    New firmware release v1.11.0.b1 and new updater tool version v1.1.4.b1 (FiPy and GPy support)
    firmware
    32 Posts 11 Posters 8.3k Views 11 Watching
    • ledbelly2142L Offline
      ledbelly2142 @Xykon
      @xykon The code I updated before works with the one of the last firmware versions. Uses the Pycom mqtt.py booting with wifi and Lora, and the Lora Raw example.
        ledbelly2142 @Xykon
        @xykon I went line by line through my code. Visual Studio code was acting strange... I had to reinstall VS Code, manually uninstall the Pymakr extension and reinstall it... again.
        I have been able to get my code working without freezing up. Thanks to @Xykon 's help, I narrowed it down to freezing up caused by my code, not the firmware. I had a line in my boot.py that was redundant, 'Upload' worked after I removed the machine.main('main.py')
        Thank you for your help
          dbrgn @daniel
          @daniel said in New firmware release v1.11.0.b1 and new updater tool version v1.1.4.b1 (FiPy and GPy support):
          Breaking change: the default MISO pin for SPI has been moved from P12 to P14. Remember that SPI, UART, I2C pins can be assigned pretty much anywhere.
          That's a pretty small mention for a breaking change. Also, I could not find this change reflected in the pinout docs (https://docs.pycom.io/chapter/datasheets/development/lopy.html). A lot of people will also have a version of that pinout printed out or stored in a project directory, without any expectation of pinout changes.
          If I had already made hardware that relies on the MISO pin to be on P12, would I have to compile my own patched version of the firmware for every release? Or is this configurable in boot.py? Was there a technical reason for the change (indicating that it's better to have MISO on P14 than P12)?
          sebS L 2 Replies Last reply Reply Quote 0
          • sebS Offline
            seb @dbrgn
            @dbrgn
            You would only need to change the way you instantiate the SPI class to use the old pin layout, you can find an example of this here: https://docs.pycom.io/chapter/firmwareapi/pycom/machine/SPI.html
            No need to recompile the whole firmware. The reason this has been changed is because on new devices P12 controls the external WiFi antenna switch and therefor should not be used for SPI. The pinout diagrams will soon be updated to reflect these changes.
              livius @dbrgn
              @dbrgn
              It is good practice that if you have default configuration which can by changed by params,
              to specify default params also. It is helpfull for self documenting (you do not need to look into docs what is default or place some comments) and then such changes do not affect you at all.
              But this is only my little POV.
                There’s no need to recompile firmware. Every peripheral (except for the SD card) allows to assign its pins anywhere (by passing the pins argument to the constructor). However, if no pins argument is given, a set of default pins is used. P12 is also the safeboot pin and the antenna select pin in the WiPy3, LoPy4, GPy and FiPy.
                Just use the pins argument in the constructor and specify P12 for MISO and that’s it.
                I hope that this is clear.
                • sebS Offline
                  seb @livius
                  @livius
                  Hi, thanks for the feedback, the documentation will be undergoing a lot of improvements soon and we will definitely keep this in mind.
                    robert-hh @daniel
                    If you look into the Pin-out diagrams, there is still a mess about that topic.
                    • sebS Offline
                      seb @robert-hh
                      @robert-hh said in New firmware release v1.11.0.b1 and new updater tool version v1.1.4.b1 (FiPy and GPy support):
                      I just looked over all of the pinouts, only the LoPy4 remained to fixed and has now been resolved. The pinouts now all accurately reflect where each module has its antenna select. I will soon be improving the documentation around the other issue you raised with safe boot.
                        robert-hh @seb
                        @seb Thanks, and in case we do not talk again: Merry Christmas
                          dbrgn @seb
                          @seb said in New firmware release v1.11.0.b1 and new updater tool version v1.1.4.b1 (FiPy and GPy support):
                          @dbrgn
                          Ah, thank you for clarification, that helps :)
                          Yep, I agree :) I was under the impression that this mapping is something that is done in the ESP32 firmware, not in the "MicroPython userspace", which would have been a bit more complicated in my case.
                            tcottle @daniel
                            @daniel Updater tool does not work on Win7(!) No indication of Win10 requirement in the docs and the installer does not catch this error.
                              @tcottle it should work on Win7 as well. What errors do you get?
                                tcottle @daniel
                                @daniel I never got an executable. The installer created and populated python 2.7 and installer directories and then quit. After several install and uninstall cycles I tried it on Win10 machine and everything worked fine
                                  @tcottle thanks for this bug report. We well do some more testing as in principle it works fine on our Win7 test machines.
                                  • I Offline
                                    incognico
                                    I used this on Win7 (64) with no issues.
                                    Installer put a link to the executable in my start menu.
                                    • X Offline
                                      Xykon administrators @tcottle
                                      @tcottle We have tested the firmware update tool on Windows 7 multiple times and never encountered any issues.
                                      Could you please provide the type (32/64bit) of your Windows 7 installation.
                                      Did the installer create the Icon for the firmware update tool in the start menu?
                                      Did you get any error message when trying to launch the tool from the start menu?
                                      I'm working on a new firmware update tool that will work with a single executable file but until this is ready I would like to make sure the current version doesn't have any issues.
                                      Thanks a lot for your assistance.
                                      Christian Ehlers
                                        tcottle @Xykon
                                        @xykon Running Win7 Pro SP1 64 bit. The installer seemed to run OK but I definitely didn't get an icon. Uninstalled and reinstalled multiple times (even tried "Run as Administrator") This machine rarely gets rebooted but it did get a reboot since my original e-mail. Today when I reinstalled the firmware tool now get a start menu icon(!) Go figure ...
                                        • SmeedyS Offline
                                          Smeedy @daniel
                                          @daniel any news on Sigfox for the 1.11 on FiPy?
                                            @Smeedy it will be available in a new release today or tomorrow.
                                            • 2 / 2
