    Send a file from one Lopy to another Lopy
    lopy to lopywlanwifi lopy
    27 Posts 2 Posters 7.9k Views 2 Watching
    • Z Offline
      zceld @seb
      @seb said in Send a file from one Lopy to another Lopy:
      @zceld
      The return of ifconfig is in the following format.
      (ip, subnet, gateway, dns)
      I see now from your code that you are using one of the modules as a wifi AP, can you first try connecting them to an existing network to see if this works, then we can narrow down if the issue lies with the networking or your logic
      Now I will try to reduce where the problem may be, but the need to connect and send data is to be used without a router, if you do not communicate with each other.
      Regardless of the Wi-Fi, do you think that you could send two messages simultaneously with LoRa using thread?
      • Z Offline
        zceld @seb
        @seb
        This is the result that the server connected to Wi-Fi has given me, and to which it has begun to receive data from the client, it has failed:
        code used in the superior test:
        def buscarWifi(ssid):
            #Ponemos el wifi en modo estacion:
            wlan = WLAN(mode=WLAN.STA)
            #Buscamos wifi:
            redes = wlan.scan()
            print('Redes disponibles: ',len(redes))
            for red in redes:
                if red.ssid == ssid:
                    wlan.connect(red.ssid, auth=(red.sec,'hszh6539'), timeout=5000)
                    while not wlan.isconnected():
                    return True,wlan
                    break
                    return False,wlan
        iniciarFTP()
        ok,w = buscarWifi('S9+ Wifi')
        if ok:
            print('ok')
            ip = w.ifconfig()
            host = ip[0]
            print('my ip = ',ip[0])
            port = 60000                     # Reserve a port for your service.
            s = socket.socket()             # Create a socket object
            gc.collect()
            s.bind((host, port))            # Bind to the port
            s.listen(5)                     # Now wait for client connection.
            print ('Server listening....')
                conn, addr = s.accept()     # Establish connection with client.
                print ('Got connection from', addr)
                data = conn.recv(256)
                print('Server received', repr(data))
                with open('received_file.txt', 'wb') as f:
                    print ('file opened')
                        print('receiving data...')
                        s.setblocking(True)
                        print('Memoria->',str(gc.mem_free()))
                        data = s.recv(256)
                        print('M despues->',str(gc.mem_free()))
                        print('data=%s', (data))
                        if not data:
                            break
                        # write data to a file
                        f.write(data)
                    f.close()
                    print('Successfully get the file')
                    s.close()
                    print('connection closed')
                    conn.send('Thank you for connecting')
                conn.close()
                gc.collect()
        Result of the Lopy that sends the file:
        from network import WLAN
        import sys
            #Buscamos wifi:
            redes = wlan.scan()
            #for c in range(len(redes)):
                #print(c,'->',redes[c])
                #if ssid in redes[c]: //Otra opción de encontrar el ssid
                #print("Encontrado en:",redes[c])
                #return True
            for red in redes:
                    return True,wlan
                    break
                    return False,wlan
        if ok:
            print('ok')
            s = socket.socket()
            print('ip destino = 192.168.43.26')
            print('Configuracion de red:',w.ifconfig())
            print('Estoy conectado=',w.isconnected())
            #host = ip[]
            #print(type(HOST),'--->>',HOST)
            port = 60000
            s.connect(('192.168.43.26', port))
            s.send("Hello server!")
            filename='prueba.txt'
            f = open(filename,'rb')
            l = f.read(256)
            while (l):
               conn.send(l)
               print('Sent ',repr(l))
               l = f.read(256)
            f.close()
            s.close()
        • sebS Offline
          seb
          Please excuse the delay. I have gone ahead and written some code for you to demonstrate sending a file between devices. Be aware that this does no error checking/retries etc. but the basic functionality is there.
          Client
          import select
          # Connect to server AP
          nets = wlan.scan()
          for net in nets:
              if net.ssid == 'Gateway1':
                  print('Network found!')
                  wlan.connect(net.ssid, auth=(net.sec, 'password'), timeout=5000)
                  break
              raise Exception("WiFi network not found")
          # sleep just to make sure the wifi is connected
          time.sleep(1)
          ip, subnet, gateway, dns = wlan.ifconfig()
          # Connect to server
          port = 12345
          s = socket.socket()
          print("Connecting to: ", gateway, port)
          s.connect((gateway, port))
          s.setblocking(True)
          s.settimeout(2)
          file = "/flash/test.txt"
          with open(file, 'wb') as f:
                  try:
                      data = s.recv(1024)
                      print(data)
                      f.write(data)
                  except TimeoutError:
                      break
          Server
          import select
          #Setup WiFi AP
          wlan = WLAN(mode=WLAN.AP,
                      ssid='Gateway1',
                      auth=(WLAN.WPA2,'password'),
                      antenna=WLAN.INT_ANT)
          # Bind to the port
          port = 12345
          s = socket.socket()
          s.bind(socket.getaddrinfo("0.0.0.0", port)[0][4])
          s.listen(1)
          print("Running server")
              readable, writable, errored = select.select([s], [], [])
              for s in readable:
                  cl, remote_addr = s.accept()
                  cl.setblocking(True)
                  print("Client connection from:", remote_addr)
                  print("Sending: ", file)
                  with open(file, 'rb') as f:
                      data = f.read(1024)
                      while(data):
                          print("sending", data)
                          cl.sendall(data)
                          data = f.read(1024)
                  print("Done Sending")
                  cl.close()
          Z 1 Reply Last reply Reply Quote 1
          • Z Offline
            zceld @seb
            import select
            #Setup WiFi AP
                        ssid='Gateway1',
            # Bind to the port
            port = 12345
            s = socket.socket()
            s.listen(1)
                for s in readable:
                        data = f.read(1024)
                        while(data):
                            cl.sendall(data)
                            data = f.read(1024)
                    cl.close()
            hi, forgive me for the delay, yesterday I could not look at it, today was the first thing I've done and has given a failure on the server.
