    GPy with Hologram.io SIM
    hologram.io
    100 Posts 10 Posters 42.8k Views 12 Watching
      tlanier @jmarcelino
      @jmarcelino
      I accidentally sent a message to Chris which I meant to send to you concerning the possible bug with the lte.send_at_cmd() function. I assume you will see it; I couldn't figure out how to redirect the message to a different person.
        tlanier @jmarcelino
        @jmarcelino
        One time the GPy got into a state where lte.isattached() was returning True at the start of the program. When the lte.connect() was called an exception was thrown:
        After resetting the chip, things are back like they were before (unable to attach).
        It's beginning to look like I may need to put try/except blocks around all calls to the LTE class. I'm not sure if this is what the designers of the LTE module intend for programmers to do.
        lte.isattached() returned True but lte.connect() threw an exception
        Again, this has only happened once.
          tlanier @jmarcelino
          @jmarcelino
          I am now able to attach to the cell tower consistently!
          response=[''+CEREG: 2,5,"AE02","02A99403",7', 'OK', '+CEREG: 5,"AE02","02A99403",7']
          When the lte.connect() method is called, the program crashes with the following exception:
          Notes:
          • In browsing the source code this morning I noticed Daniel posted a significant update to the modlte.c code. Do we have any idea when this update might be published for testing?
          • On the web site there is no indication of firmware versions and history. How do we know when a new update is available to download?
          • At some point the LTE documentation should be updated to indicate which method calls might throw exceptions. For instance the dettach() method can throw an mpexception_os_operation_failed exception. Maybe at the python level we should assume any LTE method call may throw an exception.
          • Problems can occur when a modem command is sent but your timeout is too short and the modem command returns before the modem has finished responding. When the next modem command is sent, the response contains the tailing fragment of the response from the previous command. Adding a delay between sending commands does keep the problem from propagating to the second command (the result received from the first command is invalid since it was aborted prematurely). Maybe the send_at_cmd() should have an optional second parameter that allows the caller to specify the timeout.
          • The dettach() method should probably be renamed detach().
          • Is there any reason to believe I should update the modem firmware at this time, or should I wait for Daniel's patches to be published?
          • ChrisGammellC Offline
            ChrisGammell
            Did something change? Or did it just start working? Or maybe i'm not following the thread? Did you end up swapping antennas or was it something in the code?
            I'm still at the same point with the lte.connect() function, but Jose said the LTE team is looking at that. I found out from my co-worker that it's possible to hook into the modem UART pins, so I might try throwing some other commands via that tomorrow.
              tlanier @ChrisGammell
              @chrisgammell
              After seeing the major changes being made on GitHub this morning when I was studying the code, I had decided to just wait until they were published. I setup my laptop and the GPy in my office (where the signal is actually weaker) just to copy the software changes to my desktop. The attach just started working. I don't think I changed anything from yesterday. I had been playing with adding a delay of 2 secs before trying to attach, but that had no affect yesterday. I took the delay out today and it still attached without a problem. Very strange and no we did not swap the antenna. It turns out the antenna I'm using is within specs.
              Is it possible that Hologram did something to activate my account with Verizon? Is it possible that inserting the SIM in an Android phone somehow activated the SIM? I'm not sure why it started working.
              Tomorrow I will post my updated code. I didn't bring it home with me tonight.
              If I have time tomorrow, I'm thinking about trying to duplicate the connect() code in Python to try to see where it fails. Now that I know the source code is on GitHub, that may generate some ideas of how to debug what is going on. All the code is in C/C++, so the question is whether I can duplicate the same thing in Python to troubleshoot the problem. I really haven't looked at it close enough yet.
              There are various places in the C/C++ code where exceptions are thrown for various reasons. I think one of the fundamental problems the programmer has is how long should you wait for the modem to respond to a command before timing out. Once a timeout occurs bad things can happen since the program may then try to talk to the modem with another command and the modem is still processing and returning results for the previous command. You've gotta timeout at some point, but if you do so too soon things get out of sync.
