Security - IP Protection
@inverseeffect The main entrance is REPL, as you told. The encryption of the flash prevents access from "out of band" tools like esptools.py or direct probing of the flash chip, but once you can load or execute own code, your are "in". So running external code is to be prevented. A CRC is not a protection, because it does not rely on a secret.
Booting into safe boot prevent loading of main.py and boot.py and gives access to REPL. At least, i do not see in the sources where this is prevented. Then, any code can be pasted & executed. Functions like ustruct.bytes_at(addr, len) allow direct access to flash memory, which can be read & dumped, I assume it is unencrypted. That includes the area of frozen bytecode and the internal file system. -
I c. That is quite a vulnerability. Would you say that if we can get the REPL on the COM port password protected that the Pycom devices should be secure enough?The last thing I want is to roll out devices and a few months/years I read in the media that 'my super product' has been hacked and is being used to gain acces to user,s WiFi etc.
@inverseeffect The ESP32 is in no way a secure processor. It is simply not built for that purpose. If you need one, look at the secure processors of Maxim, TI and Freescale. Besides that, you get some low level obstacles with the ESP32. It is like all other properties of the ESP32 (I'm not talkling about the pycom integration). Many features for a low price, all built on a mediocre quality level.
@inverseeffect It should be possible to disable safeboot in secure mode. A fallback for recovery would then erasing the whole flash.
@robert-hh I like this approach. I am use to baremetal micro controllers where read out protection is enabled and the only way is to erase the flash to reprogram the micro controller. (I just don't want to baremetal C anymore :), especially string handling and networking ) I can't see why the ESP32 should be any different except for the external SPI flash, but that is why the flash encryption feature exists.
This is an interesting discussion. We could add your conclusions to our future development list.
We were looking into a couple of things to increase security:
- encrypted serial REPL (disabling UART clear text and telnet)
- encrypted FTP (disabling clear FTP)
<later edit:> The Flash Encryption and Secure Boot features have the role to protect ESP32 firmware. Now, furthermore, the micropython scripts are indeed not really .
secured. -
@catalin Don't forget to lock the JTAG interface (if possible).
@catalin That will be great, or even just password protection on all interfaces or the ability for the user (the developer) to have more control on what happens when safe boot is executed.
Can you explain what flash sections are encrypted when flash encryption is enabled? Meaning the ESP32 onboard/builtin flash and/or the external SPI flash.
Never mind I found it here: http://esp-idf.readthedocs.io/en/latest/security/flash-encryption.html -
@inverseeffect The standard ESP32 has no built-in flash. It is all external SPI flash. However, there is a variant which has 2 MB Flash embedded (ESP32-D2WD), but that chip is not used for Pycom devices.
@robert-hh said in Security - IP Protection:
There is a fuse to disable JTAG (JTAG_DISABLE). Furthermore, unless you build a firmware with DEBUG enabled, the JTAG IO pins are re-initialised as inputs with pull-down enabled during micropython startup.
