Guru meditation error
  • At random intervals I notice that my wipy/pytrack board reboots. I finally managed to get the core dump (this is another core dump than the one I posted yesterday when doing FTP)
    The error I get is below.
    How do I interpret this to find where the problem is in my code?
    Guru Meditation Error: Core  1 panic'ed (Unhandled debug exception)
    Debug exception reason: BREAK instr
    Register dump:
    PC      : 0x400803c0  PS      : 0x00060036  A0      : 0x00000000  A1      : 0x3ffe94d0
    A2      : 0x3ffe972c  A3      : 0x3ffdd82c  A4      : 0x00000000  A5      : 0x0000ff00
    A6      : 0x00ff0000  A7      : 0xff000000  A8      : 0x00060023  A9      : 0x00000000
    A10     : 0x00000004  A11     : 0x7fffffff  A12     : 0x80089c57  A13     : 0x3ffd93d0
    A14     : 0x00000003  A15     : 0x00060023  SAR     : 0x0000001e  EXCCAUSE: 0x00000001
    EXCVADDR: 0xffffffd0  LBEG    : 0x40099934  LEND    : 0x40099962  LCOUNT  : 0x00000000
    Backtrace: 0x400803c0:0x3ffe94d0 0x7ffffffd:0x00000000
    Also, after rebooting: the main.py seems not to work anymore
    Unhandled exception in callback handler
      File "main.py", line 370, in launchWriters
    NameError: name 'dispatcher' is not defined
    If I reset the board (via the button), It starts up again and runs normally until the next random crash (sometime a few minutes later, sometimes hours later).
    I can provide the entire core dump
    system: (sysname='WiPy', nodename='WiPy', release='1.17.3.b1', version='v1.8.6-849-83e2f7f on 2018-03-19', machine='WiPy with ESP32')
  • Hi,
    Im sorry if I accidentally ignored your coredump post. You notice that this post is from 2018 and that there is no added value in solving this issue anymore right?
    Now, let me start by mentioning it is never okay for the controller to present a coredump and they should be avoided at all costs.
    The issue with these coredumps is that they can have a variety of reasons, and that debugging them takes a lot of effort, as I need to know the exact firmware version used (incl development board version), the coredump parameters (top section) and it is very useful to see the python code and learn about its workings and when it breaks (if it breaks at the same location every time). Even then, it is still a wild goose chase. There can be many reasons for a coredump (including inadequate power supply, incorrect use of threading, firmware errors etc.)
    What we can do, is provide you with better tools to research the coredump and I will be working on that. Note that I have already started a documentation page here: https://docs.pycom.io/advance/coredump/, but I want to do better. Please let me know how we can improve the situation!
    Best,
  • Why is it that admins and official tech support @ pycom never really answer these questions? Do they not understand that many people get these same problems and then leave in disgust and eventually abandon their projects or find another chip? Or do they just not care?
