    Configuration class
    python
    3 Posts 3 Posters 923 Views 3 Watching
      misterlisty
      class Status(object):
           def __init__(self):
               self.__x = 2
          def getx(self):
              print("getx is read only")
              return self.__x
          def setx(self, val):
              print("setx is read only")
         x = property(getx, setx)
      print(Status.x)    #returns <PROPERTY>  what do i do with this
      Status.x=True
      print(Status.x)
      Status.x=False
      print(Status.x)
      Want to create a configution class that i can use to store config info but also have a setter/getter to add logic? Is the above correct?
      • sebS Offline
        seb
        @misterlisty said in Configuration class:
        def init(self):
        self.__x = 2
        def getx(self):
            return self.__x
        Status.x=True
        print(Status.x)
        You are trying to access the CLASS property X, your code should be something like:
            def __init__(self):
                self.__x = 2
            def getx(self):
                return self.__x
        a = Status()
        print(a.x)
        a.x=True
        print(a.x)
          robert-hh @misterlisty
          @misterlisty Besides that setx() should store the value, the other way of doing that is with decorators:
              def __init__(self):
                  self.__x = 2
              @property
              def x(self):
                  return self.__x
              @x.setter
              def x(self, val):
                  self.__x=val
          a=Status()
          print(a.x)
          a.x=1001
          print(a.x)
