    CAN peripheral support
    cancanbusbusperipheralcontroller
    18 Posts 7 Posters 6.5k Views 8 Watching
      jmarcelino @TravisT
      @TravisT
      There is an option at build time (menuconfig) to change pins otherwise the default GPIO5 would conflict on the LoPy/Sipy (but work on the WiPy)
      However CAN is not officially supported yet, so far it's been a side project started in the ESP32.com community using some early information from Espressif.
      • E Offline
        eerimoq
        The CAN driver part of Pumbaa works in the normal case for ESP32. Improved error handling is being implemented as I write.
        Pumbaa does support the ESP32, but not the Pycom boards in particular. It's just a matter of creating a few files with pin mapping definitions, so can easily be added.
          johand
          I found this project, anyone tried it? A step closer to CAN-support for Pycom-devices?
          https://github.com/danicampora/pycom-micropython-can
          Johan
            TravisT
            I have been working with Daniel, there should hopefully be a tested CAN implementation in the master branch of the repo in the not to distant future.
              johand @TravisT
              @travist Sounds great! Do you need any help testing? What transceiver do you use?
              Johan
                TravisT
                @johand
                I think after Daniel finishes up a couple more features and I can do initial testing it will likely be available as some sort of Beta, but that is more up to Daniel.
                Transceivers are mostly transparent to CAN, so this is not really an issue. I would suggest just buying a common one, especially if you are running 500k or slower.
                  johand @TravisT
                  @travist Any update on CAN support?
                    TravisT
                    I have done some more testing with Daniel's latest library. I think the initial version will be released very soon, maybe within the week.
                      johand @TravisT
                      That is very good news!
                      • sebS Offline
                        seb
                        CAN support will be available in the next firmware release which should be coming out in a few days, its just undergoing final testing.
                        • sebS Offline
                          seb
                          A firmware with the CAN library has just been released and the documentation for it is available here: https://docs.pycom.io/chapter/firmwareapi/pycom/machine/CAN.html