  • I'm getting a very similar issue, at least for me it appears to be an issue with multi-threaded code. I've tried writing my code both with and without threading and I only have this issue on the threaded version.
    I'll try to put together an MCVE if I have time so that hopefully this can get fixed.
  • @seb
    Found anything interesting?
    Is there a good resource that explains how I can decode it myself. This is something I haven't done before.
  • @seb
    Register dump:
    KE4AABYAAABsAQAA
    KNj9PxCU/j/wl/4/
    QJT+P5CX/j9vWdkAlE/8P5RP/D8o2P0/jE/8PxQAAAAUYPw/FGD8PyjY/T8AAAAA
    BQAAAPSD/j9NUFRocmVhZAABwKgEAgMAAQAAAPCX/j8AAAAAIAgGAAUAAAACAAAA
    AAAAACyX/j8AAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA
    r1dAPwAAAAAUoQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAi0ADw==
    AQAAAMADCEA2AAYAAAAAANCU/j8sl/4/LNj9PwAAAAAA/wAAAAD/AAAAAP8jAAYA
    AAAAAAQAAAD///9/V5wIgNCT/T8DAAAAIwAGAB4AAAABAAAA0P///zSZCUBimQlA
    AAAAAFecCIDQk/0/0DEIQATy+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAATy+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAP4AAADAk/4/AAAAACSlCIBnRQ+A4JX+P+CW/j/EMpU/
    2VQPgDCV/j8YpUA/eK5APwAAAABgAAAAAAAAAAAAAADdRA+AUJX+PwIAAADQMpU/
    AgAAAAIAAAABAAAALhMAAHQOD4Bwlf4/xFQPQAIAAAAA95Q/AgAAAAAAAABQz0A/
    3A4PgKCV/j9cr0A/AgAAAAAAAADIMpU/5F/8PwEAAAAAAAAA0DKVPwEAAAC2CgAA
    aMIPgMCV/j8BAAAAAAAAAAAAAADQMpU/AQAAAF4UAABnRQ+A4JX+PwgAAACyypU/
    zDKVPzQzlT8AAAAAAQAAAHQOD4CAlv4/gF78P4Be/D/glv4/gAiVP2dFD4Dglf4/
    4Jb+P8QylT8QCpU/KDOVP+/KlT+xAAAApaWlpaWlpaWlpaWlpaWlpXQOD4CAlv4/
    gF78P4Be/D/2tA+AG8qVPw8AAAAIAAAANDOVPwAAAAAAAAAAoDKVP/gylT/0MpU/
    DgAAAPj3lD8AAAAAAAAAAMwylT8AAAAAMP///7PKlT9+sg+AwJb+P7ANlT8AAAAA
    AsqVPwAAAAAAAAAAAAAAAAAAAAD495Q/AAAAAAAAAACgMpU/hAAAAA8AAACAlv4/
    zNANgOCW/j8AAAAA4PeUPwAAAAD495Q/CJf+P2CX/j8AAAAAcJf+P+D3lD8AAAAA
    AAAAAAAAAADM0A2A4Jb+PwAAAADg95Q/IwAGAAAAAAAEAAAA////fwAAAAAAAAAA
    AAAAAAAAAAAAAAAAcJf+P+D3lD8AAAAAbbIPgIBe/D+AXvw/4Jb+P0CX/j8AEAAA
    4PeUPwAAAAAAAAAAAAAAAOD3lD8AAAAABAAAAP///38AAAAAkJf+PwAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEAAAAAAJyX/j8AAAAA
    gAAAAAAAyELNzMw9AAB6RADESLKAlhjAMKGzNZW/1nYAwJ93NCXsugAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=
    QEX9P8BD/T84Rf0/
    wEP9P9BE/T9DQ5ARvEr9PzBP/D9ARf0/KE/8PxkAAABhqy+0R/AlA0BF/T8AAAAA
    AAAAADxB/T9JRExFAEBGvI5As6mzCDQAAAAAADhF/T8AAAAAIQAGAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADJc9w==
    xDIIQMQ6FEAwBgYA/LIIgIBE/T8gAAAAAQAAAAAAAAC0kPw/HFH8P8RO/D/QkPw/
    MzMzAwAAAABQDwAAAAAAAFDW+z8DAAAAIwAGAAoAAACYXPw/AAAAAOBlDkAcZg5A
    AAAAAL00CEBQ1vs/SMAIQESf+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAABQ1vs/AwAAACMABgAAAAAAoET9PwAAAAAAAAAA
    AAAAALSQ/D8cUfw/xE78PwAAAADQRP0/AAAAAAAAAAAEGfw/AAAAAAAAAAAAAAAA
    AQAAAAAAAAAEAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANxE/T8AAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==
