    Cellular radio firmware release (SQN3330) for both Cat-M1 and NB-IoT
    firmware
    48 Posts 18 Posters 17.1k Views 22 Watching
      bali @daniel
      @daniel I tried, i got the exact same thing unfortunately. The reason why i'm trying to update the firmware is because when i try to call lte = LTE() the GPy hangs.
        Do you have SIM card properly inserted? Can you double check?
          bali @daniel
          @daniel I double checked it, still not working. 1_1521820926411_IMG_2343 (2).jpg 0_1521820926410_IMG_2342 (2).jpg
            @bali have you ever been able to call lte = LTE() without hanging?
              bali @daniel
              @daniel with firmware 1.16.0.b1 yes, but i could never attch to cellular network because i’m on At&T and in 1.16 there was no way to configure for it.
                @bali can you try changing the baud rate from 921600 to 115200 or 345600 and maybe 57600? Just in case somehow the default baudrate is different in your board...
                  @bali OK then it seems that some of the new logic is causing your device to hang. Are you able to build a custom firmware? Then we can disable the background LTE logic and simply run the upgrade...
                    bali @daniel
                    @daniel I did try at 921600, 345600, 115200, 57600 and it failed the same way at every baud rate. Unfortunately i can't build custom firmware. If you could send me one with the LTE disabled i could try it. I ordered the GPy but was never able to the the LTE on it :(
                    • X Offline
                      Xykon administrators @bali
                      @bali Could you please check what happens if you run the following commands on your GPy?
                      from network import LTE
                      lte = LTE()
                      lte.send_at_cmd('AT+CFUN=0')
                      Christian Ehlers
                        bali @Xykon
                        @xykon hangs right after issuing lte=LTE()
                        • X Offline
                          @bali Please open a technical support request at https://pycom.io/contact as it seems your GPy is faulty.
                          Christian Ehlers
                          • N Offline
                            nathanh
                            So I think this just rendered my entire FiPy useless....
                            I upgraded the CAT-M firmware yesterday without issue to see if I could connect more successfully to Telstra and besides not getting reliable connections the upgrade process seemed to go ok.
                            Today I tried to upload the NB-IOT firmware and it got stuck at 6% for over 5 minutes exactly like the description in the instructions (https://github.com/pycom/pycom-libraries/tree/master/lib/sqnsupgrade). So I power cycled as per the instructions and now I get stuck on this:
                            <<< Welcome to the SQN3330 firmware updater >>>
                            And nothing... I have let it run for over 10 minutes and power cycled multiple times. I also notice now I lose all UART REPL command/interface after about 1-2 minutes of powering up my FiPy and it is a race against the clock to even execute the update code. If I wait a while the REPL just freezes and won't accept any input, so essentially making the device unusable.
                            And as per @bali now when I can get in quick enough and try and call lte = LTE() my device hangs. So it looks like my device that was working is no longer functioning and I followed the instructions as directed...
                              @nathanh @bali I will contact each one of you directly to help resolve your issues.
                              • V Offline
                                vigmeister @daniel
                                @daniel FWIW I seem to have run into exactly the same symptoms as @nathanh If and when a resolution is found, I would appreciate if you post it here. I would also not mind getting in on the debugging action if that would help.
                                • V Offline
                                  vigmeister @vigmeister
                                  @daniel @nathanh Additional hint from my observation. I looked at the TX buffer of the serial interface by inserting s.wait_tx_done(5000) after the s.write("ATE0\r\n") line in sqnsupgrade.py and I get "False" as the response. Will try moving downstream in the sqnsupgrade.py code later in the day and share my findings.
                                  • V Offline
                                    I tinkered a bit further and by setting the default timeout to 2000 instead of 20000 in sqnsupgrade.read_rsp , I was able to get my FiPy to get further along, but ran into @bali ‘s issue of AT+SMSWBOOT=3, 0 failed!
                                    Looks like the issues are roughly the same, but that @nathanh and I have unstable REPL on top :/
                                    • K Offline
                                      kevin
                                      Same issue here, failing with "AT+SMSWBOOT=3,0 failed!" (full log is below). If/when this issue is resolved, please post the details here.
                                      • I Offline
                                        IOAg @nathanh
                                        @nathanh Hi, were you able to recover FiPy at the end?
                                        • N Offline
                                          nathanh @IOAg
                                          @ioag said in Cellular radio firmware release (SQN3330) for both Cat-M1 and NB-IoT:
                                          Nope, @daniel asked me to send my unit back.
                                          I tried to reload the actual Pycom firmware back onto it hoping that might reset the entire device and only made it worse, I can't event load the device now, REPL just shows un-ending loops of flash errors when I turn it on.
                                          • K Offline
                                            kevin @kevin
                                            Update on my issue: I found that AT^RESET was required after flashing the board with new FW, and before attempting the sqnsupgrade procedure. After that, the upgrade seems to have completed successfully.
                                            V T 2 Replies Last reply Reply Quote 0
                                            • 1 / 3
