    Reading data from bluetooth device
    bluetoothgatt
    7 Posts 3 Posters 3.0k Views 3 Watching
      sam_uk
      Hi I've done a search but it's a bit unclear to me what the current state of bluetooth support is.
      Am I likely to have success connecting this device https://wiki.hackerspace.pl/projects:xiaomi-flora
      It looks like I need
      sudo apt-get install python-pip
      pip install paho-mqtt
      pip install gattlib
      Are these supported on LoPy?
      • sebS Offline
        seb
        @sam_uk said in Reading data from bluetooth device:
        The commands you list are for a full installation of python, not micropython, which does not have pip. Please check out our bluetooth api documentation for details about how to use the bluetooth radio in our modules: https://docs.pycom.io/chapter/firmwareapi/pycom/network/bluetooth/
          sam_uk @seb
          @seb
          Thanks, it seems like paho-mqtt exists in micropython, but not gattlib.
          I've found this alternate Esp2866 route so I think I'll pursue that for now.
          Sam
          • sebS Offline
            seb
            gattlib
            Our devices do support GATT directly in our firmware, you can find examples of this in the link I provided
              luc hanneuse
              Hi @seb ,
              Can you help me with the connection and those GATT instructions ?
              from network import Bluetooth
              bt = Bluetooth()
              print("searching")
              bt.start_scan(-1)
              print("connection")
              bt.connect('C47C8D643FAF') # Flower
              print("connected")
              I just succeed in a connection.
              How can I go further ?
              How can I send those 0x0038 , 0xA01F , 0x0033 , 0x0035 and read the returned value ? as describe their : https://wiki.hackerspace.pl/projects:xiaomi-flora
              • sebS Offline
                seb
                I dont have access to this specific device to test but you can do something like this:
                bluetooth = Bluetooth()
                bluetooth.start_scan(10)
                    adv = bluetooth.get_adv()
                    if adv and binascii.hexlify(adv.mac) == 'XXXXXXXXXX':
                        try:
                            print('1')
                            conn = bluetooth.connect(adv.mac)
                        except:
                            bluetooth.start_scan(5)
                            continue
                        break
                def characteristic_callback(char):
                    v = int.from_bytes(char.value(), "little")
                    print("Got new value: {}".format(v))
                services = conn.services()
                for service in services:
                    print("Service: {}".format(service.uuid()))
                    if service.uuid() == b'XXXXXXXXXXXXX':
                        characteristics = service.characteristics()
                        for characteristic in characteristics:
                            print("Characteristic: {}".format(characteristic.uuid()))
                            if characteristic.uuid() == b'XXXXXXXXXXXX':
                                characteristic.callback(trigger=Bluetooth.CHAR_NOTIFY_EVENT,
                                                        handler=characteristic_callback,
                                                        arg=None)
                You will need to replace the XXX parts with values that match your sensor
                  luc hanneuse @seb
                  @seb
                  I write this code to be able to find where it doesn't work
                  bt = Bluetooth()
                  print("searching")
                  bt.start_scan(-1)
                  print("connection")
                  conn = bt.connect('C47C8D643FAF')
                  print("connected")
                  print("before services")
                  print("services")
                                                          arg=None)
                  So, in the terminal it print
                  searching
                  connection
                  connected
                  before services
                  So it never reach the line :
                  in the page https://wiki.hackerspace.pl/projects:xiaomi-flora , it's specified that "You need to write 0xA01F to the handle 0x0033 to enable real-time data reading "
                  How can I write the value 0xA01F in the handle 0x0033 ?
                  Thanks in advance for your precious help.