    tEr9PzBJ/T+sSv0/
    MEn9P0BK/T/LaPHHME/8P0hF/T+0Sv0/KE/8PxkAAADGuxumk4A0c7RK/T8AAAAA
    AAAAALBG/T9JRExFALycrqaYoTWirL4AAQAAAKxK/T8AAAAAIwAGAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAILGXw==
    xDIIQMQ6FEAwBAYA/LIIgPBJ/T8gAAAAAQAAACAAAAC0kPw/IFH8P8RO/D/wkPw/
    AQAAAAAAAAD///9/V5wIgDBq/j8DAAAAIwAGAAAAAADwSf0/IAAAAAAAAAAAAAAA
    AAAAAL00CEAwav4/SMAIQLSk+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAAEEr9PwAAAAABAAAA
    AQAAAAQZ/D8gUfw/xE78PwAAAABASv0/AAAAAAAAAAAEGfw/AAAAAAAAAAAAAAAA
    AQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAExK/T8AAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=
    pE39P3A1/T9QN/0/
    cDX9P/A2/T+DWdkAUNX9P2Q//T+kTf0/FE/8PwcAAAAYmf0/GJn9P6RN/T8Qmf0/
    EgAAAFQp/T90aVQAdADYAU/dtl/w/v0A////f1A3/T8AAAAAIQAGABIAAAABAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKav1w==
    xDIIQCSlCEAwBAYASdIVgDA2/T/smP0/wDb9PziZ/T8AAAAAQJn9PwAAAAAkpQiA
    EDb9PwAAAABkAAAAHFH8PwAAAAAEGfw/AAAAABAAAABkkfo/AAAAAC29FUA2vRVA
    AAAAAL00CEAAAAAASMAIQGSR+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAEA2/T8gNv0/DAAAAEjACECNVxWAcDb9P8ST/D/ANv0/
    AAAAAB9Z2QAUTv0/AAG8P2QAAAAAGAAAAQAAAAAAAACYVxWAgDb9PwAAAACIOAhA
    Y+IUgKA2/T/Ek/w/wDb9P2PiFICgNv0/xJP8P8A2/T9kAAAAH1nZAPb///8BAAAA
    AAAAAMA2/T/86hVAAAAAAGCa/D9YVhVAAAAAABxR/D8AAAAA8Db9PwAAAAAAAAAA
    AAAAAAAAAAD8Nv0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    SNX9P1Bs/j/ob/4/
    UGz+P4Bv/j8EWtkAwNb9P6xN/T9I1f0/FE/8PxQAAACQdvs/kHb7P0jV/T8AAAAA
    BQAAAOxb/j9NUFRocmVhZABsAG8AZwAAAQAAAOhv/j8AAAAAIQAGAAUAAAAAAAAA
    AAAAABxv/j8AAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA
    xDIIQGyyCEAwBAYAQdUNgBBt/j8EWtkAIFH8PwQZ/D8BAAAAAwAAAEAAAABssgiA
    8Gz+PwEAAAAEWtkASNX9PwEAAAD+AAAAAAAAAB4AAAC10Q2A0Gz+PxibCUAjmwlA
    AAAAAL00CEABAAAASMAIQPTJ+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAADRg/D8AAAAAAQAAAAAAAAA6OhCAMG3+P5YAAADkX/w/
    PF78P/////8DAAAAQAAAAFhED4BQbf4/AAB6RAAAAAABAAAAAQAAANhs/j9Abf4/
    dA4PgHBt/j+kSkE/AQAAAAEAAAABAAAAAAAAAEYMAADcDg+AkG3+P6RKQT8BAAAA
    AAAAALTslD8PAAAAUG3+P2jCD4Cwbf4/AQAAAAAAAAAAAAAAtOyUPwEAAAAWDQAA
    Z0UPgNBt/j8IAAAAfsiVP6zslD8BAAAAAAAAAAEAAAB0Dg+AcG7+P4Be/D+AXvw/
    0G7+PwAAAABnRQ+A0G3+P9Bu/j8OAAAA5OyUPwAAAADg7JQ/AAAAAAUAAAAAAAAA
    paWlpaWlpaV0Dg+AcG7+P4Be/D+AXvw/9rQPgNhu/j8OAAAAAwAAAPDslD8AAAAA
    AAAAAJDslD/k7JQ/4OyUPw0AAAAYMZU/AQAAAAAAAACs7JQ/AAAAADD///9/yJU/
    frIPgLBu/j+gDZU/AAAAAKLHlT8AAAAAAAAAAAAAAAAAAAAAGDGVPwAAAAAAAAAA
    kOyUP1wAAAAOAAAAcG7+P8zQDYDQbv4/AAAAAAAxlT8AAAAAGDGVP/hu/j9Qb/4/
    AAAAAGBv/j8AMZU/AAAAAAAAAAAAAAAAzNANgNBu/j8AAAAAADGVPyMABgAAAAAA
    BAAAAP///38AAAAAAAAAAAAAAAAAAAAAAAAAAGBv/j8AMZU/AAAAAG2yD4CAXvw/
    gF78P9Bt/j8wb/4/ABAAAAAxlT8AAAAAAAAAAAAAAAAAMZU/AAAAAAQAAAD///9/
    AAAAAIBv/j8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAABAAAAAACMb/4/AAAAAIAAAAAAABZDmpkZPgAAekQAxEiygJYYwDChszWVv9Z2
