    What does a green LED after power up mean?
    lopy4boot modergbled
    20 Posts 8 Posters 3.7k Views 9 Watching
      g0hww
      Me too, with the sporadic green LED on startup. Pressing the reset set button a few times will typically get past the issue, but its not a good thing. So far, I've only seen this on a Lopy4 on an Expansion Brd 2. Not yet seen on the Lopy4 on PyTrack.
      This with FW 1.17.3.b1.
        MarcoBenini
        LoPy4 + Expansion board 2.0 and nothing else connected. same problem.
        If I plug and unplug the USB to the pc, than the green light stays on and it not possible interaction with LoPy4.
        Pressing the reset button, than it works normally.
        Firmware: the latest stable version from link in documentation (1.17.3.b1).
        Same expansion board and USB cable with LoPy => no problem.
        dwsD 1 Reply Last reply Reply Quote 0
        • dwsD Offline
          dws @MarcoBenini
          @marcobenini Did you try a high-current power supply instead of PC usb power? that solved it for me. Find a USB supply rated at perhaps 1A or more. I have a large USB battery that also works well.
            MarcoBenini @dws
            @dws Yes, You are right, it should be a problem with power supply.
            I retested with a very short USB cable and now it works, but there is always an initial "green" light that lasts about a second (that does not happens with the LoPy).
            The longer USB, I tried before, is the best one I have, infact is the only one that arrives to have a stable conenction with another LoRa card I have (not PyCom).
            It looks like the initial current need of LoPy4 vs. LoPy is higher, or initial powerup sequence of LoRa module is different.
            Probably is brown-out detection that causes the initial green light, combined, maybe, that onboard capacitors doesn't arrive to deal with (too small or slow capacitors ?).
            • dwsD Offline
              dws @MarcoBenini
              @marcobenini Hopefully others here can give their opinion on why this happens. I think you are correct. I am going to purchase some high-quality USB cables for use with pycom and other micros, to avoid this in the future. If anyone here can recommend a brand of cable they like, please do.
                robert-hh @dws
                @dws I use a 3 feet USB3 extension cable at a USB3 port, with a short adapter cable to Micro-USB. That works well. USB3 is rated at 900 mA.
                The FiPys I have also show green light for ashort while on boot. As far as I know, that's just the confirmation than an firmware Image with a valid signature was found; green light for taking off, so to speak.
                dwsD S 2 Replies Last reply Reply Quote 0
                • dwsD Offline
                  dws @robert-hh
                  @robert-hh Thanks! I never saw anything in the docs regarding the purpose of this green LED. If anyone can point to that, it would be appreciated.
                    Sympatron @robert-hh
                    @robert-hh But this would have to be implemented somewhere in the firmware and I did not find any trace of this.
                      jcaron
                      Does this happen when coming out of deep sleep as well, or only on the initial device start?
                        MarcoBenini
                        I made some other tests, the ones I can make since I have no oscilloscope, desktop lab power supply, ...
                        So LoPy4 + expansion board with three NiMH batteries.
                        1. First connection to power up => green light and than normal heartbeat blue light
                        2. connect power, disconnect for few seconds (5 -10 seconds) and than reconnect => no green light, than starts blue heartbeat
                        3. connect power, disconnect for more than 10/15 seconds, reconnect => green light and than blue heartbeat.
                          I suppose that internal capacitors discharge.
                        Than tried with external FTDI without +3.3V connected to LoPy4.
                        With machine.reset() or machine.deepsleep() there is no green ligth.
                        My explanation, but I could be wrong, the capacitors should be fully charged.
                          robert-hh @Sympatron
                          @sympatron OK. I do not know where I found that, and cannot see it in the sources either. The only thing I found in the comments to 1.17.3.b1 was to switch of the RGB led early. So maybe it lights up for other reasons. A transition on P2 may bring the LED on. But at least the fact, that it switched off indicates the normal boot being started.
