    threading error (NameError: name 'xxx' is not defined)
    threadingthread
    4 Posts 2 Posters 2.6k Views 2 Watching
      gregcope
      hi all,
      I am trying to make a Class that merges L76GNSS and micropyGPS. I would like to create a thread to feed the micropyGPS object with NMEA data in the background.
      My code is here; https://github.com/gregcope/L76micropyGPS.
      Basically;
      class L76micropyGPS:
          def __init__(self, my_gps, pytrack=None, sda='P22', scl='P21', timeout=None):
          <snippage>
          # start thread feeding microGPS
              _thread.start_new_thread(feedMicroGPS, '')
          def feedMicroGPS(self):
             # <snippage>
                  # get some NMEA data
                  someNmeaData = self.i2c.readfrom(GPS_I2CADDR, 128)
                  print(" feedGps_thread - gpsChars recieved : {}".format(len(someNmeaData)))
                  # Pass NMEA data to micropyGPS object
                  for x in someNmeaData:
                      self.my_gps.update(x)
      However I get this error;
      File "main.py", line 21, in <module>
      File "/flash/lib/L76micropyGPS.py", line 41, in init
      NameError: name 'feedMicroGPS' is not defined
      What I am doing wrong?
        timh @gregcope
        @gregcope you call _thread.start_new_thread(feedMicroGPS, '') can't find feedMicroGPS which is to be expected, it's definition is not in the scope of the init method.
        You should either be using self.feedMicroGPS or cls.feedMicroGPS (if it where a class method).
        The examples use a function not a method.
          gregcope
          Brilliant. Thanks. Now fails much further on!
          I had assumed that as methods in python are declared as functions that this should just work(tm).
          Thanks again.
            timh
            Functions and methods are actually different things and exist in different scopes.
            You can't look up a method by name without the self. (or similiar) prefix. Unless you bind it to another name in the current scope.
            The same applies to class methods.