    AMCfd+JqHLsAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAA=
    uNb9P1CA/j/sg/4/
    UID+P4CD/j9GWtkAHE/8P1DV/T+41v0/FE/8PxQAAACQdvs/kHb7P7jW/T8AAAAA
    BQAAAPBv/j9NUFRocmVhZAAANwA5ADQAAQAAAOyD/j8AAAAAIQAGAAUAAAAAAAAA
    AAAAAByD/j8AAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAqWlpQ==
    xDIIQGyyCEAwDAYAQdUNgBCB/j9GWtkAIFH8PwQZ/D8BAAAAiIVAP1h3QD9ssgiA
    8ID+PwEAAABGWtkAuNb9PwEAAAD+AAAAAAAAAB4AAAC10Q2A0ID+PyCoDkBMqA5A
    oG8CAL00CEABAAAASMAIQPTd+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAADRg/D8AAAAAAQAAAAAAAAA6OhCAMIH+P8gAAADkX/w/
    AAAAAAEAAACIhUA/WHdAP1hED4BQgf4/AAB6RAAAAAABAAAAAQAAAIzPlT89AAAA
    dA4PgHCB/j+kSkE/AQAAAAEAAAABAAAAAAAAAEYMAADcDg+AkIH+P6RKQT8BAAAA
    AAAAAJT7lD8JAAAAUIH+P2jCD4Cwgf4/AQAAAAAAAAAAAAAAlPuUPwEAAAAWDQAA
    Z0UPgNCB/j8IAAAAps6VP4z7lD+o+5Q/AAAAAGCC/j90Dg+AcIL+P4Be/D+AXvw/
    0IL+PwAAAABnRQ+A0IH+P9CC/j8MAAAAvPuUPwAAAAC4+5Q/AAAAAAUAAAAAAAAA
    paWlpaWlpaV0Dg+AcIL+P4Be/D+AXvw/9rQPgNiC/j8MAAAAAwAAAMj7lD8AAAAA
    AAAAAHD7lD+8+5Q/uPuUPwsAAAA4MZU/AQAAAAAAAACM+5Q/AAAAADD///+nzpU/
    frIPgLCC/j/ADZU/AAAAACLOlT8AAAAAAAAAAAAAAAAAAAAAODGVPwAAAAAAAAAA
    cPuUP1QAAAAMAAAAcIL+P8zQDYDQgv4/AAAAACAxlT8AAAAAODGVP/iC/j9Qg/4/
    AAAAAGCD/j8gMZU/AAAAAAAAAAAAAAAAzNANgNCC/j8AAAAAIDGVPyMABgAAAAAA
    BAAAAP///38AAAAAAAAAAAAAAAAAAAAAAAAAAGCD/j8gMZU/AAAAAG2yD4CAXvw/
    gF78P9CB/j8wg/4/ABAAACAxlT8AAAAAAAAAAAAAAAAgMZU/AAAAAAQAAAD///9/
    AAAAAICD/j8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AQAAAAAAAACMg/4/AAAAAIAAAAAAAEhDzcxMPgAAekR4/1Yy2w9JwHj/VjKD+aJW
    AMCfV91L5bkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAA
    XD/9P/A9/T9UP/0/
    8D39P/A+/T+AWdkArE39PxxP/D9cP/0/FE/8PxQAAAD8dvs//Hb7P1w//T8AAAAA
    BQAAAFg3/T9TZXJ2ZXJzAAAAAAAAAAAAAQAAAFQ//T8AAAAAIQAGAAUAAAAAAAAA
    HNv7PwAAAACINA1AAAAAAAsAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA
    xDIIQGyyCEAwAAYAH84NgLA+/T+AWdkAIFH8PwQZ/D8BAAAAHwAAAKyv/T9ssgiA
    kD79PwEAAACAWdkAXD/9PwEAAAD+AAAAIwAGAAQAAACbig6AcD79PzSZCUBimQlA
    /////700CEABAAAASMAIQGSZ+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAFw//T8BAAAA/gAAACMABgAAAAAA0D79PwAAAAABAAAA
    +ExAPwEAAAAfAAAArK/9PwAAAADwPv0/AAAAAAAAAAAAAAAAAQAAAM5W/D8AAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA/D79PwAAAAAAAAAAAAAAAAAAAAAAAAAA
    JEz9P2Bf/T+4YP0/
    YF/9P1Bg/T8AAAAACE/8PwhP/D8kTP0/AE/8Pw8AAADwVf0/8FX9PyRM/T/oVf0/
    CgAAALxW/T9UbXIgU3ZjAArV4F8MQVQAAAAAALhg/T8AAAAAIQAGAAoAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHU+ew==
    xDIIQJm+CEAwAAYAAAAAACBg/T8AAAAAAAAAAAAAAAAsUfw/JFH8PwkAAACZvgiA
    AGD9PwAAAAAEGfw/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAL00CEAAAAAASMAIQMS6+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAMS6+j8AAAAAAAAAAAAAAAAAAAAAUGD9PwAAAAAAAAAA
    AAAAAAAAAABcYP0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAA=
    5Cf9PzAm/T/cJ/0/
    MCb9P3An/T+Ua5HeqHn7P3gi/T/kJ/0/pE78PwEAAABAVf0/QFX9P+Qn/T84Vf0/
    GAAAAOAj/T9pcGMxAIQfm79hxtPs3IcAAQAAANwn/T8AAAAAIQAGABgAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEw23Q==
