    Root causes of high deep sleep current [LoPy1, WiPy2 and SiPy], all the new modules **do not have deepsleep issues**
    deepsleep
    127 Posts 48 Posters 112.5k Views 57 Watching
      jalperin
      Thank you for the fix.
      So, does one use the lopy deepsleep, the pysense go-to-sleep, or both (somehow)?
      Is there an example of using the nvram save and load?
        crasu
        The survey monkey link is dead. I have 5 affected boards. How can I obtain 1-3 deep sleep shields?
        Thank you,
        Christian
          colin.guyon
          The same for me, I would need a deep-sleep shield but I see the survey is closed...
          • F Offline
            Fred administrators @colin.guyon
            @colin.guyon Hi Colin, simply send an email to sales@pycom.io with your order number and where the shields need to be sent. Best wishes Fred
            • F Offline
              Fred administrators @crasu
              @crasu Hi Christian, Inhave just messaged Colin with same info. Please send email to sales@pycom.io with order number details / address for delivery of the shields. Also, confirm how many you need. Thanks Fred
                rolandvs @Fred
                @Fred is it possible to implement on the deep sleep board a real RTC (even by an empty place on the pcb So it can be added afterwards)? Maybe size up the PIC chip and add a 32kHz xtal and do the RTC in software...
                  @rolandvs I don't think we will do this. The deesleep shield prupose is to compensate for the current batch of modules with the issue of the high deepsleep current. The next batch of modules will be able to go to deepsleep with a consumption of 5uA, therefore you'll be able to use the RTC built-in the ESP32.
                    dbrgn
                    @daniel sounds promising. Do you already know when that next batch will be available?
                    • F Offline
                      fkoran
                      • E Offline
                        Electrozest @Fred
                        @fred, I wondered if the deep sleep issues have been resolved in the new LoPy4 modules? Will the deep-sleep shield still be needed for LoPy4 to achieve low current deep-sleep? Thank you. Best Regards, Martin
                          livius @Electrozest
                          @electrozest
                          No, deepsleep shield is not needed for Lopy4. It work "natively" in deepsleep mode.
                          • E Offline
                            Electrozest @livius
                            @livius , thank you. Are the quoted <5uA standby currents for LoPy4 with Wifi/LoRa/SigFox disabled using the 3.3V-5.5V power external input pin via the LoPy4 internal 3.3V voltage regulator? To achieve lowest standby deep sleep power consumption, will I be able to use the built in voltage regulator or will a lower loss external 3.3V regulator be required instead?
                              robd
                              Has the Lopy sleep power been resolved and how can the modules be identified from the ones which have the issue?
                              Thank you,
                                jmarcelino @robd
                                @robd
                                This has been resolved in all new the new development boards WiPy 3, FiPy, GPy and LoPy 4 as well as all the OEM modules including the L01.
                                For the existing LoPy (not the LoPy 4) the solution is still the deepsleep shield (complementary) or using the Pytrack/Pysense
                                  rvandam
                                  I have two V1.0 Lopy's. I tried to reach the link from Surveymonkey from above, but the survey is currently closed. Is there a way to order these deepsleep shields?
                                    robert-hh @rvandam
                                    @rvandam Down the road on this post you'll find the answer:
                                      rvandam @robert-hh
                                      @robert-hh Thank you for the reply. Email send :-)
                                      • K Offline
                                        kdehmelt @jmarcelino
                                        @jmarcelino Hey, I was not successful with a SiPy to reach low deep sleep currents, so I ordered a FiPy and expansion board. But I'm still not getting the wanted currents in uA (with machine.deepsleep still in the range of mA).
                                        Do I need the DeepSleep shield, even with a FiPy?
                                          @kdehmelt that's because the LTE radio needs to be placed into "fly-mode". We have tested that and uA current ranges can be achieved without issues, so no need to worry. The FiPy doesn't need the deepsleep shield.
                                          We will enable fly-mode within a few days in our next release.
                                          • I Offline
                                            incognico @daniel
                                            @daniel said in Root causes of high deep sleep current:
                                            Anything further on this? New firmware, same old 150mA result when activating deepsleep().
                                            (sysname='FiPy', nodename='FiPy', release='1.13.0.b1', version='v1.8.6-849-656704e on 2018-01-10', machine='FiPy with ESP32', lorawan='1.0.0', sigfox='1.0.1')
                                            • 5
                                            • 6
                                            • 7
                                            • 5 / 7
