Send a file from one Lopy to another Lopy
It seems that finally they are between lopys and connect because the server prints this:
Now the client seems to give me another error but this one I do not know what it means:
OSError: (Errno 113) EHOSTUNREACH
error host unreachable - this means the lopy could not find a route to the destination
@seb said in Send a file from one Lopy to another Lopy:
If you do not find it as it is on the print server ('connected') when I run the client code? What am I missing?
can you post your complete code and I will have a look
Thank you very much for looking at it. This is the full code of the Lopy Server:
import socket # Import socket module def iniciarFTP(): try: import network from network import WLAN wlan = network.WLAN(mode=network.WLAN.STA) wlan.init(mode=WLAN.AP, ssid='Gateway1', auth=(WLAN.WPA2,'witeklab@2018'), channel=7, antenna=WLAN.INT_ANT) from network import Server server = Server(login=('micro', 'python'), timeout=600) server.timeout(300) server.timeout() print(server.isrunning()) return True except: return False #Iniciamos servidor: iniciarFTP() host = '' port = 8206 # Reserve a port for your service. s = socket.socket() # Create a socket object s.bind((host, port)) # Bind to the port s.listen(5) # Now wait for client connection. print ('Server listening....') while True: conn, addr = s.accept() # Establish connection with client. print ('Got connection from', addr) data = conn.recv(1024) print('Server received', repr(data)) with open('received_file.txt', 'wb') as f: print ('file opened') while True: print('receiving data...') data = s.recv(1024) print('data=%s', (data)) if not data: break # write data to a file f.write(data) f.close() print('Successfully get the file') s.close() print('connection closed') conn.send('Thank you for connecting') conn.close()No more, now I give you a screenshot of what you do when you run it, but I already told you that it stops when you print ('Server listening ....')
As the programming indicates waiting for some connection. But the one that receives a connection from the client fails with the error 'OSError: 128':
Now we go to the client Lopy code:
from network import WLAN import socket import sys def buscarWifi(ssid): wlan = WLAN(mode=WLAN.STA) redes = wlan.scan() print('Redes disponibles: ',len(redes)) for red in redes: if red.ssid == ssid: wlan.connect(red.ssid, auth=(red.sec,'witeklab@2018'), timeout=5000) while not wlan.isconnected(): machine.idle() # save power while waiting print('WLAN connection succeeded!') return True,wlan break else: return False,wlan ok,w = buscarWifi('Gateway1') if ok: print('ok') s = socket.socket() ip = w.ifconfig() print('ip destino = ',ip[0]) print('Configuracion de red:',w.ifconfig()) print('Estoy conectado=',w.isconnected()) ip = w.ifconfig() host = ip[2] #print(type(HOST),'--->>',HOST) port = 8206 s.connect((host, port)) s.send("Hello server!") filename='prueba.txt' f = open(filename,'rb') l = f.read(1024) while (l): conn.send(l) print('Sent ',repr(l)) l = f.read(1024) f.close() s.close()and the error that appears to me in this case is:
I do not know what that error means, nor do I know if I'm doing things right. The only thing I know is that at least now they connect to Lopy client and Lopy server, which is already a lot, having to study how the socket system works.
That's why in some comment I said, I was requesting some exemplary code of how the system should connect between a client and server and transfer a file.
I have taken the code example from here:
http://www.bogotobogo.com/python/python_network_programming_server_client_file_transfer.phpAlthough I would like to be able to use the last one with Thread but I have not known how to adapt it to mircro python:
http://www.bogotobogo.com/python/python_network_programming_server_client_file_transfer.php#ec2 -
@zceld said in Send a file from one Lopy to another Lopy:
import sysdef buscarWifi(ssid):
redes = wlan.scan()
for red in redes:
return True,wlan
break
return False,wlanok,w = buscarWifi('Gateway1')
if ok:
print('ok')
s = socket.socket()
ip = w.ifconfig()
ip = w.ifconfig()
host = ip[2]
port = 8206
l = f.read(1024)
while (l):
conn.send(l)
l = f.read(1024)
f.close()
s.close()Looking at your second block of code it looks like you are trying to connect the device to itself? You are getting
hostfromifconfig()but then trying to connect to that address -
host = ip[2]
Hi, thanks again for checking it out!
