    UNIX Time
    21 Posts 6 Posters 7.9k Views 6 Watching
      jmarcelino
      I traced the problem to esp32/mods/modutime.c and added a comment to the issue on github: https://github.com/pycom/pycom-micropython/issues/71#issuecomment-275624314
      Simply changing time_time() to return an int fixed it for me, but not sure why it was returning a float in the first place so maybe I'm missing something :-)
      With the patch in place it seems to be working
      >>> rtc.init((2017,1,27,9,0))
      Running utimeTest.py
      rtc.now:(2017, 1, 27, 9, 0, 9, 37484, None)  utime.time:1485507609
      rtc.now:(2017, 1, 27, 9, 0, 10, 39594, None)  utime.time:1485507610
      rtc.now:(2017, 1, 27, 9, 0, 11, 41610, None)  utime.time:1485507611
      rtc.now:(2017, 1, 27, 9, 0, 12, 43605, None)  utime.time:1485507612
      rtc.now:(2017, 1, 27, 9, 0, 13, 45611, None)  utime.time:1485507613
      rtc.now:(2017, 1, 27, 9, 0, 14, 48617, None)  utime.time:1485507614
      rtc.now:(2017, 1, 27, 9, 0, 15, 50614, None)  utime.time:1485507615
      rtc.now:(2017, 1, 27, 9, 0, 16, 52619, None)  utime.time:1485507616
        abilio @dchappel
        @dchappel, @jmarcelino, thanks for the report. You're totally right about time not working properly after initialization.
        To continue with @jmarcelino's finding, the reason why returns a float is to making it more compatible with CPython, taking advantage of the fact that floating point is supported. (reference here). It was a last minute change before the release, and must admit, not tested in the way you did, but only with the RTC in reset after boot state.
        The original line reads:
        return mp_obj_new_float(mach_rtc_get_us_since_epoch() / 1000000.0);
        The fact is that if you do some printing:
        printf("%lld %f\n", mach_rtc_get_us_since_epoch(), mach_rtc_get_us_since_epoch() / 1000000.0);
        You'll see the value changing, yet the float object returned always have the same value. Furthermore, if you replace the C code by:
        STATIC mp_obj_t time_time(void) {
            static float t = 1483229312.0;
            t = t + 1.0;
           // get date and time
           return mp_obj_new_float(t);
        You would expect the value to change, but it doesn't. But if you do initialize t to 1.0, as in: static float t = 1.0; then it changes.
        Now if t = 16777215.0, you'll see the value increment once, then get stuck at 16777216.0, which is 2 ˆ24.
        I have to investigate further.
          abilio
          I've been doing some tests, and found this to be related to the Espressif tools. I created this simple test:
          void check_this_float_passing(float f) {
              printf("this is a float: %f\n", f - 16777215.0); // the constant is there to prove that is not fault of the printf */
          void test_float(void) {
              check_this_float_passing(16777215.0);
              check_this_float_passing(16777216.0);
              check_this_float_passing(16777216.1); // buggy from now on
              check_this_float_passing(16777217.0);
              printf("this is a big float showing it works: %f\n", 16777217.0); // this works
          Expected result:
          this is a float: 0.000000
          this is a float: 1.000000
          this is a float: 1.100000
          this is a float: 2.000000
          this is a big float showing it works: 16777217.000000
          Obtained:
          As you see, there is a problem with passing floats as a parameter of a function for numbers higher than 2^24. I'm going to investigate further.
          Note: this is not related to the previous floating point bug (80000000.0 / 1000000.0 != 80).
            jmarcelino @abilio
            Thank you so much for posting your thoughts and debugging steps @abilio
            This is really excellent for us entering the world of μpython internals debugging - and do I love a good mystery to apply some detective work ;-)
            That the problem appears at 24 bits is interesting and I remember floats (when stored as 32 bit) only have 23 bits for the significant digits so maybe that explains it.
            I think printf("%lld %f\n" ...) uses doubles so that's probably why you didn't see it there.
            Just a theory at least. I'll look into it a bit more later if we're still stuck.
              abilio @jmarcelino
              @jmarcelino, actually in the line:
              I wanted to print the us value after epoch, which is internally kept as a 64 bit integer (to go beyond the 2K38 problem), hence the %lld. Then at the same line I wanted to test that it was not an issue with converting it to a float seconds value (which proved not to be the case).
                jmarcelino @abilio
                @abilio
                I meant that %f in the printf is usually a double not a float
                  abilio @jmarcelino
                  @dchappel, @jmarcelino, and everyone else that reads this. I hope you guys all accept my humble apology. @jmarcelino made me realize of a mistake I made while coming into this conclusions (and in the original software too).
                  I had forgotten that single floating point values are 32 bit (so only 23 bits represent the fraction). The results are then correct. I'll check into the reported bug and look for a way to fix it ASAP. Probably it won't be included in today's release, as I want to test it properly this time.
                    abilio
                    After thinking it through and discussing it with my fellow workers, the only posible solution is to go back to integers. The reason is that at present time mp_float_t is now a C float, that only has 23 bit to represent the mantissa. This could be changed, but needs proper testing. Perhaps in the future this will change, but until then, time.time() will return an integer.
                    • sorenS Offline
                      soren
                        Devang Sharma
                        @abilio, how can I sync/set RTC to UNIX time?
                          jmarcelino @Devang Sharma
                          @devang-sharma
                          Do you mean over NTP?
                          You can now use rtc.ntp_sync("pool.ntp.org")
                          Check the RTC docs: https://docs.pycom.io/chapter/firmwareapi/pycom/machine/RTC.html
                            Devang Sharma
                            @jmarcelino, I want to sync RTC to current time(UTC) and after that, I can use time.time() function to calculate time elapsed since Epoch and then use it as a timestamp.
                              livius @Devang Sharma
                              @devang-sharma
                              I do not know if i understand you corectly
                              but you can set timezone
                              utime.timezone([secs])
                              and then use
                              utime.localtime()
                                Devang Sharma @jmarcelino
                                @jmarcelino It works for me now! I had to enable NTP client using the command line in Windows. Before that, "rtc.synced()" was returning False. Thanks.
