    Expansion board v3.0 doesn't go in Dfu mode
    fipy
    7 Posts 4 Posters 2.3k Views 4 Watching
      Matthew
      I've successfully installed libusbk drivers, now i can't turn on my expansion board in dfu mode (0xEF99) to upgrade the firmware, what of the 2 buttons i have to keep press?
      i think i've installed libusbk while in normal boot (0xEF98), i'm not sure, is this a problem?
        jmarcelino @Matthew
        You should only press S1 while plugging in the USB cable to enable DFU mode.
        If you've accidentally set EF98 device to the libusbK driver you'll then need to revert it to get the COM port back
          Matthew @jmarcelino
          @jmarcelino How should i revert back to COM?
          I've tried also to do this in linux and this is what i get, actually it recognize ef99 but cannot open it
          And on widows 7 with many tries i got
          The installation blocked at 96%
          J VolodymyrV 2 Replies Last reply Reply Quote 0
            jmarcelino @Matthew
            @matthew
            To revert back to COM please use the WinUSB driver
            On Linux it sounds like a permission problem, can you try running dfu-util as root with e.g. sudo?
            Regarding the last screen I've never seen a problem at 96% as you reported. Maybe try a different cable. If there's a battery connected to the Expansion Board also please unplug it.
              Matthew @jmarcelino
              @jmarcelino
              Tried a different cable on windows 7 and on windows 10 got back to com and then back to libusbk correctly, nothing different happens, on linux instead i got this
              • VolodymyrV Offline
                Volodymyr @Matthew
                @matthew said in Expansion board v3.0 doesn't go in Dfu mode:
                I could workaround this by inserting the device into the available USB2.0 port, instead of 3.0 SS.
                You could also try USB2.0 hub, if you have no 2.0 ports..
                • catalinC Offline
                  catalin
                  hi @Matthew,
                  First, you should not have anything plugged in the Expansion Board, no Lopy/Fipy.
                  On Windows, the fact that went up to 96% and stopped, means there are USB problems(lots of retries and timeout). Try changing something, USB port, cable. We had lots of problems with poor USB cables. Maybe try to remove other USB peripherals, from your PC.
                  On Linux, please, check if board is in dfu mode, looking at lsusb output, 04D8:EF99 should be visible. It's not clear from dfu-util error, Cannot open DFU device 04d8:ef99, if the device is not enumerated or you don't have rights.
                  As wild try, maybe you should keep just RX and TX jumpers, on Expansion Board.
                  <later edit>: FYI, the Expansion board 3 has already the latest firmware, we released just once
                  Catalin,
