    Root causes of high deep sleep current [LoPy1, WiPy2 and SiPy], all the new modules **do not have deepsleep issues**
    deepsleep
    127 Posts 48 Posters 110.1k Views 57 Watching
      derchris
      I‘ll try it tomorrow when I‘m back in office.
      But I already tried with 8 secs and that did change nothing.
      Well, is there any option to completely disable the modem? For the current project I don‘t need it
      • I Offline
        incognico
        All tests in this post are on an expansion board v2.1A, only TX/RX jumpers in place, with a USB inline power monitor. FyPi module is freshly formatted (mkfs'd) with 1.15.0.b1 firmware.
        No module installed: 16mA (power LED etc)
        Insert FyPi module. Result: 264mA; settles down to 137mA after several seconds
        >>> import os
        >>> os.uname()
        (sysname='FiPy', nodename='FiPy', release='1.15.0.b1', version='v1.8.6-849-baa8c33 on 2018-01-29', machine='FiPy with ESP32', lorawan='1.0.0', sigfox='1.0.1')
        >>> import machine
        >>> machine.deepsleep(10000)
        Result from above: 46.9mA during deep sleep
        >>> import network
        >>> from network import WLAN
        >>> wlan=WLAN()
        >>> wlan.deinit()
        Result from above: Drops from 137mA to 75mA
        >>> import machine
        >>> machine.deepsleep()
        • I Offline
          incognico
          Same module powered via digital bench supply @5.0V shows the same current draw as the previous test (less the 16mA of the bare expansion board). Power is to VIN & GND pins. No other pins connected.
          Same direct supply @ 3.6V shows slightly increased draw, ~39mA in sleep.
          This test was with empty main.py; boot.py as follows:
          print('-START-')
          time.sleep(10)
          print('-SLEEP-')
          machine.deepsleep(20000)
          print('-AWAKE-')
          I have not found any sleep current changes from [de]initializing WLAN or LoRa so have not done any of that in an attempt to keep the test as simple as possible.
            derchris @incognico
            @incognico
            Well, I think it‘s time to find a pro-grade moldule :(
              Hello everyone,
              We have been doing lots of deepsleep tests again on FiPy and GPy. Deepsleep works well and we measure values between 35uA and 45 uA which will be improved to ~20uA after firmware updates to the LTE radio. User experiencing high deepsleep currents are due to timing issues in the firmware when sending the LTE radio to airplane mode. We will be working on fixing that ASAP during the next few days.
                derchris @daniel
                @daniel sounds good!
                Any news regarding the BLE sleep modes? AFAIK it‘s not possible to sleep and wait for BLE interrupts (because of the ESP32)
                  Thosch42
                  Hi all!
                  Since a few days I'm working on a deepsleep issue. I have a Lopy with Deepsleep-Shield, powered from my Otii Arc. Just connected the UART RX, to see what's going on. No Expansionboard. Latest Firmware, and a pretty simple script:
                  from deepsleep import DeepSleep
                  import deepsleep
                  from network import Bluetooth, WLAN
                  bluetooth = Bluetooth()
                  bluetooth.deinit()
                  wlan = WLAN(mode=WLAN.STA)
                  wlan.deinit()
                  ds = DeepSleep()
                  # get the wake reason and the value of the pins during wake up
                  wake_s = ds.get_wake_status()
                  print(wake_s)
                  if wake_s['wake'] == deepsleep.PIN_WAKE:
                      print("Pin wake up")
                  elif wake_s['wake'] == deepsleep.TIMER_WAKE:
                      print("Timer wake up")
                  else:  # deepsleep.POWER_ON_WAKE:
                      print("Power ON reset")
                  ds.enable_pullups('P17')  # can also do ds.enable_pullups(['P17', 'P18'])
                  ds.enable_wake_on_fall('P17') # can also do ds.enable_wake_on_fall(['P17', 'P18'])
                  print("Go to sleep")
                  ds.go_to_sleep(20)
                  And my deepsleep power consumtion is 6.5mA.
                  Am I doing something wrong?
                  Thomas
                  • sebS Offline
                    seb
                    Deep sleep using a LoPy an Deepsleep shield should result in a current draw of 530uA, could you please detail your setup for your current measurement and we can try replicate it? What voltage are you setting the Otii? Are you applying the voltage to Vin or 3.3V? Have you tried with the UART disconnected?
                      Thosch42 @seb
                      @seb
                      Hi!
                      I found the problem. My Otii Arc was defective. So, everything is fine.
                      Thomas
                        dbrgn @Thosch42
                        @thosch42 said in Root causes of high deep sleep current [LoPy1, WiPy2 and SiPy], all the new modules **do not have deepsleep issues**:
                        Oh, how did you find out? With the resistor test?