            • sebS Offline
              seb @zceld
              @zceld
              Did you create a test.txt file on your device too? the server reads the file test.txt and client writes to a file called test.txt
              • Z Offline
                zceld @seb
                I had not realized that it was the other way around, that is, as my idea was to send the client to the server, I had not noticed sorry. Anyway now I have changed it to a file that is in the Lopy but now it tells me this error:
                0_1524148256070_d4c119a9-7b2b-4f3f-adb3-340e720e3c95-image.png Captura de pantalla 2018-04-19 16.30.23
                sebS Z 2 Replies Last reply Reply Quote 0
                • sebS Offline
                  seb @zceld
                  @zceld
                  How big of a file are you trying to copy?
                  • Z Offline
                    zceld @zceld
                    @zceld
                    I still do not know what that error means but it must be related to the socket and the listener method.
                    But I have reset the plates and it has worked :) I still do not believe it ...
                    hehe thank you very much at least I know that something works now I need many things to know but already with the base is much.
                    By the way when you put the socket = cl.setblocking (True)
                    Is there a way to cancel or interrupt this?
                    another question. this 's.listen (1)' which means you will be listening once?
                    I have more questions ... If I use for example Wi-Fi or Lora with _threads, can I send and listen to the same chip at the same time?
                    • sebS Offline
                      seb @zceld
                      @zceld
                      1. You can cancel it by using setblocking(False)
                      2. you can find out what s.listen(1) means here: https://docs.pycom.io/chapter/firmwareapi/micropython/usocket.html#socketlistenbacklog its basically how many unaccepted connections you can queue up
                      3. Yeah that should be fine, the underlying drivers for wifi/lora will handle multiplexing access to them
                      • Z Offline
                        zceld @seb
                        Would you know to tell me that I failed in all the previous examples??
                        On the other hand I already ask you in your day for the same thing of s.setblocking (True / False) you know where I could find an exhaustive explanation about that?
                        Finally on the _treads, to confirm. It would be possible to put in a Lopy a _tread that established the wifi in WLAN.AP mode and in turn in the same Lopy through another _tread the wifi was put in WLAN.STA mode at the same time?
                        • sebS Offline
                          seb @zceld
                          @zceld
                          The docs are the best place to look at what these functions do: https://docs.pycom.io/chapter/firmwareapi/micropython/usocket.html
                          Here is a basic run down, s.setblocking(True) will make any sending or recieving functions block, this means the lopy will get stuck at that line of code until it receives the amount of bytes asked for (or it timesout, if a timeout is set) or until all data is send. When it is False calls to any sending or receiving functions will return immediately. In the case of a send, it will place the data in a queue and it will be send in the background in a different thread. In the case of a recieve, if there is less data than expected available it simply returns that and doesnt wait for the full expected amount.
                          You can change the WLAN modes but this will become messy because you will need to make sure the threads have proper locks and that they are aware of what state the WLAN is in before trying to use it. You might be better off just using the WLAN.STA_AP mode which is both modes at once.
                          • Z Offline
                            zceld
                            Good again.
                            I return to post, because I would need the LoPy that receives the txt file is the one that starts the wifi as
                            wlan = WLAN (mode = WLAN.AP,
                            ssid = 'Gateway1',
                            auth = (WLAN.WPA2, 'password'),
                            antenna = WLAN.INT_ANT)
                            I have tried to modify the code as I have the partner that works so that it is but I get error everywhere.
                            Once trying once more, if I do not restart the board and try to execute the code, I always get the error:
                            File "<stdin>", line 17, in <module>
                            OSError: [Errno 12] ENOMEM
                            Because it is ? If someone can give me a hand code please!
                            Capture Errors:
                            used code:
                            Server And Wifi AP:
                            import select
                            #Setup WiFi AP
                                        ssid='Gateway1',
                            port = 12345
                            s = socket.socket()
                            s.listen(1)
                                file = "/flash/registro2.txt"
                                    try:
                                        data = s.recv(1024)
                                        print(data)
                                        f.write(data)
                                        break
                            Client and Lopy and in charge to send file:
                            import select
                            # Abrimos wifi
                            nets = wlan.scan()
                            for net in nets:
                                    break
                            time.sleep(1)
                            # Connect to server
                            # Bind to the port
                            port = 12345
                            s = socket.socket()
                            s.setblocking(True)
                            s.settimeout(2)
                                for s in readable:
                                    file = "/flash/registro.txt"
                                        data = f.read(1024)
                                        while(data):
                                            cl.sendall(data)
                                            data = f.read(1024)
                                    cl.close()
                            • 2 / 2