                ChrisGammell
                @tlanier said in GPy with Hologram.io SIM:
                It is possible that the SIM was not seated correctly. Now that I think of it, I should have had you run the AT+CCID command. This ensures that the modem is reading the unique identifier back from the SIM card. Sometimes if there is dirt or a loose SIM holder, this is a possibility. I'm sorry I didn't think to recommend that. Sometimes in an ongoing battle against getting connected, it's good to go through and do a checklist of things. We actually made a video/blog post about just that, after discussing this situation.
                You mean you'll basically replicate the function that the C++ is doing? Where is this code located?
                  @chrisgammell
                  Attach/Connect Success!!!
                  I've now been able to attach to the tower and connect.
                  The program now crashes at either of these two lines:
                  s.connect(socket.getaddrinfo('www.google.com', 443)[0][-1])
                  or
                  s.send(b"GET / HTTP/1.0\r\n\r\n")
                  OSError: -29312 was one error I got
                  Unfortunately, somehow the unit is now stuck on the "lte = LTE(carrier="verizon")" line which executes when I restart and it hangs forever. CTRL+C does not abort the program, power down/up does not fix, reloading Visual Studio Code does not fix, reinstalling Pymakr does not fix.
                  I don't think my problems in the past were caused by the SIM card not being inserted properly because I think the code throws an exception if it does not detect a SIM plugged in. Unfortunately I can't test that theory now because of the problem above, but I do remember seeing code that checks the SIM.
                  Here's a link to the GitHub site where you can view the code.
                  GitHub
                  The "esp32\mods\modlte.c" is one place to start looking for clues I think. Notice that major changes to this module were made yesterday.
                  import ssl
                  import sys
                  from network import LTE
                  BLACK = 0x000000
                  WHITE = 0xFFFFFF
                  RED = 0xFF0000
                  GREEN = 0x00FF00
                  BLUE = 0x0000FF
                  YELLOW = 0xFFFF00
                  # send AT command to modem and return response as list
                  def at(cmd):
                      print("modem command: {}".format(cmd))
                      r = lte.send_at_cmd(cmd).split('\r\n')
                      r = list(filter(None, r))
                      print("response={}".format(r))
                      return r
                  def blink(rgb, n):
                      for i in range(n):
                          pycom.rgbled(rgb)
                          time.sleep(0.25)
                          pycom.rgbled(BLACK)
                          time.sleep(0.1)
                  print("CAT M1 Test - V0.5 - 4/20/18")
                  print("disable MicroPython control of LED")
                  pycom.heartbeat(False)
                  pycom.rgbled(WHITE)
                  print("instantiate LTE object")
                  print("delay 4 secs")
                  time.sleep(4.0)
                  if lte.isattached():
                      try:
                          print("LTE was already attached, disconnecting...")
                          if lte.isconnected():
                              print("disconnect")
                              lte.disconnect()
                      except:
                          print("Exception during disconnect")
                      try:
                              print("detach")
                              lte.dettach()
                      except:
                          print("Exception during dettach")
                      try:
                          print("resetting modem...")
                          lte.reset()
                      except:
                          print("Exception during reset")
                      print("delay 5 secs")
                      time.sleep(5.0)
                  # enable network registration and location information, unsolicited result code
                  at('AT+CEREG=2')
                  # print("full functionality level")
                  at('AT+CFUN=1')
                  time.sleep(1.0)
                  # using Hologram SIM
                  at('AT+CGDCONT=1,"IP","hologram"')
                  print("attempt to attach cell modem to base station...")
                  # lte.attach()  # do not use attach with custom init for Hologram SIM
                  at("ATI")
                  time.sleep(2.0)
                  i = 0
                  while lte.isattached() == False:
                      # get EPS Network Registration Status:
                      # +CEREG: <stat>[,[<tac>],[<ci>],[<AcT>]]
                      # <tac> values:
                      # 0 - not registered
                      # 1 - registered, home network
                      # 2 - not registered, but searching...
                      # 3 - registration denied
                      # 4 - unknown (out of E-UTRAN coverage)
                      # 5 - registered, roaming
                      r = at('AT+CEREG?')
                      try:
                          r0 = r[0]  # +CREG: 2,<tac>
                          r0x = r0.split(',')     # ['+CREG: 2',<tac>]
                          tac = int(r0x[1])       # 0..5
                          print("tac={}".format(tac))
                      except IndexError:
                          tac = 0
                          print("Index Error!!!")