                          Thosch42 @dbrgn
                          @dbrgn
                          Nope! A little bit harder ;-)
                          I stripped down my complete design, module per module, to find out who draws the 6.5mA. The last step was, to pull the cable from the output terminal of my Arc. And, oh wonder, I had still a current of 6.5mA ;-)
                          I contacted the support from Qoitech, and a replacement arrived next day!!!
                          Thomas
                            lj Pybytes Beta
                            @Pycom
                            Will LoPy1 be redesigned to allow newer production bacthes to have a proper deesleep mode( ~5 and ~15uA) by its own ( at least this is what I undertood) , or will it need the deepsleep shield for ever?
                            migrating to Lopy4 is not an option because it is not priced the same.
                            Thanks for your reply.
                              robert-hh @lj
                              @lj I would not expect that. Any new devices use ESP32 Rev 1, and the code as it is assumes PSRAM for a Rev1 device. Obviously, that could be changed, but not easily.
                                james_seth
                                @Fred
                                I have two Lopy v1.0r boards. Due to the evolving ESP32 code set I benched the boards for a while and used an alternative product to accomplish the task due to time constraints and have now come back to redesign the product using the Lopy. As the product runs off a battery the low power capabilities is a must. I only saw this post now and the survey is closed.
                                Kind regards,
                                James
                                • sebS Offline
                                  seb @james_seth
                                  @james_seth
                                  Sent an email to salessupport@pycom.io if you need some deepsleep shields
                                    akshayjames @incognico
                                    @incognico Hi
                                    The high current during deepsleep is due to the LTE module. LTE is started automatically during boot. You need to deinit LTE separately before calling deepsleep as LTE is not stopped automatically during deepsleep.
                                    I had the same issue. My FiPy module was drawing 49mA during deepsleep. After I called LTE deinit, the current draw reduced by a lot at that time itself. After that deepsleep worked as expected. :)
                                    from network import LTE
                                    lte = LTE()
                                    LTE.deinit()
                                    Hope this helps.
                                      dmayorquin
                                      Hi @Fred, I need some help with the Pysense deep sleep mode. I have a SiPy + Pysense + 3.7 V LiPo battery (Using JST connector on Pysense). I'm testing Deep sleep mode from last version of Pysense library but I'm measuring high deep sleep current consumption.
                                      My program disabled WiFi in boot.py. In main.py It blinks an LED for 5 seconds and then sleeps 20 seconds. These are my results:
                                      SiPy firmware: 1.18.0
                                      Pysense firmware: 0.0.8
                                      Blinking: ~50 mA
                                      Deep sleep: ~2.2 mA
                                      main.py code:
                                      from pysense import Pysense
                                      py = Pysense()
                                      #Turn-off heartbeat
                                      if pycom.heartbeat() == True:
                                          pycom.heartbeat(False)
                                      #Blink the LED
                                      for i in range(5):
                                          pycom.rgbled(0x1F)
                                          time.sleep(0.05)
                                          pycom.rgbled(0x00)
                                          time.sleep(1)
                                      #Sleep 20 seconds
                                      py.setup_sleep(20)
                                      py.go_to_sleep()
                                      boot.py code:
                                      wlan = WLAN()
                                      wlan.deinit()
                                      I tried other SiPy firmware versions (1.13.0.b1, 1.15.0.b1, 1.17.3.b1, 1.19.0.b4) but results are the same. @daniel said a few months ago this Pysense issue was resolved, but can you confirm if there is still something wrong with Pysense? Or, am I missing some line of code to make deep sleep mode works as it should? Thanks in advance.
                                        Radec @dmayorquin
                                        @dmayorquin I think you forget lines codes :
                                        Example with timer :
                                        machine.deepsleep(3600000 )  # 1 hours
                                          dmayorquin @Radec
                                          Hi @radec, thanks. According to documentation, machine.deepsleep() works well when you are not using a shield or expansion board, but in my case I'm using SiPy + Pysense, so I must use the deep sleep methods of Pysense library. I've found a solution which I posted here:
                                          https://forum.pycom.io/topic/3594/how-to-deep-sleep-with-sipy-pysense-3-7v-lipo
                                          By the way, I also tried machine.deepsleep() with my setup, but didn't work (the deep sleep current was ~60 mA).
                                            mattliddle
                                            @Fred What do you need to do to accomplish that low of power consumption on the GPy with deep sleep? I'm getting about 18 mA when it's going into deep sleep..
                                            # and later on in the code once my sensor is done running, I call this
                                            machine.deepsleep(30000)
                                            What could be going on? does the GPy 1.0 need a power saving board as well? I've looked around on the forum only to find no real solution yet, but other users with the same issue.
                                            • 5
                                            • 6
                                            • 7
                                            • 6 / 7
