    Lopy and Matchx usage
    matchxgatewaylorawan server
    37 Posts 2 Posters 12.1k Views 2 Watching
      jmarcelino @misterlisty
      @misterlisty
      At first sight that screenshot looks fine, you have an uplink (likely the join request) from the LoPy and then a downlink on 923.3Mhz which is the RX2 window so it should be the join accept reply.
      Do you have any option to use the RX1 window instead? That would be preferrable. I haven't used MatchX backend in months.
      The MatchX is also transmitting with some crazy power (30), try to have the nodes well apart otherwise the receiver on the LoPy will be overloaded.
      If that doesn't help pos the exact macPayload for both uplink and downlinks - you need to expand fields so I can understand exactly what's being sent.
      M 2 Replies Last reply Reply Quote 0
        misterlisty @jmarcelino
        @jmarcelino Hope this helps :)
          @jmarcelino I'm now trying to use BDP instead but i get no indication of connection from MtachX anymore..any suggestion?
          Here is my code
          from network import LoRa
          import binascii
          import struct
          # lora = LoRa(mode=LoRa.LORAWAN, rx_iq=True, tx_power=14, power_mode=LoRa.ALWAYS_ON, public=True, tx_retries=1)
          print("Lora send::-3")
          print("DevEUI[",binascii.hexlify(lora.mac()).upper().decode('utf-8'),"]")
          # create an OTAA authentication parameters
          # dev_eui = binascii.unhexlify('70 B3 D5 49 97 E4 4C 6E'.replace(' ',''))
          # app_eui = binascii.unhexlify('70 B3 D5 7E D0 00 81 BD'.replace(' ',''))
          # app_key = binascii.unhexlify('77 E7 AE FA 56 67 78 3D 5C 2F 4A E0 B9 F2 E3 FC'.replace(' ',''))
          # create an ABP authentication parameters
          dev_eui = struct.unpack(">l", binascii.unhexlify('AE A7 4C 1B'.replace(' ','')))[0]
          # dev_eui = binascii.unhexlify('AE A7 4C 1B'.replace(' ',''))
          app_eui = binascii.unhexlify('39 7E 7F A3 AB 51 CB 3B 60 18 3C 85 E6 B5 56 D6'.replace(' ',''))
          app_key = binascii.unhexlify('9A 92 D8 3B 94 D2 6C DF 03 84 EF D3 59 47 14 85'.replace(' ',''))
          print("Lora send::-2")
          # set the 3 default channels to the same frequency
          lora.add_channel(0, frequency=915200000, dr_min=0, dr_max=4)
          lora.add_channel(1, frequency=915200000, dr_min=0, dr_max=5)
          lora.add_channel(2, frequency=915200000, dr_min=0, dr_max=5)
          # lora.add_channel(4, frequency=915800000, dr_min=0, dr_max=5)
          # lora.add_channel(5, frequency=916000000, dr_min=0, dr_max=5)
          # lora.add_channel(6, frequency=916200000, dr_min=0, dr_max=5)
          # lora.add_channel(7, frequency=916400000, dr_min=0, dr_max=5)
          # lora.add_channel(8, frequency=915600000, dr_min=0, dr_max=5)
          # lora.add_channel(9, frequency=916600000, dr_min=0, dr_max=5)
          print("Lora send::-1")
          def lora_cb(lora):
              events = lora.events()
              if events & LoRa.RX_PACKET_EVENT:
                  print('Lora packet received')
              if events & LoRa.TX_PACKET_EVENT:
                  print('Lora packet sent')
          # lora.callback(trigger=(LoRa.RX_PACKET_EVENT | LoRa.TX_PACKET_EVENT), handler=lora_cb)
          # join a network using OTAA (Over the Air Activation)
          # lora.join(activation=LoRa.OTAA, auth=(dev_eui,app_eui, app_key), timeout=0)
          lora.join(activation=LoRa.ABP, auth=(dev_eui,app_eui, app_key), timeout=0)
          print("Lora send::0")
          # remove all the non-default channels
          ##for i in range(0, 16):
          ##    lora.remove_channel(i)
          while not lora.has_joined():
              time.sleep(5)
              print('Not yet joined...')
