    W01 OEM + L01 reference board + Expansion board 2.0: ampy is possible?
    w01ampyusbexpansion boardmicropython
    13 Posts 2 Posters 2.2k Views 2 Watching
      robert-hh @formica
      @formica Which version of the firmware do you use? And is theer a difference to version 1.15.0.b1 and earlier?
      • F Offline
        formica
        MicroPython v1.8.6-621-g17ee404e on 2017-05-25; WiPy with ESP32
          robert-hh @formica
          @formica You shoud also tell the result of uos.uname()
          • F Offline
            formica @robert-hh
            (sysname='WiPy', nodename='WiPy', release='1.7.0.b1', version='v1.8.6-621-g17ee404e on 2017-05-25', machine='WiPy with ESP32')
              robert-hh @formica
              @formica The release level is quite old, so you might consider updating. I tried ampy yesterday with a board running release 1.17.3.b1, and it worked.
              You can still upload code through ftp/WiFi, as you surely know. And, since you have an expansion board, you can also use an Micro-SD card, at least for initial transfer.
              • F Offline
                formica @robert-hh
                No way robert.
                Now my uname gives (sysname='WiPy', nodename='WiPy', release='1.17.3.b1', version='v1.8.6-849-83e2f7f on 2018-03-19', machine='WiPy with ESP32') but 'ampy' is still unusable...
                Maybe I have to modify something in the boot.py?
                Regards
                  robert-hh @formica
                  @formica I just retested it with the standard build - no problem. My boot.py is empty.
                  Do you close the Atom window or other REPL windows during upload? You have to.
                  • F Offline
                    formica @robert-hh
                    Yes, nothing in the background.
                    Tried with 'ampy -p /dev/ttyUSB0 -b 115200 put myfile.py' without any result.
                      robert-hh @formica
                      @formica What is the error message?
                      • F Offline
                        formica @robert-hh
                        No error.
                        Just hangs up the terminal and I have to type CTRL-C.
                          robert-hh @formica
                          @formica does any other ampy action work, like 'ls' or 'ls /flash'?
                          and the usual brute force hammer on linux, running it with sudo?
                          • F Offline
                            formica @robert-hh