In theory the server returns these values of WLAN.ifconfig ():
Of the data that ifconfig returns are:?
('ip assigned', 'subnet mask', 'ip server'?, 'and this last one I do not know' /0.0.0.0).
Capture of the client, this time trying to connect to the ip '192.168.4.1' that is supposed to be the server's Wi-Fi therefore the Lopy server does not?
@zceld
The return of ifconfig is in the following format.
(ip, subnet, gateway, dns)I see now from your code that you are using one of the modules as a wifi AP, can you first try connecting them to an existing network to see if this works, then we can narrow down if the issue lies with the networking or your logic
@zceld
I see now from your code that you are using one of the modules as a wifi AP, can you first try connecting them to an existing network to see if this works, then we can narrow down if the issue lies with the networking or your logicNow I will try to reduce where the problem may be, but the need to connect and send data is to be used without a router, if you do not communicate with each other.
Regardless of the Wi-Fi, do you think that you could send two messages simultaneously with LoRa using thread?
@seb
This is the result that the server connected to Wi-Fi has given me, and to which it has begun to receive data from the client, it has failed:
code used in the superior test:
def buscarWifi(ssid): #Ponemos el wifi en modo estacion: wlan = WLAN(mode=WLAN.STA) #Buscamos wifi: redes = wlan.scan() print('Redes disponibles: ',len(redes)) for red in redes: if red.ssid == ssid: wlan.connect(red.ssid, auth=(red.sec,'hszh6539'), timeout=5000) while not wlan.isconnected(): machine.idle() # save power while waiting print('WLAN connection succeeded!') return True,wlan break else: return False,wlan iniciarFTP() ok,w = buscarWifi('S9+ Wifi') if ok: print('ok') ip = w.ifconfig() host = ip[0] print('my ip = ',ip[0]) port = 60000 # Reserve a port for your service. s = socket.socket() # Create a socket object gc.collect() s.bind((host, port)) # Bind to the port s.listen(5) # Now wait for client connection. print ('Server listening....') while True: conn, addr = s.accept() # Establish connection with client. print ('Got connection from', addr) data = conn.recv(256) print('Server received', repr(data)) with open('received_file.txt', 'wb') as f: print ('file opened') while True: print('receiving data...') s.setblocking(True) print('Memoria->',str(gc.mem_free())) data = s.recv(256) print('M despues->',str(gc.mem_free())) print('data=%s', (data)) if not data: break # write data to a file f.write(data) f.close() print('Successfully get the file') s.close() print('connection closed') conn.send('Thank you for connecting') conn.close() gc.collect()
Result of the Lopy that sends the file:
from network import WLAN import socket import sys def buscarWifi(ssid): #Ponemos el wifi en modo estacion: wlan = WLAN(mode=WLAN.STA) #Buscamos wifi: redes = wlan.scan() print('Redes disponibles: ',len(redes)) #for c in range(len(redes)): #print(c,'->',redes[c]) #if ssid in redes[c]: //Otra opción de encontrar el ssid #print("Encontrado en:",redes[c]) #return True for red in redes: if red.ssid == ssid: wlan.connect(red.ssid, auth=(red.sec,'hszh6539'), timeout=5000) while not wlan.isconnected(): machine.idle() # save power while waiting print('WLAN connection succeeded!') return True,wlan break else: return False,wlan ok,w = buscarWifi('S9+ Wifi') if ok: print('ok') s = socket.socket() print('ip destino = 192.168.43.26') print('Configuracion de red:',w.ifconfig()) print('Estoy conectado=',w.isconnected()) #host = ip[] #print(type(HOST),'--->>',HOST) port = 60000 s.connect(('192.168.43.26', port)) s.send("Hello server!") filename='prueba.txt' f = open(filename,'rb') l = f.read(256) while (l): conn.send(l) print('Sent ',repr(l)) l = f.read(256) f.close() s.close() -
Please excuse the delay. I have gone ahead and written some code for you to demonstrate sending a file between devices. Be aware that this does no error checking/retries etc. but the basic functionality is there.