                      # get signal strength
                      # +CSQ: <rssi>,<ber>
                      # <rssi>: 0..31, 99-unknown
                      r = at('AT+CSQ')
                      # extended error report
                      # r = at('AT+CEER')
                      # if lte.isattached():
                      #    print("Modem attached (isattached() function worked)!!!")
                      #    break
                      # if (tac==1) or (tac==5):
                      #    print("Modem attached!!!")
                      #    break
                      i = i + 5
                      print("not attached: {} secs".format(i))
                      if (tac != 0):
                          blink(BLUE, tac)
                          blink(RED, 1)
                      time.sleep(5)
                  at('AT+CEREG?')
                  print("connect: start a data session and obtain an IP address")
                  lte.connect(cid=3)
                  i = 0
                  while not lte.isconnected():
                      i = i + 1
                      print("not connected: {}".format(i))
                      blink(GREEN, 1)
                      time.sleep(1.0)
                  print("connected!!!")
                  pycom.rgbled(BLUE)
                  s = socket.socket()
                  s = ssl.wrap_socket(s)
                  print(s.recv(4096))
                  s.close()
                  lte.disconnect()
                  lte.dettach()
                  # end of test, Red LED
                  print("end of test")
                      blink(YELLOW,1)
                      time.sleep(1.0)
                    tlanier
                    I now have control of the GPy again. Word to the wise. Do NOT execute "sys.stdin.read()" to try to clear the keyboard input because it will lock the system.
                      ChrisGammell
                      Awesome!
                      I verified it's working on mine as well, thank you for sharing the code
                      T N 2 Replies Last reply Reply Quote 0
                        @chrisgammell
                        Were you able to download data from google or did it crash?
                        I'm waiting my mandatory 180 secs to post on the forum again. There's got to be a better way to prevent SPAM.
                        ChrisGammellC 1 Reply Last reply Reply Quote 1
                          ChrisGammell @tlanier
                          @tlanier Could you define "Crash"? Like did the REPL return? No, it's still stuck at the "end of test" message like in that image. But if I CTRL+C, I'm able to escape to the REPL.
                            @chrisgammell
                            It WORKED!!!
                            The problem I'm having now is after I run the program once successfully the program will hang in the "lte=LTE(carrier="verizon") line at the start of the program. Unfortunately you can't reset the modem without instantiating the LTE object and instantiating the object is what gets hung up. There needs to be some command to say let's start all over and reset everything.
                              tlanier @tlanier
                              @tlanier
                              The program is now connecting to google.com successfully. I'm still having trouble with the unit locking up on the LTE(carrier="verizon") line at times. The chip/development environment gets in a crazy mode where I have to reset/power down/restart Visual Studio Code in unknown combinations to regain control of the chip.
                              The Hologram.io dashboard is TERRIFIC!!! You can see data usage and the actual data that passes across the network. I love it!!!
                              import ssl
                              import sys
                              BLACK = 0x000000
                              WHITE = 0xFFFFFF
                              RED = 0xFF0000
                              GREEN = 0x00FF00
                              BLUE = 0x0000FF
                              YELLOW = 0xFFFF00
                              def at(cmd):
                                  return r
                              def blink(rgb, n):
                                  for i in range(n):
                                      pycom.rgbled(rgb)
                                      time.sleep(0.25)
                                      pycom.rgbled(BLACK)
                                      time.sleep(0.1)
                              print("CAT M1 Test - V0.6 - 4/20/18")
                              # input("")
                              # r = input("Enter anything to abort...")  # allow opportunity to stop program
                              # if r != "":
                              #    sys.exit(0)
                              pycom.rgbled(WHITE)
                              time.sleep(4.0)
                              print("reset modem")
                              try:
                                  lte.reset()
                              except:
                              time.sleep(5.0)
                                  try:
                                          print("disconnect")
                                          lte.disconnect()
                                  except:
                                  try:
                                          print("detach")
                                          lte.dettach()
                                  except:
                                  try:
                                      lte.reset()
                                  except:
                                  time.sleep(5.0)
                              at('AT+CEREG=2')
                              at('AT+CFUN=1')
                              time.sleep(1.0)
                              at("ATI")
                              time.sleep(2.0)
                              i = 0
                                  # <tac> values:
                                  r = at('AT+CEREG?')
