AWS MQTT 'Packet sent. (Length: 2)' periodic message
I am successfully using the AWS MQTT lib but noticed that on my Wipy, every 20 seconds the following message is printed: Packet sent. (Length: 2).
It does not register on the AWS console as a message, so what is being sent? Maybe a keep alive message, if so, can I change the interval? Is it even a MQTT message being sent?
This will be a keepalive packet. You can set the keepalive frequency in the api
I tried specifying the keep-alive frequency by passing a value in the connect() method: pycomAwsMQTTClient.connect(900), but still occurs every 20 seconds. Drilling down the source code, this value is thrown away. Look at def _send_connect(self, keepalive, clean_session) method in MQTTClient.py. The keepalive argument is not used. If I remember correctly, AWS specifies a max keep-alive interval of 20 minutes, it's weird that this keep-alive is 20 seconds. Perhaps a result of some late night coding? :)
@timh I sm only using part of that library, (the lower levels) and the keepalive does work down there. I am not talking to AWS, but another platform that needs to use TLS.
There are a number of problems with the library as it's currently implemented.
For instance when you disconnect the background thread is not cleaned up, so a reconnect attempt causes problems, without destroying the thread .
So I would not be surprised its really only addressing a minimal working set.
@timh Thanks for the heads-up. Are you satisfied with your implementation of MQTT? Meaning you got everything to work reliably and stable? I don't mind writing my own MQTT lib, as long as I can know my efforts won't be pointless because of unstable firmware/micropython/hardware/etc.
@inverseeffect using the underlying library that the AWS work is built on seems to work ok. What I haven't had time to do yet is very long running (many days) tests. I did leave an LTE based MQTT connection active with just keepalives going last week, and ended up with a GURU meditation error, after an un caught exception. But the session was active in a console and no code around it. Will look into this more this week.
... Packet sent. (Length: 2) Packet sent. (Length: 2) Packet sent. (Length: 2) Guru Meditation Error: Core 1 panic'ed (StoreProhibited) . Exception was unhandled. Register dump: PC : 0x4017c802 PS : 0x00060433 A0 : 0x8017d867 A1 : 0x3ffe4da0 A2 : 0x00000000 A3 : 0x00000041 A4 : 0xffffff40 A5 : 0xfe5440ff A6 : 0xfe7d983f A7 : 0xfe7e9c3f A8 : 0x8017c802 A9 : 0x3ffe4d80 A10 : 0x3ffe7d98 A11 : 0x400839f8 A12 : 0x00000100 A13 : 0x3ffe7f9c A14 : 0x882072f1 A15 : 0x66316b7d SAR : 0x00000008 EXCCAUSE: 0x0000001d EXCVADDR: 0xfe544103 LBEG : 0x4009b194 LEND : 0x4009b1c2 LCOUNT : 0x00000000 -
@inverseeffect Did you ever get any resolution on the keepalive timer? I'm running into the same issue. For now I've switched to simple.py, but I would much rather use the AWS library.