          for i in range(3, 16):
          # create a LoRa socket
          print("Lora send::1")
          i = 0
              # set the LoRaWAN data rate
              print("Lora send::2")
              # make the socket blocking
              s.setblocking(True)
              print("Lora send::3")
              # send some data
              count = s.send(bytes([i % 256]))
              print('Sent %s bytes' % count)
              print("Lora send::4")
              s.setblocking(False)
              print("Lora send::5")
              data = s.recv(64)
              print("Lora send::",data)
              i += 1
            @misterlisty said in Lopy and Matchx usage:
            Data Rate 5 isn't valid for your region, that's for EU868. Aren't you receiving an error trying to set it?
            Try data rate 3:
            also your remove channel loop needs to remove up to channel 72, not just 16
            for i in range(3, 72):
            Ideally you shouldn't set them all to the same frequency and should set channels 0 - 7 to match you frequency plan - the 8 frequencies your gateway is listen on. Can you post your frequency plan again from your gateway configuration? I think you posted it before but then removed it.
              @jmarcelino
              	"SX1301_conf": {
              		"lorawan_public": true,
              		"clksrc": 1, /* radio_1 provides clock to concentrator */
              		"lbt_cfg": {
              			"enable": true,
              			"rssi_target": -81, /* dBm */
              			"chan_cfg":[ /* 8 channels maximum */
              				{ "freq_hz": 915200000, "scan_time_us": 5000 },
              				{ "freq_hz": 915400000, "scan_time_us": 5000 },
              				{ "freq_hz": 915600000, "scan_time_us": 5000 },
              				{ "freq_hz": 915800000, "scan_time_us": 5000 },
              				{ "freq_hz": 916000000, "scan_time_us": 5000 },
              				{ "freq_hz": 916200000, "scan_time_us": 5000 },
              				{ "freq_hz": 916400000, "scan_time_us": 5000 },
              				{ "freq_hz": 916600000, "scan_time_us": 5000 }
              			"sx127x_rssi_offset": -7 /* dB */
              		"antenna_gain": 2, /* antenna gain, in dBi */
              		"radio_0": {
              			"enable": true,
              			"type": "SX1257",
              			"freq": 915600000,
              			"rssi_offset": -166.0,
              			"tx_enable": true,
              			"tx_freq_min": 915000000,
              			"tx_freq_max": 928000000
              		"radio_1": {
              			"enable": true,
              			"type": "SX1257",
              			"freq": 916300000,
              			"tx_enable": false
              		"chan_multiSF_0": {
              			"desc": "Lora MAC, 125kHz, all SF, 915.2 MHz",
              			"enable": true,
              			"radio": 0,
              			"if": -400000
              		"chan_multiSF_1": {
              			"desc": "Lora MAC, 125kHz, all SF, 915.4 MHz",
              			"enable": true,
              			"radio": 0,
              			"if": -200000
              		"chan_multiSF_2": {
              			"desc": "Lora MAC, 125kHz, all SF, 915.6 MHz",
              			"enable": true,
              			"radio": 0,
              			"if": 0
              		"chan_multiSF_3": {
              			"desc": "Lora MAC, 125kHz, all SF, 915.8 MHz",
              			"enable": true,
              			"radio": 0,
              			"if": 200000
              		"chan_multiSF_4": {
              			"desc": "Lora MAC, 125kHz, all SF, 916.0 MHz",
              			"enable": true,
              			"radio": 1,
              			"if": -300000
              		"chan_multiSF_5": {
              			"desc": "Lora MAC, 125kHz, all SF, 916.2 MHz",
              			"enable": true,
              			"radio": 1,
              			"if": -100000
              		"chan_multiSF_6": {
              			"desc": "Lora MAC, 125kHz, all SF, 916.4 MHz",
              			"enable": true,
              			"radio": 1,
              			"if": 100000
              		"chan_multiSF_7": {
              			"desc": "Lora MAC, 125kHz, all SF, 916.6 MHz",
              			"enable": true,
              			"radio": 1,
              			"if": 300000
              		"chan_Lora_std": {
              			"desc": "Lora MAC, 500kHz, SF8, 915.825 MHz",
              			"enable": true,
              			"radio": 0,
              			"if": 250000,
              			"bandwidth": 500000,
              			"spread_factor": 8
              		"chan_FSK": {