                                  try:
                                  except IndexError:
                                      tac = 0
                                  r = at('AT+CSQ')
                                  # r = at('AT+CEER')
                                  #    break
                                  #    break
                                  i = i + 5
                                  if (tac != 0):
                                      blink(BLUE, tac)
                                      blink(RED, 5)
                                  time.sleep(2)
                              at('AT+CEREG?')
                              lte.connect(cid=3)
                              i = 0
                                  i = i + 1
                                  blink(GREEN, 1)
                                  time.sleep(1.0)
                              pycom.rgbled(BLUE)
                              s = socket.socket()
                              print("get www.google.com address")
                              addr = socket.getaddrinfo('www.google.com', 443)
                              print(addr)
                              print("connect to {}".format(addr[0][-1]))
                              s.connect(addr[0][-1])
                              print("GET 50 bytes from google")
                              print(s.recv(50))   # receive 50 bytes
                              print("close socket")
                              s.close()
                              try:
                                  lte.disconnect()
                              except:
                              try:
                                  lte.dettach()
                              except:
                                  blink(GREEN,5)
                                  time.sleep(1.0)
                                tealbrains @tlanier
                                @tlanier I have made the same observation about the unit locking up, I am using the WDT to take care of that, hoping that they will solve the issue in the near future. It does not happen that often, see my other post : https://forum.pycom.io/topic/3073/lte-analysis-of-connectivity . Glad to see you got it working in the end!
                                • N Offline
                                  nathanh @ChrisGammell
                                  @chrisgammell said in GPy with Hologram.io SIM:
                                  Out of curiosity, did you rebuild your firmware from the changes just made to the code on Github?
                                    tlanier @nathanh
                                    @nathanh
                                    Question: did you rebuild your firmware from the changes just made to the code on Github?
                                    No, that's why I asked the questions:
                                    • When can the next update be expected?
                                    • How will we be notified that the update is available (the web site just has a link to the update program with no version number displayed)?
                                      RWall
                                      Has there been any additional progress on this issue?
                                      If not, is it possibly due to carrier="verizon" and using a hologram SIM effectively being mutually exclusive (emphasis on “effectively”).
                                      My understanding is that the carrier assignment optimizes the modem configuration for operation on a specific cellular network (Verizon in this case). However, operating on the Verizon network as a Verizon customer vs operating on their network through a MVNO may be very different. The most obvious is being on a home network vs roaming. In addition to functional implications, are there additional constraints based on Hologram’s contractual relationship with Verizon that may be playing a role in this issue? If I recall correctly from an old Hologram discussion, network operators like Verizon impose constraints on VMNO users such as requiring different timeouts on data connections.
                                      ChrisGammellC T 2 Replies Last reply Reply Quote 0
                                        ChrisGammell @RWall
                                        @rwall If it requires that we do something other than set the APN, I assume that the development process baked in some special magic to get around some restriction on the Verizon side of things (understandable if it was due to the relatively new Sequans chipset). I would be curious if any other SIMs have been tried other than ours and Verizon's. For now, I'm left at the same stage as others of "waiting for updates from the LTE team".
                                        I had missed Nathan's question about rebuilding the firmware. I did not, I simply used the latest block of code that tlanier had posted. I verified it connected to the Verizon tower and to our cloud and then got pulled away onto something else.
                                        Fun new feature on our dashboard, you can see live usage data and tower location for pro plan stuff.
                                          tlanier @RWall
                                          @rwall
                                          Last weekend I drove the device from LaGrange, GA to Fairhope, AL (about 270 miles) . During the trip I spot checked CAT M1 connectivity. It worked everywhere except when I reached Fairhope where it did not work even though I had 3-4 bars on my cell phone (which also uses Verizon). We are still looking for a coverage map from the carrier detailing where CAT M1 coverage should be expected.
                                            RWall
                                            @tlanier, thanks for the update. Do the results from your road trip mean that your system is no longer locking up on the LTE(carrier="verizon") line? If yes, can you share how it was resolved?
                                            • 5
                                            • 4 / 5
