maximum number of clients
  • hello,
    I am making a project, which should connect one Lopy to 7 ESP8266 through Wi-Fi. Lopy is access point and all Esp8266 are clients.
    so far Lopy connects to only any 4 clients among all. how to increase the number of clients
    or
    how to connect rest of the three esp8266 to same one Lopy.
    I am using below line of code in Lopy(Access point) which is related to wifi configuration:
    wlan=WLAN(mode=WLAN.AP, ssid='lopy-wlan-7cd4', auth=(WLAN.WPA2,'www.pycom.io'), channel=11, antenna=WLAN.EXT_ANT)
    another question what is the maximum number of clients that can connect to Lopy or Wipy in wifi mode.
    please help.
    thanks
  • @dhk111
    As you found 4 clients is the maximum number of clients for the LoPy or WiPy in AP mode.
    This is a limit set by the microcontroller core libraries/framework we use (ESP-IDF) so probably not going to increase anytime soon.
