    Deepsleep randomly ends
    deepsleepsipy
    5 Posts 3 Posters 1.3k Views 3 Watching
      bradnz
      Hi
      I have a new SiPy in a expansion board. I have tried this with two different deepsleep modules with same result.
      My code engages deepsleep for 30mins. With this new SiPy though it engages at completely random times, could be 5 mins, 10 mins or 45 mins. It never consistent. The same code on a different SiPy is be fine (i.e the very first SiPy I received several months ago). I have cut the code right back to simply having the deepsleep on in a while loop. Everything else (i.e. WLAN, Bluetooth) is disabled. Firmware is the latest release (I upgraded to ensure this wasnt the issue).
      Any ideas anyone? Any checks I can make?
      Brad
        livius @bradnz
        @bradnz said in Deepsleep randomly ends:
        what do you mean deepsleep in loop?
        after deepslip enter board woke up near the same as pressing reset button then no loop needed.
          crumble
          check the deepsleep wake up reason.
          I know only the PyTrack. On this device you have reasons like shaking, button press, ...
          Maybe a floating input pin, which wakes up your system.
            bradnz
            What Im actually finding is that its a POWER_ON_RESET - I have disabled the wake on pin so should this effect it. When the device is in Deepsleep there is a voltage on a lot of pins that I dont expect. For example, the power pin has 0.91V, the 3.3V pin has 1.9V, and a number of the GPIO pins have voltages on them too! These should all be 0V. The only connections are expansion board, to deep sleep module to SiPy. I have the latest version of the deepsleep module so I really dont know.
              bradnz
              Further to this, I have found even more weird. I simply cannot get this Pycom SiPy device with a deepsleep module attached to wake every 30mins. Its so random.
              @crumble if I needed to fix the floating pins issue, what resistor size would you suggest, and would this be pull up or pulldown? Also what commands in the SW would I need to ensure that P17/P18 doesnt wake the module from deepsleep if I do this? (Assuming of course that these are the only two pins I need to control - P10 is used to communicate with the deepsleep module, but I dont think this needs a pullup / pulldown on my board?)
              Any help would be appreciated.
              Cheers.
