    Pytrack GPS API
    pytrack
    51 Posts 13 Posters 16.1k Views 20 Watching
    • N Offline
      Neuromystix @Neuromystix
      @crumble I added a function where i can get time and date. If you want, try it and check if you have any problem.
      main.py
      L76GNSS
      Code:
      ## Test code for read date/time from gps and update RTC
      import math
      import network
      import utime
      from machine import RTC
      from machine import SD
      from machine import Timer
      from L76GNSS import L76GNSS
      from pytrack import Pytrack
      import struct
      # setup as a station
      import gc
      time.sleep(2)
      gc.enable()
      #Start GPS
      py = Pytrack()
      l76 = L76GNSS(py, timeout=600)
      #start rtc
      rtc = machine.RTC()
      print('Aquiring GPS signal....')
      #try to get gps date to config rtc
      while (True):
         gps_datetime = l76.get_datetime()
         #case valid readings
         if gps_datetime[3]:
             day = int(gps_datetime[4][0] + gps_datetime[4][1] )
             month = int(gps_datetime[4][2] + gps_datetime[4][3] )
             year = int('20' + gps_datetime[4][4] + gps_datetime[4][5] )
             hour = int(gps_datetime[2][0] + gps_datetime[2][1] )
             minute = int(gps_datetime[2][2] + gps_datetime[2][3] )
             second = int(gps_datetime[2][4] + gps_datetime[2][5] )
             print("Current location: {}  {} ; Date: {}/{}/{} ; Time: {}:{}:{}".format(gps_datetime[0],gps_datetime[1], day, month, year, hour, minute, second))
             rtc.init( (year, month, day, hour, minute, second, 0, 0))
             break
      print('RTC Set from GPS to UTC:', rtc.now())
      chrono = Timer.Chrono()
      chrono.start()
      #sd = SD()
      #os.mount(sd, '/sd')
      #f = open('/sd/gps-record.txt', 'w')
      while (True):
         print("RTC time : {}".format(rtc.now()))
         coord = l76.coordinates()
         #f.write("{} - {}\n".format(coord, rtc.now()))
         print("$GPGLL>> {} - Free Mem: {}".format(coord, gc.mem_free()))
         coord1 = l76.coordinates1()
         print("$GPGGA>> {} - Free Mem: {}".format(coord1, gc.mem_free()))
         coord2 = l76.get_datetime()
         print("$G_RMC>> {} - Free Mem: {}".format(coord2, gc.mem_free()))
      The L76GNSS.py code:
      import gc
      import binascii
      class L76GNSS:
          GPS_I2CADDR = const(0x10)
          def __init__(self, pytrack=None, sda='P22', scl='P21', timeout=None):
              if pytrack is not None:
                  self.i2c = pytrack.i2c
                  from machine import I2C
                  self.i2c = I2C(0, mode=I2C.MASTER, pins=(sda, scl))
              self.chrono = Timer.Chrono()
              self.timeout = timeout
              self.timeout_status = True
              self.reg = bytearray(1)
              self.i2c.writeto(GPS_I2CADDR, self.reg)
          def _read(self):
              self.reg = self.i2c.readfrom(GPS_I2CADDR, 128)      #Changed from 64 to 128 - I2C L76 says it can read till 255 bytes
              return self.reg
          def _convert_coords(self, gngll_s):
              lat = gngll_s[1]
              lat_d = (float(lat) // 100) + ((float(lat) % 100) / 60)
              lon = gngll_s[3]
              lon_d = (float(lon) // 100) + ((float(lon) % 100) / 60)
              if gngll_s[2] == 'S':
                  lat_d *= -1
              if gngll_s[4] == 'W':
                  lon_d *= -1
              return(lat_d, lon_d)
          #diff indexes from original - Using GGA sentence
          def _convert_coords1(self, gngga_s):
              lat = gngga_s[2]
              lon = gngga_s[4]
              if gngga_s[3] == 'S':
                  lat_d *= -1
              if gngga_s[5] == 'W':
                  lon_d *= -1
          def _get_time(self, gngga_s):
              gps_time = gngga_s[1]
              return(gps_time)
          def _get_altitude(self, gngga_s):
              gps_altitude = gngga_s[9]
              return(gps_altitude)
          def _get_satellites(self, gngga_s):
              num_satellites = gngga_s[7]
              return(num_satellites)
          def _fix_quality(self, gngga_s):
              valid = gngga_s[6]
              if valid == '1':
                  return True
                  return False
          #Using RMC sentence
          def _get_time_rmc(self, gnrmc_s):
              gps_time = gnrmc_s[1]
              return(gps_time)
          def _data_valid_rmc(self, gnrmc_s):
              valid = gnrmc_s[2]
              if valid == 'A':
                  return True
                  return False
          def _get_date_rmc(self, gnrmc_s):
              gps_date = gnrmc_s[9]