    xDIIQDIUCEAwBAYAJKUIgPAm/T8BAAAA/////yBR/D8BAAAABBn8PyADBgAyFAiA
    0Cb9P+AA8D8BAAAAuBj8PwEAAAD+AAAAIwAGAAAAAADwJv0/AQAAAAAAAAAAAAAA
    AAAAAL00CEABAAAASMAIQOSB+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAD8HAiAECf9PxRV/T8AAAAA
    IFH8PwEAAAAEGfw/IAMGAAAAAABQJ/0/BE78PwAAAAAAAAAAQhUAAAAAAAAgAwYA
    /////wAAAAAETvw/8E38P2BV/T8AAAAAFFX9PwAAAAAAAAAAcCf9PwAAAAAAAAAA
    9EoIQAEAAAAAAAAAAAAAAGESCICAff4/AQAAAAAAAAAAAAAAAAAAAHwn/T8AAAAA
    oHn7P5D3/T9I+f0/
    kPf9P+D4/T8AAAAAbBr+P+wn/T+gefs/pE78PwIAAABsefs/bHn7P6B5+z9kefs/
    FwAAAEzp/T9idENvbnRyb2xsZXIAAAAAAAAAAEj5/T8AAAAAIQAGABcAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAG7N2g==
    xDIIQCSlCEAwAAYAEWwIgFD4/T9Aefs/sPj9P4x5+z8AAAAAlHn7PwAAAAAkpQiA
    MPj9PwAAAAD/////HFH8PwAAAAAEGfw/AAAAABsAAAC0+vo/FAwAADSZCUBimQlA
    /////700CEAAAAAASMAIQFRT+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAABo/fo/zJP7PwAAAAC7EBqAkPj9P0B5+z+w+P0/
    AAAAAFUVAAD+AAAAAAAAAP////+Q+P0/AQAAALD4/T+Mefs/AAAAAJR5+z8BAAAA
    AAAAALD4/T+0Q/w/2EP8P/////8AAAAAFgAAAP///38AAAAA4Pj9PwAAAAAAAAAA
    AQAAAAAAAAAAAAAAAAAAAAAAAADUQ/w/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAADs+P0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAA=
    ZBr+P8AY/j9cGv4/
    wBj+P/AZ/j/d0bJoNCv+P6h5+z9kGv4/pE78PwMAAAB4/P0/ePz9P2Qa/j9w/P0/
    FgAAAGAQ/j9oY2lIb3N0VADU4YtKhmEAAAAAAFwa/j8AAAAAIQAGABYAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJVimg==
    xDIIQCSlCEAwAgYADFgZgIAZ/j9M/P0/wBn+P5j8/T8AAAAAoPz9PwAAAAAkpQiA
    YBn+PwAAAAD/////HFH8PwAAAAAEGfw/AAAAABkAAAAAAAAAAAAAADSZCUBimQlA
    AAAAAL00CEAAAAAASMAIQGR0+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAEyf/D8AIAAAACEAAAAAAAAAAAAAwBn+PwSf/D8AAAAA
    AAAAAFUVAAD+AAAAAAAAAP/////AGf4/DJ/8PwAAAACY/P0/AAAAAGD9/T8AAAAA
    AAAAAPAZ/j8AAAAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA/Bn+PwAAAAAAAAAAAAAAAAAAAAAAAAAA
    LCv+P5Ap/j8kK/4/
    kCn+P8Aq/j+EX/5KNDP+P2wa/j8sK/4/pE78PwQAAAA8Hf4/PB3+Pywr/j80Hf4/
    FQAAACgh/j9oY2lINFQAnwtntuWe97YAAAAAACQr/j8AAAAAIQAGABUAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIZvkQ==
    xDIIQCSlCEAwAgYAiOEZgFAq/j8QHf4/kCr+P1wd/j8AAAAAZB3+PwAAAAAkpQiA
    MCr+PwAAAAD/////HFH8PwAAAAAEGfw/AAAAAAAAAAAAAAAAAAAAADSZCUBimQlA
    AAAAAL00CEAAAAAASMAIQDSF+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAA4AAAAMn/w/Drf7P/8AAAAAAAAAkCr+P1Si/D8AAAAA
    AAAAAFUVAAD+AAAAAAAAAP////+QKv4/VKL8PwAAAABcHf4/AAAAAPQe/j8BAAAA
    AAAAAMAq/j8AAAAAAAAAAAAAAAAAAAAADrf7P/8AAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAzCr+PwAAAAAAAAAAAAAAAAAAAAAAAAAA
    LDP+P9BT/j9oVf4/
    0FP+PwBV/j/erP08AH77PzQr/j8sM/4/pE78PwUAAADgL/4/4C/+Pywz/j/YL/4/
    FAAAAGxD/j9idHVUAAt2of6AkjFVkmUAAAAAAGhV/j8AAAAAIQAGABQAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAESBlw==
    xDIIQCSlCEAwDAYA5HAYgJBU/j+0L/4/0FT+PwAw/j8AAAAACDD+PwAAAAAkpQiA
    cFT+PwAAAAD/////HFH8PwAAAAAEGfw/AAAAACAAAAAAAAAAAAAAAJxJGUCqSRlA
