    New firmware release 0.9.5.b1, Pymate iOS released and improved docs
    21 Posts 5 Posters 9.0k Views 5 Watching
      livius @betabrain
      @betabrain
      It depends on the application
      If the data falls only a few hours it is ok
      Or if the only requirement is not broadcast in plain text in order not to facilitate someone for so much.
      Although if AES is supported by hardware(accelerated) it actually does not make sense to use DES
        jmaralc
        Hi everyone,
        here a newbie in Pycom. About the update I have a question. It is related to the serial port. If I connect the WiPy 2.0 through the expansion board and from there by USB to the USB port in my computer. What is the serial port? I have used arduino and it provide an automatic communication through serial port despite you connected by USB to the computer.
        I need a serial port for the udpate...and I know, perhaps it is a easy question :)
        Thanks.
          livius @jmaralc
          @jmaralc
          if you attach to usb on your computer then it is installed as COM port.
          When you run updater then it provide COM port choose.
          remember that to update you must connect GND and G23 on your expanson board with simple wire.
            jmaralc @livius
            @livius Thanks for the answer.
            The problem is exactly that I connect the board with the USB and it is not installed as COM port....symply the system does not recognize it. I tried in three computer the three with linux and windows....I can use pymakr and load the examples of the tutorials but the computers are not recognizing the board. I tried also with different USB cables....any idea?
              alangman @daniel
              Hi @Daniel. I just updated my WiFy 2.0 to the latest firmware version (1. I noticed that I cannot find the RTC module.
              If I import machine and then do a dir(machine); RTC class seems to be missing.
              Best
              Alan
                jmaralc @jmaralc
                @jmaralc In deed I am noticing that I can not connect with pymakr with the serial COM, I did it this morning but through the wifi.....Could it be a defective board?
                  livius
                  No - pymakr have problem connecting by COM
                    jmaralc @livius
                    @livius And any suggestion for the board not being detected by any computer/system after connecting it with USB? Any special USB cable is needed? Could you show me a screenshot of how the device list should look like in case of a proper detection?
                    Thanks and sorry for the extra work. I was eager to work on the board....I am still but more frustrated.
                      jmaralc
                      @livius Just some good news. In Ubuntu, I manage to connect the board through the serial port (COM) with the updater and the pymakr. I notice that the port was /dev/ttyUSB0 and I could type it in the linux updater and worked fine.
                      Thanks for the help. Motivation comes up again!
                        jmaralc @jmaralc
                        May I ask which USB cable do you use to connect the board? I lost the connection again with the same cable in Ubuntu, not accessible any more.....
                          livius @jmaralc
                          @jmaralc
                          best use expansion board
                          if you have not one then use any converter - e.g. - remember about voltage 3V3
                          alt text
                            jmaralc @livius
                            @livius Thanks Livius. I am already using the expansion board (the Wipy 2.0 is plugged in).
                            Still no solution...next time today after work. I have some ideas in mind that this board could help a lot but.....well let see whether it improves or at least I manage to solve my problems
                            Cheers
                              livius
                              I work on Windows and there are no problems with updater
                              If you connect GND + GP23 by wire
                              and turn power on(or reset WiPy)
                              and you run Firmware Updater - it work for me without problem with Expansion Board
                                livius
                                if someone have not expansion board then this is i suppose helpfull
                                I attache WiPy2 to computer by UART/USB converter like this
                                alt text
