Connecting to Eduroam
I have been trying to figure out how to connect to Eduroam on my nano-gateway and still having some trouble. I have used all the examples in the WLAN docs but I believe I need to change stuff in the main.py as well as the config.py. Was hoping there was something as straight forward as:
WIFI_SSID = 'eduroam'
WIFI_AUTH = 'username'
WIFI_PASS = 'pass'But it doesn't seem to be the case.
I've been searching for python examples but only found how to connect a Linux system. Eduroam is basically everywhere so I'm sure this answer will be well used.
Dylan
@dylan
Eduroam is a WPA2 Enterprise network. You need to change the WLAN initialisation to it, see the Connecting with EAP-PEAP or EAP-TTLS example:https://docs.pycom.io/chapter/tutorials/all/wlan.html
I think for Eduroam your username and the identity are your e-mail address. You shouldn't need to have the ca_certs option.
As a quick test change line 207 in nanogateway.py (under _connect_to_wifi function) from
self.wlan.connect(self.ssid, auth=(None, self.password))to:
self.wlan.connect(ssid='eduoram', auth=(WLAN.WPA2_ENT, 'youremail', 'password'), identity='youremail')Of course in this replacing the placeholder fields your e-mail and password respectively.
I not sure this will work as I've not used eduroam in a few years so any feedback would be appreciated.
@jmarcelino thanks for the reply, I suspected it had something to do with the WPA2 Enterprise network just no idea how to implement it, cheers for the help. I am still having trouble with what placeholders to put in? I put the WPA2 Enterprise stuff (wlan.connect etc) into the config file, but I believe I need to change stuff in the main too, sorry for lack of explanation, gotta go out for a bit and wanted to get this post out.
@dylan
You need to change nanogateway.py, changing config.py won’t do anything.For a quick test just put the values directly on the self.wlan.connect(...) call , if it works we’ll change it to pick them up from config.py
@jmarcelino I found where I made my mistake earlier, the password is case sensitive haha. Its connected and working well.
Thanks for the help
@jmarcelino
I have followed the section "Connecting with EAP-PEAP or EAP-TTLS" of https://docs.pycom.io/chapter/tutorials/all/wlan.html, and your comments @jmarcelino , but I can't connect my LoPy to Eduroam. Is it possible that the authentication method will be important? In my university the authentication method is EAP-MSCHAP-V2, and my question is: Is this method supported by LoPy? -
@franman
How your connection looks like?
I suppose you do not provide any cert as it is not needed on client side forEAP-MSCHAP-V2
and are you sure that it is notPEAP-EAP-MSCHAPv2? -
@livius I try connect with the following command:
wlan.connect(ssid="eduroam",auth=WLAN.WPA2_ENT,EDUROAM_USER,EDUROAM_PWD),identity=EDUROAM_IDENTITY,timeout=5000)
Where:
- EDUROAM_USER = my email address
- EDUROAM_PWD = my eduroam passwd
- and EDUROAM_IDENTITY = my email address too.
And yes, as the document to configure eduroam in my university says, the authentication mechanism is EAP-MSCHAP-V2.(an screenshot of the web, unfortunally in spanish, is attached)
It seems as some of you got it to work. Can you please provide a short guide with some code that worked?
@thomand1000 Unfortunately I didn't get it entirely fixed, the best theory is that the Eduroam has a UDP timeout feature, I did find a work around that has been working consistently, it gives a maximum of about 30 seconds downtime every 31minutes.
The few things I changed are in the nanogateway.py file for the gateway example:
After 1900 seconds the message "Failed to pull downlink packets from server" would occur so I put a machin.reset() in:
def _pull_data(self): token = uos.urandom(2) packet = bytes([PROTOCOL_VERSION]) + token + bytes([PULL_DATA]) + ubinascii.unhexlify(self.id) with self.udp_lock: try: self.sock.sendto(packet, self.server_ip) except Exception as ex: machine.reset() self._log('Failed to pull downlink packets from server: {}', ex)And every 4-5th restart it would just not connect so I did a simple timer reset in the wifi connection:
def _connect_to_wifi(self): count = 0 self.wlan.connect(ssid='eduroam', auth=(WLAN.WPA2_ENT, 'Username', 'Password'), identity='Username', timeout = 30) while not self.wlan.isconnected(): utime.sleep(1) count = count + 1 print(count) if count >= 30: machine.reset() self._log('WiFi connected to: {}', self.ssid)Hopefully one day I'll be able to get the UDP timeout thing properly fixed, but they don't change things like this in a hurry for a student haha.