    BwAAAL00CEAAAAAASMAIQHSv+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAQAAADgV/4/hAL9PwAAAAAAAAAA0FT+P0ii/D9sekI/
    AAAAAFYVAAD+AAAAAAAAAP/////QVP4/mHEYQGx6Qj8AMP4/AAAAAOgw/j8AAAAA
    AAAAAABV/j8AAAAAAAAAAAIAAADoePs/CgAAAHw4CEAAFwAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADFX+PwAAAAAAAAAAAAAAAAAAAAAAAAAA
    +H37P8AO/j9YEP4/
    wA7+P/AP/j9zW7NxHE/9PzQz/j/4ffs/pE78PwYAAADse/s/7Hv7P/h9+z/ke/s/
    EwAAAFwE/j9CdGNfdGFzawCnT4z6m00AAAAAAFgQ/j8AAAAAIQAGABMAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD/XIw==
    xDIIQCSlCEAwAAYAoNcXgIAP/j/Ae/s/wA/+Pwx8+z8AAAAAFHz7PwAAAAAkpQiA
    YA/+PwAAAAD/////HFH8PwAAAAAEGfw/AQAAACAAAAACAAAA2Ff+PzSZCUBimQlA
    /////700CEAAAAAASMAIQGRq+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAANhX/j8THwAA/gAAACAEBgAAAAAAwA/+Pwyd/D8AAAAA
    AAAAAFYVAAAAAAAAAAAAAP/////AD/4/DJ38PwAAAABQeEI/AAAAACx8+z8AAAAA
    AAAAAPAP/j8AAAAAAAAAAAFJAgAYV/4/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA/A/+PwAAAAAAAAAAAAAAAAAAAAAAAAAA
    FE/9P5Cr/T9Irf0/
    kKv9P+Cs/T8DPNcnVLP9PwB++z8UT/0/pE78PwUAAAAgm/0/IJv9PxRP/T8Ym/0/
    FAAAAEyh/T9ldmVudFRhc2sAvtxfICUAAAAAAEit/T8AAAAAIQAGABQAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIBZKw==
    xDIIQCSlCEAwCAYA6DkUgFCs/T/0mv0/kKz9P0Cb/T8AAAAASJv9PwAAAAAkpQiA
    MKz9PwAAAAD/////HFH8PwAAAAAEGfw/AQAAAAAAAAAwrP0/PKz9PzSZCUBimQlA
    AAAAAL00CEAAAAAASMAIQFQH+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAMCoBAH///8AwKgEATCupC0AAAAAkKz9P2yQ/D8AAAAA
    AAAAAGNnBgD+AAAAAAAAAP////+QrP0/bJD8PwAAAABAm/0/AAAAAPic/T8AAAAA
    AAAAAOCs/T8AAAAAAAAAABAAAABgAwiOhKYBPywJvD9AAAAAAAAAAHwQ/T///z+z
    /gAAAPgKvD9w5wMA9Aq8PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAADsrP0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAA=
    TLP9P6DK/T+4zP0/
    oMr9P1DM/T/8acAAoFH7PxxP/T9Ms/0/pE78Pw4AAAB8rf0/fK39P0yz/T90rf0/
    CwAAALy0/T9JUlFzAKWlpaWlpaWlpaUAAQAAALjM/T8AAAAAIQAGAAsAAAAAAAAA
    AAAAAOzL/T8AAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA
    xDIIQCSlCEAwAgYAT4AOgGDL/T9Qrf0/AMz9P5yt/T8AAAAApK39PwAAAAAkpQiA
    QMv9PwEAAAD/////IFH8PwEAAAAEGfw/AAAAAAYAAACS1JU/5K39PzSZCUBimQlA
    /////700CEABAAAASMAIQMQm+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAHqADoCAy/0/wEKVP1CxQD/M0A2AoMv9Pwhd/D8AAAAA
    AAAAABRmwAAAAAAAAAAAAP////+gy/0/CEMOQAAAAAAAAAAAIMz9P8jL/T8gzP0/
    AAAAADDM/T/8XPw/AAAAAAAAAAAAAAAAzNANgKDL/T8AAAAAAAAAAIBe/D8AAAAA
    CgAAAP///38AAAAAAAAAAAAAAAAAAAAAAAAAADDM/T/8XPw/AAAAAG+ADoCAXvw/
    gF78PwAAAAAAzP0/ABQAAAhDDkDAQpU/AAAAAAAAAACAXvw/AAAAAAoAAAD///9/
    AAAAAFDM/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAABAAAAAABczP0/AAAAAIAAAAAAAKBAAOoDQAAAIEFkAABL+Ci8v4b/PDVOJi4/
    AMCfP/I2pToAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAA=
    mFH7PwBQ+z+QUfs/
    AFD7PzBR+z9qrsXTzBz9P1Sz/T+YUfs/pE78PwQAAAAIR/s/CEf7P5hR+z8AR/s/
    FQAAAJRH+z9wbVQAUU6VezP89OEXWo4A////f5BR+z8AAAAAIQAGABUAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPR3+Q==