              			"desc": "FSK disabled",
              			"enable": false
              		"tx_lut_0": {
              			/* TX gain table, index 0 */
              			"pa_gain": 0,
              			"mix_gain": 8,
              			"rf_power": -6,
              			"dig_gain": 3
              		"tx_lut_1": {
              			/* TX gain table, index 1 */
              			"pa_gain": 0,
              			"mix_gain": 10,
              			"rf_power": -3,
              			"dig_gain": 3
              		"tx_lut_2": {
              			/* TX gain table, index 2 */
              			"pa_gain": 0,
              			"mix_gain": 9,
              			"rf_power": 0,
              			"dig_gain": 0
              		"tx_lut_3": {
              			/* TX gain table, index 3 */
              			"pa_gain": 0,
              			"mix_gain": 12,
              			"rf_power": 3,
              			"dig_gain": 0
              		"tx_lut_4": {
              			/* TX gain table, index 4 */
              			"pa_gain": 1,
              			"mix_gain": 8,
              			"rf_power": 6,
              			"dig_gain": 2
              		"tx_lut_5": {
              			/* TX gain table, index 5 */
              			"pa_gain": 1,
              			"mix_gain": 9,
              			"rf_power": 10,
              			"dig_gain": 0
              		"tx_lut_6": {
              			/* TX gain table, index 6 */
              			"pa_gain": 1,
              			"mix_gain": 11,
              			"rf_power": 11,
              			"dig_gain": 2
              		"tx_lut_7": {
              			/* TX gain table, index 7 */
              			"pa_gain": 1,
              			"mix_gain": 11,
              			"rf_power": 12,
              			"dig_gain": 1
              		"tx_lut_8": {
              			/* TX gain table, index 8 */
              			"pa_gain": 1,
              			"mix_gain": 11,
              			"rf_power": 13,
              			"dig_gain": 0
              		"tx_lut_9": {
              			/* TX gain table, index 9 */
              			"pa_gain": 1,
              			"mix_gain": 12,
              			"rf_power": 14,
              			"dig_gain": 1
              		"tx_lut_10": {
              			/* TX gain table, index 10 */
              			"pa_gain": 2,
              			"mix_gain": 8,
              			"rf_power": 16,
              			"dig_gain": 0
              		"tx_lut_11": {
              			/* TX gain table, index 11 */
              			"pa_gain": 2,
              			"mix_gain": 12,
              			"rf_power": 20,
              			"dig_gain": 2
              		"tx_lut_12": {
              			/* TX gain table, index 12 */
              			"pa_gain": 2,
              			"mix_gain": 14,
              			"rf_power": 23,
              			"dig_gain": 2
              		"tx_lut_13": {
              			/* TX gain table, index 13 */
              			"pa_gain": 2,
              			"mix_gain": 15,
              			"rf_power": 25,
              			"dig_gain": 0
              		"tx_lut_14": {
              			/* TX gain table, index 14 */
              			"pa_gain": 3,
              			"mix_gain": 11,
              			"rf_power": 26,
              			"dig_gain": 3
              		"tx_lut_15": {
              			/* TX gain table, index 15 */
              			"pa_gain": 3,
              			"mix_gain": 13,
              			"rf_power": 28,
              			"dig_gain": 0
              	"gateway_conf": {
              		/* change with default server address/ports, or overwrite in local_conf.json */
              		"server_address": "aux.matchx.io",
              		"serv_port_up": 1700,
              		"serv_port_down": 1700,
              		/* adjust the following parameters for your network */
              		"keepalive_interval": 10,
              		"stat_interval": 30,
              		"push_timeout_ms": 100,
              		/* forward only valid packets */
              		"forward_crc_valid": true,
              		"forward_crc_error": false,
              		"forward_crc_disabled": false,
              		/* GPS configuration */
              		"gps_tty_path": "/dev/ttyS1",
              		/* GPS reference coordinates */
              		"ref_latitude": 0.0,
              		"ref_longitude": 0.0,
              		"ref_altitude": 0
                Thanks @misterlisty
                Please remove your all add_channel and remove_channel code and replace it with the following (yes remove_channel should be first). It should then match your gateway configuration. Also change the SO_DR to 3 as mentioned in my previous post. Do try OTAA and ABP if you can.