              return(gps_date)
          def coordinates(self, debug=False):
              lat_d, lon_d, debug_timeout = None, None, False
              if self.timeout is not None:
                  self.chrono.reset()
                  self.chrono.start()
              nmea = b''
                  if self.timeout is not None and self.chrono.read() >= self.timeout:
                      self.chrono.stop()
                      chrono_timeout = self.chrono.read()
                      self.chrono.reset()
                      self.timeout_status = False
                      debug_timeout = True
                  if not self.timeout_status:
                      gc.collect()
                      break
                  nmea += self._read().lstrip(b'\n\n').rstrip(b'\n\n')
                  gngll_idx = nmea.find(b'GNGLL')
                  if gngll_idx >= 0:
                      gngll = nmea[gngll_idx:]
                      e_idx = gngll.find(b'\r\n')
                      if e_idx >= 0:
                          try:
                              gngll = gngll[:e_idx].decode('ascii')
                              gngll_s = gngll.split(',')
                              lat_d, lon_d = self._convert_coords(gngll_s)
                          except Exception:
                              pass
                          finally:
                              nmea = nmea[(gngll_idx + e_idx):]
                              gc.collect()
                              break
                      gc.collect()
                      if len(nmea) > 410: # i suppose it can be safely changed to 82, which is longest NMEA frame
                          nmea = nmea[-5:] # $GNGL without last L
                  time.sleep(0.1)
              if debug and debug_timeout:
                  print('GPS timed out after %f seconds' % (chrono_timeout))
                  return(None, None)
          #TEST functions
          #Parser for GPGGA
          def coordinates1(self, debug=False):
              lat_d, lon_d, gps_time, valid, gps_altitude, num_satellites, debug_timeout = None, None, None, None, None, False, False
                  self.chrono.reset()
                  self.chrono.start()
              nmea = b''
                      self.chrono.stop()
                      self.chrono.reset()
                      gc.collect()
                      break
                  gpgga_idx = nmea.find(b'GPGGA')
                  if gpgga_idx >= 0:
                      gpgga = nmea[gpgga_idx:]
                      gpgga_e_idx = gpgga.find(b'\r\n')
                      if gpgga_e_idx >= 0:
                          try:
                              gpgga = gpgga[:gpgga_e_idx].decode('ascii')
                              gpgga_s = gpgga.split(',')
                              lat_d, lon_d = self._convert_coords1(gpgga_s)
                              gps_time = self._get_time(gpgga_s)
                              valid = self._fix_quality(gpgga_s)
                              gps_altitude = self._get_altitude(gpgga_s)
                              num_satellites = self._get_satellites(gpgga_s)
                          except Exception:
                              pass
                          finally:
                              nmea = nmea[(gpgga_idx + gpgga_e_idx):]
                              gc.collect()
                              break
                      gc.collect()
                  time.sleep(0.1)
                  return(None, None, None, None, False, None)
                  return(lat_d, lon_d, gps_time, gps_altitude, valid, num_satellites)
          #parser for UTC time and date >> Reads GPRMC
          def get_datetime(self, debug=False):
              lat_d, lon_d, gps_time, valid, gps_date, rmc_idx, debug_timeout = None, None, None, None, None, -1, False
                  self.chrono.reset()
                  self.chrono.start()
              nmea = b''
                      self.chrono.stop()
                      self.chrono.reset()
                      gc.collect()
                      break
                  #Since or spg or glonass could give date see which one is present -SEE page 10 GNSS protocol
                  #GPS only       - GPRMC         GPGGA
                  #Glonass only   - GNRMC         GPGGA
                  #GPS+GLON       - GNRMC         GPGGA
                  #No station     - GPRMC         GPGGA
                  gprmc_idx = nmea.find(b'GPRMC')
                  gnrmc_idx = nmea.find(b'GNRMC')
                  if gprmc_idx >= 0:
                      rmc_idx = gprmc_idx
                  if gnrmc_idx >= 0:
                      rmc_idx = gnrmc_idx
                  if rmc_idx >= 0:
                      rmc = nmea[rmc_idx:]
                      rmc_e_idx = rmc.find(b'\r\n')
                      if rmc_e_idx >= 0:
                          try:
                              rmc = rmc[:rmc_e_idx].decode('ascii')
                              rmc_s = rmc.split(',')
                              lat_d, lon_d = self._convert_coords1(rmc_s[1:])
                              gps_time = self._get_time_rmc(rmc_s)
                              valid = self._data_valid_rmc(rmc_s)
                              gps_date = self._get_date_rmc(rmc_s)
                          except Exception:
                              pass
                          finally:
                              nmea = nmea[(rmc_idx + rmc_e_idx):]
                              gc.collect()
                              break
                      gc.collect()
                      if len(nmea) > 512: # i suppose it can be safely changed to 82, which is longest NMEA frame --CHANGED to 512
                  time.sleep(0.1)
                  return(None, None, None, False, None)
                  return(lat_d, lon_d, gps_time, valid, gps_date)
      Researcher @ UALG, Portugal
      G S 2 Replies Last reply Reply Quote 4
        combaindeft @andrethemac
        @andrethemac Yeah, ran into that issue aswell.
        why we are re-doing the gps library that comes from pycom :)
        and selectively adding more and more features ... so we won't run out of memory
          andrethemac @Neuromystix
          @neuromystix I used to search the nmea messages with _read looking for xxGGA until a fix was found. Only then I use the l76.coordinates to find the exact position.
          a bit of a work around.
          The new library you posted works as a charm, no more memory errors.
          The Quectel is a bit "slow" but with a timeout of 180 (3 minutes), I manage to get a fix (almost) every time the wipy/lopy comes awake (after deep sleep). Not so good for the battery, 3 minutes on +- 70 mA vs 390 uA in deep sleep with the pytrack. The 390 uA are probably from the accelerator, I use the accelerator to wake up the unit when it gets more than 2g for over a second.
          • N Offline
            Neuromystix @andrethemac
            @andrethemac i followed the original lib which use gc to clean memory. But haven't tried any other options.
            Same problem here with the starting time. Sometimes i just unplug the cable from my computer and plug it to a powerbank and have to wait 5 minutes for it to get fix. For my project this will not be a problem but for a battery operated device it's not a good thing...
              gregcope @Neuromystix
              @neuromystix Works like a champ - it would be good if this was added to the main lib. I added HDOP (GPGGA) as that is a good indication of accuracy.
                mwtidd @Neuromystix
                @neuromystix your work has been awesome. Thank you so much for your efforts. In running some test logs earlier today, I found that I got a series of fixes logged that were "invalid". Upon reviewing you code the protocol documents, I have one update to propose
                    valid = gngga_s[6]
                    if valid == '0':
                        return False
                        return True
                Your initial fix quality function only returned true if gngga_s[6] was 1, however it seems that values such as 2 or 3 may be valid as well.
                Per v2.2 of the protocol spec:
                Value Description
                0 Fix not available or invalid
                1 GPS SPS Mode, fix valid
                2 Differential GPS, SPS Mode, fix valid
                3 GPS PPS Mode, fix valid
                Once again, thanks for your efforts. Just wanted to share my findings.
                • N Offline
                  Neuromystix @mwtidd
                  @mwtidd When i wrote it i was reading the "Quectel l76 Series GNSS protocol Specification V3.3" which says (@page 12):
                  Fix Status
                  "0"=Invalid
                  "1"=GNSS fix
                  "2"=DGPS fix
                  "6"=Estimated (dead reckoning) mode
                  That's why i only used "1". But even with that, we can use the value "2" for the DGPS fix. I haven´t checked if i had some fixes "2" ou another values. If it worked for you, nice ;)
                  Best regards
                  Nelson Pinto
                    stefan85e @bmarkus
                    @bmarkus said in Pytrack GPS API:
                    umber of satellites visible /used for fi
                    • number of satellites visible /used for fix - Is this possible yet?!