Client
from network import WLAN import socket import select import machine import time # Connect to server AP wlan = WLAN(mode=WLAN.STA) nets = wlan.scan() for net in nets: if net.ssid == 'Gateway1': print('Network found!') wlan.connect(net.ssid, auth=(net.sec, 'password'), timeout=5000) while not wlan.isconnected(): machine.idle() # save power while waiting print('WLAN connection succeeded!') break else: raise Exception("WiFi network not found") # sleep just to make sure the wifi is connected time.sleep(1) ip, subnet, gateway, dns = wlan.ifconfig() # Connect to server port = 12345 s = socket.socket() print("Connecting to: ", gateway, port) s.connect((gateway, port)) s.setblocking(True) s.settimeout(2) file = "/flash/test.txt" with open(file, 'wb') as f: while True: try: data = s.recv(1024) print(data) f.write(data) except TimeoutError: breakServer
from network import WLAN import socket import select import time #Setup WiFi AP wlan = WLAN(mode=WLAN.AP, ssid='Gateway1', auth=(WLAN.WPA2,'password'), antenna=WLAN.INT_ANT) # Bind to the port port = 12345 s = socket.socket() s.bind(socket.getaddrinfo("0.0.0.0", port)[0][4]) s.listen(1) print("Running server") while True: readable, writable, errored = select.select([s], [], []) for s in readable: cl, remote_addr = s.accept() cl.setblocking(True) print("Client connection from:", remote_addr) file = "/flash/test.txt" print("Sending: ", file) with open(file, 'rb') as f: data = f.read(1024) while(data): print("sending", data) cl.sendall(data) data = f.read(1024) print("Done Sending") cl.close() -
from network import WLAN import socket import select import time #Setup WiFi AP wlan = WLAN(mode=WLAN.AP, ssid='Gateway1', auth=(WLAN.WPA2,'password'), antenna=WLAN.INT_ANT) # Bind to the port port = 12345 s = socket.socket() s.bind(socket.getaddrinfo("0.0.0.0", port)[0][4]) s.listen(1) print("Running server") while True: readable, writable, errored = select.select([s], [], []) for s in readable: cl, remote_addr = s.accept() cl.setblocking(True) print("Client connection from:", remote_addr) file = "/flash/test.txt" print("Sending: ", file) with open(file, 'rb') as f: data = f.read(1024) while(data): print("sending", data) cl.sendall(data) data = f.read(1024) print("Done Sending") cl.close()hi, forgive me for the delay, yesterday I could not look at it, today was the first thing I've done and has given a failure on the server.
Did you create a test.txt file on your device too? the server reads the file test.txt and client writes to a file called test.txt
I had not realized that it was the other way around, that is, as my idea was to send the client to the server, I had not noticed sorry. Anyway now I have changed it to a file that is in the Lopy but now it tells me this error:
Captura de pantalla 2018-04-19 16.30.23 -
How big of a file are you trying to copy?
I still do not know what that error means but it must be related to the socket and the listener method.
But I have reset the plates and it has worked :) I still do not believe it ...
hehe thank you very much at least I know that something works now I need many things to know but already with the base is much.By the way when you put the socket = cl.setblocking (True)
Is there a way to cancel or interrupt this?
another question. this 's.listen (1)' which means you will be listening once?I have more questions ... If I use for example Wi-Fi or Lora with _threads, can I send and listen to the same chip at the same time?
