but machine.RTC() tells me
    rtc = machine.RTC()
    AttributeError: 'module' object has no attribute 'RTC'
    Is someone working on it as we speak? or is there a list of features ahead of it?
    Cheers
    Jon
    We have roadmap. Issue is that this roadmap is not followed by PyCom and that PyCom stopped communication to its customers, changed condition advertised during KS campaign and do not meet its own commitments.
  • tru dat - It would be great to have a forward road-map of when features and documentation might be available. e.g. https://docs.pycom.io/wipy2/library/machine.RTC.html tells me I can do so:
    rtc = machine.RTC()
    print(rtc.now())
    rtc = machine.RTC()
    Cheers
    Jon
20 out of 27