    xDIIQCSlCEAwBAYAyT0SgMBQ+z/cRvs/AFH7PyhH+z8AAAAAMEf7PwAAAAAkpQiA
    oFD7PwEAAAD/////IFH8PwEAAAAEGfw/IwAGAAAAAAAzMzMDvTQIQDSZCUBimQlA
    /////700CEABAAAASMAIQKSr+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAADoAwDQUPs/PHf8PyAABgAAAAAAAFH7PzB2/D90iUE/
    AAAAAARZ2QAwdvw/dIlBP/////8AAAAAAAAAAAAAAACYUfs/AQAAAP4AAAABAAAA
    AAAAADBR+z8AAAAAAAAAAAYAAAADAAAAAAAAAAAAAABsd/w/MHb8PywBAAAAAAAg
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPFH7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
    xBz9PzAb/T+8HP0/
    MBv9P1Ac/T8+eL7qYNj7P6BR+z/EHP0/pE78PwMAAAAkU/0/JFP9P8Qc/T8cU/0/
    FgAAAMAQ/T9lc3BfdGltZXIAFB/KKREAAAAAALwc/T8AAAAAIQAGABYAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGyOkg==
    xDIIQCSlCEAwCAYATSMNgPAb/T/4Uv0/AAAAAERT/T8AAAAA+FL9PwAAAAAkpQiA
    0Bv9PwAAAAD/////HFH8PwAAAAAEGfw/XD/9PwAAAAD//z+zAAAAADSZCUBimQlA
    /////700CEAAAAAASMAIQMR2+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAABxR/D8AAAAABBn8P1w//T8AAAAAMBz9P6xN/D+0Tfw/
    AAAAAElZ2QAqIAIAXD/9P/////8wHP0/yFj7P7RN/D9EU/0/AAAAAPhS/T8AAAAA
    AAAAAFAc/T8AAAAAAAAAAAAAAAAAAAAAtE38PwAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAABcHP0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAA
    WNj7P7DW+z9Q2Ps/
    sNb7P/DX+z/CTRtVoNn9P8wc/T9Y2Ps/pE78PwIAAADowfs/6MH7P1jY+z/gwfs/
    FwAAAFTI+z93aWZpAKTDvEt7T8Ejq5EAAAAAAFDY+z8AAAAAIQAGABcAAAABAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAOAr2Q==
    xDIIQCSlCEAwBgYAnGkSgHDX+z+8wfs/wNf7PwjC+z8AAAAAEML7PwAAAAAkpQiA
    UNf7PwAAAAD/////HFH8PwAAAAAEGfw/CgABBBwAAAC9FxKAUNf7PzSZCUBimQlA
    /////700CEAAAAAASMAIQGQy+T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAGhqEoCA1/s/BAAAAKDqEEAAAAAAsNf7P8C3/D+Ad/w/
    AAAAAEtZ2QDAt/w/gHf8P/////+w1/s/wLf8P4B3/D8QAAAAxAAAAABU+z/kKPw/
    AAAAAPDX+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAA
    GgAAAGNqEkBYi0E/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPzX+z8AAAAA
    mNn9PzCo/j/0q/4/
    MKj+P5Cr/j95WdkArFL8P2DY+z+Y2f0/pE78PxQAAADAUvw/FGD8P5jZ/T8MYPw/
    BQAAAPiX/j9NUFRocmVhZABsAG8AZwAAAQAAAPSr/j8AAAAAIQAGAAUAAAABAAAA
    AAAAACyr/j8AAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA
    xDIIQCSlCEAwDAYAmNENgPCo/j/oX/w/AAAAADRg/D8AAAAAAAAAAAAAAAAkpQiA
    0Kj+PwEAAAD/////IFH8PwEAAAAEGfw/BQAAAB4AAAD//z+zAAAAABibCUAjmwlA
    AAAAAL00CEABAAAASMAIQAQG/D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAQZ/D8FAAAA/gAAAAEAAABUsw+AMKn+P+Rf/D8BAAAA
    AAAAAH9Z2QAAAAAAAAAAAP////8AAAAAAQAAAAAAAAA0YPw/AAAAAAEAAAAAAAAA
    3UQPgFCp/j/kX/w/cEWVPwAAAAABAAAAAQAAAJ4UAAB0Dg+AcKn+PySzD0ABAAAA
    AQAAAJAwlT8AAAAAIwAGANwOD4Cgqf4/mM5APwEAAADcDg+AoKn+PxibCUAjmwlA
    AAAAAHBFlT8BAAAAHgUAACW6D4DAqf4/AAAAAAAAAAAAAAAAcEWVPwEAAACqFAAA
    Z0UPgOCp/j9sRZU/hdCVP2xFlT8hAAAAAwAAAAEAAAB0Dg+AgKr+P4Be/D+AXvw/
    4Kr+P1ALlT9nRQ+A4Kn+P+Cq/j9kRZU/UAuVP8RFlT/J0JU/kgAAAAUAAAAAAAAA
    paWlpaWlpaV0Dg+AgKr+P4Be/D+AXvw/9rQPgBnQlT8OAAAABAAAAMRFlT8AAAAA
