machine.SOFT_RESET
  • LoPy updated to 0.9.0.b2
    Following the tutorial for WLAN (section 3.2)
    [https://docs.pycom.io/lopy/lopy/tutorial/wlan.html]
    I an getting an error
    AttributeError: 'module' object has no attribute 'SOFT_RESET'
  • @daniel, I got it working using the code example that @DarkHawk posted here.
    I only added a line wlan.ifconfig(config=('192.168.2.5', '255.255.255.0', '192.168.2.1', '8.8.8.8'))
    before nets = plan.scan().
    When I compare the few lines of code I cannot really see the difference. I'm not sure, but the only logical explanation would be a typo in the ssid or password. Of course I confirmed them several times...
    Only issue left is the DNS but that you know about already.
  • Hi kurt,
    Thanks for the report. I confirm that there's a bug on the DNS setting part. I cannot reproduce your reconnect issue yet, but I'll look into it.
  • @Maris I appreciate your work to improve the documentation and your quick response.
    I tried the code you suggested:
    from network import WLAN
    # configure the WLAN subsystem in station mode (the default is AP)
    wlan = WLAN(mode=WLAN.STA)
    # go for fixed IP settings
    #wlan.ifconfig(config='dhcp') # trying dhcp
    wlan.scan()     # scan for available networks
    wlan.connect('my-ssid', auth=(WLAN.WPA2, 'my-password'), timeout=5000)
    for i in range(10):
        if wlan.isconnected():
            break
    print(wlan.ifconfig())
    When I check wlan.ifconfig() it prints ('192.168.2.5', '255.255.255.0', '192.168.2.1', '0.0.0.0'). The DNS address is set to 0!
    Then it starts printing reconnect, repeating it endlessly, no timeout. I can stop it by issuing a wlan.disconnect().
    The whole reset sequence using the code above looks like this:
    configsip: 0, SPIWP:0x00
    mode:QIO, clock div:2
    load:0x3fff9010,len:8
    load:0x3fff9018,len:312
    load:0x40078000,len:2352
    load:0x4009f000,len:1196
    entry 0x4009f2d8
    frc2_timer_task_hdl:3ffd2704, prio:22, stack:2048
    tcpip_task_hdlxxx : 3ffd7224, prio:18,stack:2048
    pp_task_hdl : 3ffdb494, prio:23, stack:8192
    mode : softAP(24:0a:c4:00:11:c9)
    dhcp server start:(ip: 192.168.4.1, mask: 255.255.255.0, gw: 192.168.4.1)
    mode : sta(24:0a:c4:00:11:c8)
    MicroPython f5444c7 on 2016-10-12; LoPy with ESP32
    >>> reconnect
    reconnect
    reconnect
    reconnect
    Any idea?
  • @kurt We try to constantly fix mistakes in documentation, so time by time documents get updated.
    Please use code from WiFi example https://docs.pycom.io/lopy/lopy/quickref.html#wlan-wifi
  • @Maris said in machine.SOFT_RESET:
    https://docs.pycom.io/wipy/library/network.html?highlight=wlan.init#network.wlan.init
    Sorry, I don't get it. What is it to be done instead of checking for machine.SOFT_RESET? Or has the documentation in https://docs.pycom.io/wipy/library/network.html?highlight=wlan.init#network.wlan.init changed again?
    Cheers, Kurt.
  • More observations...
    • Expansion board manual shows use of "GP" values for identifying the IO pins e.g. "GP16", but you actually seem to have to
    • pushbutton on G17, even when set as an input (with a PULL_UP) this pin appears to be driven low (not a fault on the expansion board), so the pushbutton input doesn't work.
    • the heartbeat LED won't show any colour other than Blue.
    • I've not found any means to control timing given the absence of the Timer class - e.g. to get a LoRa node to send a message once every XXX seconds?
    • It is easy to get a crash with LoRa things being in a tight loop (hence the need for some means to control timing):
      /home/danicampora/Code/pycom/esp-idf-new/components/freertos/./queue.c:1326 (xQueueGenericReceive)- assert failed!
      Guru Meditation Error: Core 0 panic'ed.
    Please can we have more documentation e.g.
    • What does the parameter to the LoRa socket recv function do?
  • Hi robotmad,
    Great to hear that you found a solution. Indeed there is a mistake in the example.
    It should be like here: https://docs.pycom.io/wipy/library/network.html?highlight=wlan.init#network.wlan.init
    We will fix example code.
    Reset cause function not jet implemented on LoPy board. We working on that.
  • Investigating I see that after a soft reset (Ctrl-D) reset_cause() still reports 'None'.
    Further:
    wlan.init(WLAN.STA)
    gives an error:
    TypeError: extra positional arguments given
    Although initialising
    wlan =WLAN(mode=WLAN.STA)
    works OK.
5 out of 9
