    MicroPython Unable to access REPL
    Scheduled Pinned Locked Moved Projects
    micropythonpython
    2 Posts 2 Posters 1.1k Views 2 Watching
      Giranp
      I am trying to install MIcroPython Firmware on my ESP8266-12E(http://www.kynix.com/Detail/1324534/ESP8266-12E.html) chip. I am using esptool.py to flash the firmware. I have successfully uploaded the firmware esp8266-20170612-v1.9.1.bin followed by a flash_erase. I have used following commands to flash the chip.
      *$ sudo esptool.py --port /dev/ttyUSB0 erase_flash
      esptool.py v2.0.1
      Connecting........_
      Detecting chip type... ESP8266
      Chip is ESP8266
      Uploading stub...
      Running stub...
      Stub running...
      Erasing flash (this may take a while)...
      Chip erase completed successfully in 13.0s
      Hard resetting...
      $ sudo esptool.py --port /dev/ttyUSB0 write_flash --flash_mode qio --flash_size detect 0x0 esp8266-20170612-v1.9.1.bin --verify
      esptool.py v2.0.1
      Connecting....
      Chip is ESP8266
      Uploading stub...
      Running stub...
      Stub running...
      Configuring flash size...
      Auto-detected Flash size: 4MB
      Flash params set to 0x0040
      Compressed 598432 bytes to 390604...
      Wrote 598432 bytes (390604 compressed) at 0x00000000 in 34.5 seconds (effective 138.8 kbit/s)...
      Hash of data verified.
      Leaving...
      Verifying just-written flash...
      (This option is deprecated, flash contents are now always read back after flashing.)
      Verifying 0x921a0 (598432) bytes @ 0x00000000 in flash against esp8266-20170612-v1.9.1.bin...
      -- verify OK (digest matched)
      Hard resetting...*
      As you can see verification of flash process is OK. And I can see a new wifi ssid on my wifi list.
      Now when I am trying to access REPL via picocom it is hanging on following:
      *picocom v1.7
      port is : /dev/ttyUSB0
      flowcontrol : none
      baudrate is : 115200
      parity is : none
      databits are : 8
      escape is : C-a
      local echo is : no
      noinit is : no
      noreset is : no
      nolock is : no
      send_cmd is : sz -vv
      receive_cmd is : rz -vv
      imap is :
      omap is :
      emap is : crcrlf,delbs,
      Terminal ready*
      I also tried screen, putty and minicom same behaviour on them as well. Also encountered a strange behaviour that it is working perfectly via ESPlorer.
      Is there anything that I am missing? Or any suggestion to hunt this situation?
        robert-hh @Giranp
        @giranp Good morning. First of all: You're in the wrong forum. The port for ESP8266 is supported at forum.micropython.org.
        Besides that, what you did is right. The information missing is:
        a) which kind of board are you using?
        b) did you set the access rights for /dev/ttyUSB0, or better, are you as user in the dialout group? You shoud get an error message if not.
        c) When connected, try Ctrl-C or Ctrl-B or Ctrl-D, whether this changes the behviour.