You can cancel it by using
setblocking(False) -
you can find out what
s.listen(1)means here: https://docs.pycom.io/chapter/firmwareapi/micropython/usocket.html#socketlistenbacklog its basically how many unaccepted connections you can queue up -
Yeah that should be fine, the underlying drivers for wifi/lora will handle multiplexing access to them
You can cancel it by using setblocking(False)
you can find out what s.listen(1) means here: https://docs.pycom.io/chapter/firmwareapi/micropython/usocket.html#socketlistenbacklog its basically how many unaccepted connections you can queue up
Would you know to tell me that I failed in all the previous examples??
On the other hand I already ask you in your day for the same thing of s.setblocking (True / False) you know where I could find an exhaustive explanation about that?
Finally on the _treads, to confirm. It would be possible to put in a Lopy a _tread that established the wifi in WLAN.AP mode and in turn in the same Lopy through another _tread the wifi was put in WLAN.STA mode at the same time?
The docs are the best place to look at what these functions do: https://docs.pycom.io/chapter/firmwareapi/micropython/usocket.html
Here is a basic run down,
s.setblocking(True)will make any sending or recieving functions block, this means the lopy will get stuck at that line of code until it receives the amount of bytes asked for (or it timesout, if a timeout is set) or until all data is send. When it isFalsecalls to any sending or receiving functions will return immediately. In the case of a send, it will place the data in a queue and it will be send in the background in a different thread. In the case of a recieve, if there is less data than expected available it simply returns that and doesnt wait for the full expected amount.You can change the WLAN modes but this will become messy because you will need to make sure the threads have proper locks and that they are aware of what state the WLAN is in before trying to use it. You might be better off just using the WLAN.STA_AP mode which is both modes at once.
Good again.
I return to post, because I would need the LoPy that receives the txt file is the one that starts the wifi as
wlan = WLAN (mode = WLAN.AP,
ssid = 'Gateway1',
auth = (WLAN.WPA2, 'password'),
antenna = WLAN.INT_ANT)I have tried to modify the code as I have the partner that works so that it is but I get error everywhere.
Once trying once more, if I do not restart the board and try to execute the code, I always get the error:
File "<stdin>", line 17, in <module>
OSError: [Errno 12] ENOMEMBecause it is ? If someone can give me a hand code please!
Capture Errors:
used code:
Server And Wifi AP:from network import WLAN import socket import select import time #Setup WiFi AP wlan = WLAN(mode=WLAN.AP, ssid='Gateway1', auth=(WLAN.WPA2,'password'), antenna=WLAN.INT_ANT) port = 12345 s = socket.socket() s.bind(socket.getaddrinfo("0.0.0.0", port)[0][4]) s.listen(1) print("Running server") while True: cl, remote_addr = s.accept() cl.setblocking(True) print("Client connection from:", remote_addr) file = "/flash/registro2.txt" with open(file, 'wb') as f: try: data = s.recv(1024) print(data) f.write(data) except TimeoutError: breakClient and Lopy and in charge to send file:
from network import WLAN import socket import select import machine import time # Abrimos wifi wlan = WLAN(mode=WLAN.STA) nets = wlan.scan() for net in nets: if net.ssid == 'Gateway1': print('Network found!') wlan.connect(net.ssid, auth=(net.sec, 'password'), timeout=5000) while not wlan.isconnected(): machine.idle() # save power while waiting print('WLAN connection succeeded!') break else: raise Exception("WiFi network not found") # sleep just to make sure the wifi is connected time.sleep(1) ip, subnet, gateway, dns = wlan.ifconfig() # Connect to server # Bind to the port port = 12345 s = socket.socket() s.connect((gateway, port)) s.setblocking(True) s.settimeout(2) while True: readable, writable, errored = select.select([s], [], []) for s in readable: cl, remote_addr = s.accept() cl.setblocking(True) print("Client connection from:", remote_addr) file = "/flash/registro.txt" print("Sending: ", file) with open(file, 'rb') as f: data = f.read(1024) while(data): print("sending", data) cl.sendall(data) data = f.read(1024) print("Done Sending") cl.close()
