    Packet loss in Lorawan
    nano gatewaypacket loss
    13 Posts 7 Posters 3.3k Views 7 Watching
      rpct
      I have two lopys :
      • nano gateway
      • node that just sends an unconfirmed packets with a 4s period
        I get lot of packet losses as you can see here in TTN console :
      Here is packet detail with RSSI :
      Lopys are in an indoor environment, either quite close < 5m or < 20m separated by a wall. I've tested in two buildings and got in both cases lot of losses > 50%.
      Have you experienced same results?
      How can I reduce packet loss?
      As a workaround I could send confirmed packets and retransmit it when it is lost. But for class A device, that means a retransmission will be done after 2s, meaning a very high latency.
        jcaron @rpct
        @rpct Have you correctly configured the sending node to only use the single frequency the nano-gateway is listening on?
        R C 2 Replies Last reply Reply Quote 1
          rpct @jcaron
          @jcaron
          Here is node code :
          """ Node example compatible with the LoPy Nano Gateway """
          from network import LoRa
          import binascii
          import struct
          import config
          print("Single channel node")
          # initialize LoRa in LORAWAN mode.
          dev_eui = binascii.hexlify(lora.mac()).decode('utf-8').upper()
          if dev_eui in config.NODES_AUTH :
              print('Got auth parameters for {} TTN node'.format(config.NODES_AUTH[dev_eui].ttn_name))
          else :
              raise Exception('Cannot get OTA auth parameters for node with DEV_EUI {}'.format(dev_eui))
          # set the 3 default channels to the same frequency (must be before sending the OTAA join request)
          lora.add_channel(0, frequency=config.LORA_FREQUENCY, dr_min=0, dr_max=5)
          lora.add_channel(1, frequency=config.LORA_FREQUENCY, dr_min=0, dr_max=5)
          lora.add_channel(2, frequency=config.LORA_FREQUENCY, dr_min=0, dr_max=5)
          # remove all the non-default channels
          for i in range(3, 16):
              lora.remove_channel(i)
          # join a network using OTAA
          if(config.NODES_AUTH[dev_eui].auth_type == LoRa.ABP) :
              print('doing ABP activation')
              if(config.NODES_AUTH[dev_eui].abp_auth == None) :
                  raise Exception('No abp params for node {}'.format(config.NODES_AUTH[dev_eui].ttn_name))
              else :
                  lora.join(activation=LoRa.ABP, auth=(struct.unpack(">l", binascii.unhexlify(config.NODES_AUTH[dev_eui].abp_auth.dev_add))[0],
                                                       binascii.unhexlify(config.NODES_AUTH[dev_eui].abp_auth.nw_sess_key),
                                                       binascii.unhexlify(config.NODES_AUTH[dev_eui].abp_auth.app_sess_key)),
                                                 timeout=0, dr=config.LORA_NODE_DR)
          elif(config.NODES_AUTH[dev_eui].auth_type == LoRa.OTAA) :
              print('doing OTAA activation')
              if(config.NODES_AUTH[dev_eui].otaa_auth == None) :
                  raise Exception('No otaa params for node {}'.format(config.NODES_AUTH[dev_eui].ttn_name))
              else :
                  lora.join(activation=LoRa.OTAA, auth=(binascii.unhexlify(config.NODES_AUTH[dev_eui].otaa_auth.app_eui),
                                                        binascii.unhexlify(config.NODES_AUTH[dev_eui].otaa_auth.app_key)),
                  while not lora.has_joined():
                      time.sleep(2.5)
                      print('Not joined yet...')
                  print('Joined')
          else :
              raise Exception("Authentification type : {} not handled".format(config.NODES_AUTH[dev_eui].auth_type))
          pycom.heartbeat(False)
          pycom.rgbled(0x00ff00)
          # create a LoRa socket
          # set the LoRaWAN data rate
          s.setsockopt(socket.SOL_LORA, socket.SO_DR, config.LORA_NODE_DR)
          # make the socket blocking
          s.setblocking(False)
          time.sleep(1.0)
          i = 0
          while True :
              pkt = b'PKT #' + bytes([i])
              print('Sending:', pkt)
              s.send(pkt)
              i += 1
              #time.sleep(4)
              rx, port = s.recvfrom(256)
              if rx:
                  print('Received: {}, on port: {}'.format(rx, port))
              time.sleep(4)
          time.sleep(6)
          I observed that moving code that removes all default channel
          AFTER join gives better results. I cannot explain it. In my case, I'm only using 1 channel, Join request / Accept will be done using 3 first channels all configured as same channels. Deleting other channels before or after join success should be the same? In all cases, when node sends a packet it only sends it on 3 first channels.
          J H 2 Replies Last reply Reply Quote 0
            jcaron @rpct
            @rpct In the general case, changing the frequencies after the join (and a few packet exchanges) could be different as the gateway can give instructions to the node about which channels to use.
            Not sure if the nano-gateway code does anything like that...
            • bmarkusB Offline
              bmarkus @jcaron
              @jcaron said in Packet loss in Lorawan:
              Gateways never give instructions (more precisely MAC commands) to devices, it is up to the Network Server. Gateways do not have encryption keys nor any knowledge on devices.
                chumelnicu @jcaron
                @jcaron The node is to close to gateway ...
                • H Offline
                  hajermet @rpct
                  @rpct how did you import the network module please? I'm new to pycom and I'm having problems with that . Can you help?
                    rpct
                    @chumelnicu could you be more precise about mechanisms causing packet loss when gw is too close from node? How can we calculate minimum distance? How can we check a node is too close?
                      robert-hh @rpct
                      @rpct try to delete all channels but one after joining. That solved it for me
                        chumelnicu @rpct
                        @rpct To much power could bring lora module in supra-saturation ...For that is important to have a minimum distance between node and gateway .... Just try to put the gateway in other room
                          jmarcelino @robert-hh
                          That’s only true for single channel gateways (using a Lopy as a nano-gateway). When using a real, full, LoRaWAN gateway you should keep all the channels.
                          Real gateways also have more sensitivity it’s recommended that nodes are least 2 meters away to avoid overloading the RX amplifiers.
                            robert-hh @jmarcelino
                            @jmarcelino as far as OI read it, that's the case here.
                              Yes thanks @robert-hh,
                              Just wanted to make it clear to anyone looking this answer up for the more generic node - gateway separation concern that was being discussed
                              With your input, this post could be even better đŸ’—
