    from machine import Pin not working in WiPy 2.0
    wipy2.0pin
    6 Posts 3 Posters 1.9k Views 3 Watching
      ColombianAus
      hi there,
      I am trying to execute following code in WiPy 2, and it is throwing and exception.
      >>> p0 = Pin(0, Pin.OUT)
      ValueError: invalid argument(s) value
      trying different ways, always same outcome.
      >>> g = machine.Pin('GP9', mode=Pin.OUT, pull=None, drive=Pin.MED_POWER, alt=-1)
      NameError: name 'machine' is not defined
      another way...
      >>> p0 = Pin(0,mode=Pin.OUT)
      I am using Atom, though I did use telnet just in case Atom is playing, still same issue.
      Current version is.
      os.uname().release
      '1.17.0.b1'
      any advise is apprecaite.
      Cheers
      ColombianBootloader
        robert-hh @ColombianAus
        @colombianaus You tried not all variants. How about that one:
        p0 = Pin("P10", Pin.OUT)
          ColombianAus @robert-hh
          hey mate,
          thank you for your advise, it worked!!. so, I am using the pycom extension board, I was wondering if you know what is the pin to pin between WiPy and the extension board. i.e G23 in the extension board is P2 for WyPy 2.0 board.
          Another question, is why on the doco uses GPXX while you use PXX to use Pin class? , XX = a number. Can I use GPXX?
          Cheers
          Colombian
          • sebS Offline
            seb
            If you would prefer to use the GXX numbering you can do so like this:
            led = Pin(Pin.exp_board.G16, mode=Pin.OUT)
            From: https://docs.pycom.io/chapter/firmwareapi/pycom/machine/Pin.html#class-pinexpboard
              @colombianaus You can use both numbering variants. The P numbers are those of the development modules, while the GP numbers are those on the expansion board, carried over from the WiPy1 model.
                robert-hh @seb
                @seb Thanks for pointing that out.