    AAAAAEBFlT+URZU/kEWVPw0AAADo+JQ/AQAAAAAAAABkRZU/AAAAADD///+QMJU/
    frIPgMCq/j/QDZU/AAAAAALQlT8AAAAAAAAAAAAAAAAAAAAA6PiUPwAAAAAAAAAA
    QEWVP4AAAAAOAAAAgKr+P8zQDYDgqv4/AAAAAND4lD8AAAAA6PiUPwir/j9gq/4/
    AAAAAHCr/j/Q+JQ/AAAAAAAAAAAAAAAAzNANgOCq/j8AAAAA0PiUPyMABgAAAAAA
    BAAAAP///38AAAAAAAAAAAAAAAAAAAAAAAAAAHCr/j/Q+JQ/AAAAAG2yD4CAXvw/
    gF78P+Cp/j9Aq/4/ABAAAND4lD8AAAAAAAAAAAAAAADQ+JQ/AAAAAAQAAAD///9/
    AAAAAJCr/j8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAABAAAAAACcq/4/AAAAAIAAAAAAAMhCzczMPQAAekR4/1Yy2w9JwHj/VjKD+aJW
    AAAAAA==
    pFL8PzCU/T+8l/0/
    MJT9P1CX/T9/WdkArE78P6DZ/T+kUvw/pE78PxQAAAAUYPw/tNn9P6RS/D8MYPw/
    BQAAAMBn/T9NaWNyb1B5AAAAAAAAAAAAAQAAALyX/T8AAAAAIQAGAAUAAAAAAAAA
    AAAAADxe/D8AAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAA==
    xDIIQCSlCEAwDgYAmNENgPCU/T/oX/w/AAAAADRg/D8AAAAAAAAAAAAAAAAkpQiA
    0JT9PwEAAAD/////IFH8PwEAAAAEGfw/BQAAABoAAAAwlf0/f1nZAAGeCUARnglA
    /////700CEABAAAASMAIQMTx+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAP////+9NAhAAQAAAEjACEBI1Q2AMJX9P+Rf/D8BAAAA
    AAAAAH9Z2QAAAAAAAAAAAP////8AAAAAAAAAAAAAAAA0YPw/AAAAAAEAAAAAAAAA
    stUNgFCV/T8BAAAA5F/8PwAAAAABAAAAAwAAACMABgB42g2AcJX9Pzxe/D/MIUA/
    wJX9PwAAAAAAAAAAAAAAAJbcDYCglf0/wJX9P5IeQD+W3A2AoJX9P8CV/T+SHkA/
    AAAAAAAAAAAAAAAAAgAAAODMDYDAlf0/AAAAAAAAAAAGAAAAAAAAACIAAAAIAAAA
    AAAAAACW/T8Qlv0/LBr8PyAAAAAAAAAA4PmUPwgAAAAAAAAAAJb9PxCW/T8AAAAA
    kJX9PwAAAAAAAAAApFr8PwAAAABQl/0/AAAAAAAAAAABAAAApaWlpaWlpaWlpaWl
    nwIAACEABgAgQk9PVC5QWQD//////2Jvb3QucHkA////////////////////////
    //////////////////////+lpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWl
    paWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaXEMghA6MkNQDAABQAAAAAA
    UJf9PwAAAAAA//////////////////////////////////////////8AAAAAAAAA
    AAAAAAEAAAAAAAAA/////wAAAAD/////////////////////xUITgQAAAAAyAAAA
    AgEAAAAAAAAAABkAAJb9PwAAKAAAAAAAAQAAAAiX/T/Qlv0/AAAAAAAAAAAAAAAA
    AQAAAExU/D8AAAAAYR1APwAAAAAAAAAAAAAAAAAAAAAAAAEAAAAAAFyX/T8AAAAA
    gAAAAACAO0UAAEBAAAB6RADESLKAlhjAMKGzNZW/1j4AwLc/AJaZugAAAAAAAAAA
    cCL9P+Ag/T9oIv0/
    4CD9PwAi/T8N2Sdf7Cf9P6xO/D9wIv0/pE78PwEAAADoVP0/6FT9P3Ai/T/gVP0/
    GAAAAGwe/T9pcGMwAN7bVrWuBUWam44AAAAAAGgi/T8AAAAAIQAGABgAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACfgUQ==
    xDIIQCSlCEAwAgYA/BwIgKAh/T+8VP0/AAAAAAhV/T8AAAAAvFT9PwAAAAAkpQiA
    gCH9PwAAAAD/////HFH8PwAAAAAEGfw/FwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAL00CEAAAAAASMAIQHR8+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAABxR/D8AAAAABBn8PxcAAAAAAAAA4CH9PwBO/D8AAAAA
    AAAAAEgUAAD+AAAAFwAAAP////8AAAAAAE78P/BN/D8IVf0/AAAAALxU/T8AAAAA
    AAAAAAAi/T8AAAAAAAAAAPRKCEAAAAAAAAAAAAAAAADFEQiAYDz+P4xO/D+UTvw/
    AAAAAAAAAAAMIv0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAA=
    Rebooting...
  • @fsergeys
    Can you post the complete core dump so we can decode and discover where the error is coming from?
  • anyone?
    any tip to get me further is welcome.