                    • N Offline
                      Neuromystix @stefan85e
                      @stefan85e If you need the number of satellites used to fix, it's already parsed in l76.coordinates1(). The "Satellites in view" i haven't done it, but it's easy to implement, just parse any $__GSV sentence, the third field is "Satellites in view".
                        stefan85e @Neuromystix
                        @neuromystix said in Pytrack GPS API:
                        l76.coordinates1()
                        Sorry did not udnerstand that :)
                          andrethemac
                          Hi all. I've taken the original librarya and @Neuromystix addtions and made my own library. It parses aml the sentences from the L76 gps and returns them as a dict. you can get the coordinates parsed, the time, ...
                          https://github.com/andrethemac/L76GLNSV4
                          I've noticed one (strange?) thing. the RMC (required minimum data to get a fix) message only pass once (just after starting the gps) and does not reappear. Any idea's ?
                          best regards
                            For use it just call l76.coordinates1() which will return (lat, long, time(not formatted), altitude (M), valid fix (true ou false), number of satellites).
                            L76GNSS.py
                            So what did you do to get the nimber of satellites? We are trying this and we cant get it to work.
                            • N Offline
                              @stefan85e Hello,
                              You have to do something like this inside your code, and you'll get the number of satellites used for fix:
                              gps_data = l76.coordinates1()
                              n_sat = gps_data[5]
                              Or you can use the @andrethemac library which will get you all the data ;)
                                stefan85e @andrethemac
                                @andrethemac
                                (2018, 4, 17, 11, 29, 12, 564887, None)(None(53.33632, 12.53262)
                                (None, None) Got when I add this:
                                n_sat = gps_data[5]
                                Did also try to use this lib:
                                  num_satellites
                                  Does this work:
                                  I want num_satellites...
                                  • N Offline
                                    @stefan85e If you are using my code (and just my code, not the one from @andrethemac), when you call gps_data = l76.coordinates1() it will return a list gps_data with latitude at first position (gps_data[0]), longitude at second (gps_data[1]), and so on till the sixth position where you get the number of satellites (gps_data[5]). So, number_of_satellites = gps_data[5].
                                      andrethemac @stefan85e
                                      @stefan85e An example on how to get the number of satelites with my library
                                      from L76GNSV4 import L76GNSS
                                      py = Pytrack()
                                      L76 = L76GNSS(pytrack=py)
                                      print("test L76")
                                      # returns the info about sattelites in view at this moment
                                      # even without the gps being fixed
                                      print(L76.gps_message('GSV'))
                                      # returns the number of sattelites in view at this moment
                                      print(L76.gps_message('GGA')['NumberOfSV'])
                                      # returns the coordinates
                                      # with debug true you see the messages parsed by the
                                      # library until you get a the gps is fixed
                                      print(L76.coordinates(debug=True))
                                      #L76.getUTCDateTime(debug=True)
                                      #L76._read_message(debug=True)
                                        @andrethemac
                                        Got this
                                        I see that you have a 180 timeout in the code:
                                        -> L76GNSV4 - So how do I know how many sattelites i have then :) just so I look at right nr :)
                                        def init(self, pytrack=None, sda='P22', scl='P21', timeout=180,debug=False):
                                          @stefan85e The timeout is to prevent the library to wait for ever. 180 seconds (3 minutes) is (for me) most of the time enough to get a fixed location. (that is after a cold start)
                                          the GGA sentences contains the number of messages seen by the GPS, In the dict that GGA returns, this is the "NumberOfSV' fied.
                                          with this you get this number -> L76.gps_message('GGA')['NumberOfSV']
                                          In your screenshot the line that prints the number of satellites has scrolled out of view
                                          but if you make this line the last you get the number:
                                          or remove the 'debug=True) from the coordinates line (the debug spews out a lot of information)
                                          I'm still working on the library to make it faster
                                          best regards
                                          A S 2 Replies Last reply Reply Quote 0
                                            andrethemac @andrethemac
                                            @andrethemac published a new version of the Library to github
                                            If you find some errors or have a request, please ask.
                                            best regards
                                            • 1 / 3
