    Problem joining TTN in Australia with OTAA using a LoPy 4
    lopy4ttnjoinotaa
    15 Posts 5 Posters 4.0k Views 5 Watching
      jojo @rskoniec
      @rskoniec
      That's right, I forgot to add the import time in the sample code, but that's not the issue here since the code is stuck at the join and does not reach the while loop :)
      I'll edit the code in the original post.
      Also the order of the 2 statements in the loop does not really matter.
        jmarcelino @jojo
        Hi @jojo,
        OK, I'm not sure why it's still on 868Mhz but fortunately you can use the new region setting functions!
        You can now initialise lora with
        lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.AU915)
        and it'll be set to the (also newly supported) Australian AU915 frequency map!
        (you'll still need to disable channels if you gateway only supports 8 out of the 72)
        This is also saved with lora.nvram_save() and nvram_restore()
        J R philwilkinsonP 4 Replies Last reply Reply Quote 0
          jojo @jmarcelino
          @jmarcelino
          Thanks for that! I'll try that first thing tomorrow morning and let you know how it goes :).
            rskoniec @jojo
            @jojo I thought so, but I was not able to try this myself. :)
              rskoniec @jmarcelino
              @jmarcelino Btw, is there a new version 1.16.0.b1? I couldn't find any info about it on forum.
              • sebS Offline
                seb @rskoniec
                @rskoniec An announcement about it is coming momentarily
                  jojo @jmarcelino
                  @jmarcelino
                  Good morning!
                  I can confirm it works very well! Thanks Pycom for your awesome work!
                  Here is the code I use to join TTN in Australia, in case someone else face the same issue:
                  from network import LoRa
                  import binascii
                  lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.AU915, adr=False, tx_retries=0, device_class=LoRa.CLASS_A)
                  # credentials
                  APP_EUI = 'XXXXX'
                  APP_KEY = 'YYYYYYYY'
                  # remove some channels
                  for i in range(16, 65):
                      lora.remove_channel(i)
                  for i in range(66, 72):
                  # create an OTA authentication params
                  app_eui = binascii.unhexlify(APP_EUI.replace(' ',''))
                  app_key = binascii.unhexlify(APP_KEY.replace(' ',''))
                  print("Joining")
                  # join a network using OTAA if not previously done
                  Johan
                  • philwilkinsonP Offline
                    philwilkinson @jmarcelino
                    @jmarcelino said in Problem joining TTN in Australia with OTAA using a LoPy 4:
                    @jmarcelino I note your response to @jojo 's question mentioned the need to disable channels.
                    "(you'll still need to disable channels if you gateway only supports 8 out of the 72)
                    This is also saved with lora.nvram_save() and nvram_restore()"
                    I have run the adjusted code :
                    and the LoPy connects OK.
                    Is this an issue with the gateway or are the full set of AU915 frequencies not covered by all gateways?
                    The previous firmware for the LoPy ran fine with the same gateway.
                    thanks in advance for any advice, Jose
                    Phil
                      jmarcelino @philwilkinson
                      @philwilkinson
                      You almost always need to disable channels in US915 and AU915 because most commercial gateways only support listening on 8 channels out of the possible 72.
                      In terms of TTN they have done this decision for you, see the subchannel map they propose: https://github.com/TheThingsNetwork/gateway-conf/blob/master/AU-global_conf.json
                      916.8, 917.0, 917.2, 917.4, 917.6, 917.8, 918.0, 918.2
                      But this is only true to TTN, other networks may use a different subset.
                      We plan to document this better in the near future.
                      philwilkinsonP 1 Reply Last reply Reply Quote 0
                        @jmarcelino thanks for the clear explanation.
                        It would be really useful if you could put this small section of code on the Getting Started section of Pycom's LoPy documentation for those who are connecting to TTN; the most popular LoRa network in Australia/New Zealand region. I will try and post something in The Things Network Australia Community page too.
                        If you would prefer, I can raise it through GitHub, but I suspect your ability to change the Pycom documentation is much quicker!
                        thanks again for your help Jose.
                        Also, I really enjoyed your talk on The Things Network conference