                for i in range(0, 72):
                # set the 8 channels for MatchX configuration
                for channel in range(0,8):
                    lora.add_channel(channel, frequency=915200000+channel*200000, dr_min=0, dr_max=3)
                  @jmarcelino I get an error if i try to remove channels upto 72
                    @misterlisty
                    Is your LoPy configured configured for the EU868 region by any chance?
                    It should have selected 915Mhz if you chose Australia during firmware upgrade.
                    Please check with
                    lora = LoRa()
                    lora.frequency()
                    also are you running the latest firmware?
                      @jmarcelino
                      lora = LoRa()
                      lora.frequency()
                      doesn't return anything...
                      My firmware is MicroPython v1.8.6-834-g5677703c on 2017-11-13; FiPy with ESP32
                        @misterlisty
                        Did you try it on the REPL?
                        Try print(lora.frequency())
                          @jmarcelino The result is 868000000
                          Appears like it isn't Australia..i assume i have to reapply firmware?
                            @misterlisty
                            Yes that’s set to EU868. We need to reset the device in Pycom’s database before you do a firmware upgrade to change the location. Please send me the MAC address of the WLAN via chat or email a request to support@pycom.io.
                            import binascii
                            binascii.hexlify(network.WLAN().mac(),':').decode()
                              @jmarcelino Here is my Mac <removed>
                              How do you know what setting my fopy has? DO you sedn this during firmware update?
                                We have no record of your board, so I guess you never updated it?
                                We really recommend always updating all our boards first. The factory firmware tends to be very old - or set to the wrong region as yours was.
                                In any case if you run the upgrade tool and choose Australia, then it should set to 915Mhz correctly and you can use the code I posted.
                                The firmware update instructions are at: https://docs.pycom.io/chapter/gettingstarted/installation/firmwaretool.html
                                  @jmarcelino I have connected a wire from GND to G23 and the fopy will not go into upgrade mode. Its connected to a pysense board while i atempt this. It just running my normal code...can i upgrade while connected to the pysense board? Instructions suggest yes.
                                    @misterlisty
                                    Yes you can use the PySense and you don't need the wire anymore.
                                    Make sure you update the Pysense firs, follow the steps here:
                                    When you have the new firmware on the Pysense load the the Pycom Firmware Update tool and tick the box which says Pytrack/Pysense:
                                    With this setup you don't need the jumper wire as the tool will use the Pysense to put the FiPy into programming mode.
                                      @jmarcelino Will atempt update through pysense board shortly but it not upgrading the firmware if i use an USB adapter, connect G23 & GND...its running the normal code instead of going in upgrade mode..any suggestion here?
                                        @misterlisty
                                        It has to go into flash programming mode, it's a very low level hardware feature.
                                        Are you sure you are connecting GND and G23 (also called P2 on the pin map https://docs.pycom.io/chapter/datasheets/downloads/fipy-pinout.pdf )
                                        Also when you use an USB adapter what exactly is your setup?
                                        In any case I think it will be easier to use the Pysense.
                                          misterlisty
                                          OK..here is my status..have updated Fopy to latest firmware ie 1.1.12b
                                          Here is my OTTA code..it appears to work if you look at the logs of MatchX but code says not yet joined still.
                                          import binascii
                                          import struct
                                              time.sleep(5)
                                          print('Finally joined...')
                                          i = 0
                                              s.setblocking(True)
                                              # send some data
                                              data = s.recv(64)
                                              i += 1
                                            @misterlisty
                                            You're removing channels twice unnecessarily, remove your second part:
                                            Also you're sill using RX2, there are two places for this configuration, I think you missed under Application Configuration -> Network Settings. Please set it to RX1 there.
