    GPS time from PyTrack
    pytrackrtcgps time
    17 Posts 5 Posters 3.5k Views 5 Watching
      jmpratt
      Is there a way to use the GPS time to set the RTC? I want to be able to log data from remote locations with no wifi access. I want the unit to be able to set the RTC to the correct time upon reset.
      L A 2 Replies Last reply Reply Quote 0
        livius @jmpratt
        @jmpratt
        use https://github.com/inmcm/micropyGPS library
        and there you have possibility to aqquire time from GPS
        and next it is simple to set it to the rtc.init https://docs.pycom.io/chapter/firmwareapi/pycom/machine/RTC.html#rtcinitdatetimenone-sourcertcinternalrc
          jmpratt
          So does the GPS on the PyTrack communicate via a WiPy UART?
          • sebS Offline
            seb @jmpratt
            @jmpratt
            It uses I2C to communicate
              jmpratt @seb
              @seb Thanks. Is there a list of I2C commands that the GPS module supports?
              • sebS Offline
                seb @jmpratt
                @jmpratt
                http://www.quectel.com/UploadImage/Downlad/Quectel_L76-L_I2C_Application_Note_V1.0.pdf
                  jmpratt @seb
                  @seb Does Pycom have any example code that uses the GPS on the PyTrack? All I can find is the code that uses the accelerometer.
                  • sebS Offline
                    seb @jmpratt
                    @jmpratt
                    Check https://github.com/pycom/pycom-libraries
                      jmpratt @seb
                      @seb Got it. Thanks!
                        jmpratt
                        Ok, I'm confused. Here's a link for a project using the PyTrack with the micropyGPS module: https://github.com/ozeta/iot-gps-receiver. If the PyTrack uses I2C to communicate with the GPS chip, how can micopyGPS communicate with the chip via the UART?
                        • sebS Offline
                          seb @jmpratt
                          @jmpratt
                          I see no mention of UART in the linked code
                            jmpratt @seb
                            @seb It looks like he's using both the micropyGPS and L76GNSS modules, which doesn't make any sense to me. Here he talks about seeing output on a UART with a PyTrack and the micropyGPS module: https://github.com/inmcm/micropyGPS/issues/7
                            Is he using the L76GNSS module to pull a NMEA sentence and then send it to the micropyGPS module for handling?
                            Anyone know of a way to contact an author on GitHub?
                            robert-hhR sebS 2 Replies Last reply Reply Quote 0
                              robert-hh @jmpratt
                              @jmpratt said in GPS time from PyTrack:
                              Raise an issue, then the owner will be notified.
                              • sebS Offline
                                seb @jmpratt
                                @jmpratt
                                The L76GNSS library provided by pycom reads the NMEA sentences via I2C, there is no UART involved. The linked to code uses L76GNSS to get the sentenaces, and then micropyGPS to parse them
                                  jmpratt @seb
                                  @seb Ok. Thanks for the confirmation. I appreciate the help.
                                    andrethemac @jmpratt
                                    @jmpratt I've had the same question, and was looking for a library that didn't use to much memory. So I wrote it myself (based upon the default library and @Neuromystix idea's. https://github.com/andrethemac/L76GLNSV4
                                    best regards
                                      jmpratt @andrethemac
                                      @andrethemac Thanks for letting me know! Your library is just what I was looking for.
