    NB-IoT on fipy
    nb-iotfipyamarisoft
    7 Posts 4 Posters 2.2k Views 7 Watching
    • N Offline
      nalexopo
      Hello, I ve been trying to make nb-iot work on fipy. I have a base station "Amarisoft LTE 100" connected on a PC and I try with inband nb-IoT. I have managed to send data with SODAQ nb-iot shield.
      I made all the firmware updates on fipy as instructed and I ran this code on the same SIM as in sodaq. Modem is responding however I should be seing the device on the basestation pc after running the modem settings and I dont. I run
      lte.isattached() and returns false. Am I doing something wrong?
      from network import LTE
      lte = LTE()
      lte.send_at_cmd('AT+CFUN=0')
      lte.send_at_cmd('AT!="addscanfreq band=20 dl-earfcn=6300"') # I also used dl-earfcn=6309
      lte.send_at_cmd('AT!="zsp0:npc 1"')
      lte.send_at_cmd('AT+CGDCONT=1,"IP","default"')
      lte.send_at_cmd('AT+CFUN=1')
        jmarcelino @nalexopo
        Hi @nalexopo
        I only used Cat M1 with Amarisoft but I think someone from the team also used it with NB-IoT.
        I'll try to find out how it was done, I think it needs some different settings.
        • N Offline
          nalexopo
          Hello @jmarcelino
          Any news on this?
          • I Offline
            ialkhouri @jmarcelino
            Hi @jmarcelino
            I am trying the exact same thing on GPy and i am facing a similar issue.
            Your quick response is much appreciated.
            lte = LTE()
            def send_at_cmd_pretty(cmd):
            response = lte.send_at_cmd(cmd).split('\r\n')
            for line in response:
            print(line)
            send_at_cmd_pretty('AT+Cmee=2')
            time.sleep(1)
            send_at_cmd_pretty('AT+CFUN=0')
            time.sleep(1)
            send_at_cmd_pretty('AT!="clearscanconfig"')
            time.sleep(1)
            send_at_cmd_pretty('AT!="addscanfreq band=3 dl-earfcn=1584"')
            time.sleep(1)
            send_at_cmd_pretty('AT!="zsp0:npc 1"')
            time.sleep(1)
            send_at_cmd_pretty('AT+CGDCONT=1,"IP","test123"')
            time.sleep(3)
            send_at_cmd_pretty('AT+CFUN=1')
            for i in range(39):
            time.sleep(1)
            print('sleeping for 30 seconds')
              Aris
              Hello @jmarcelino,
              do you have any updates on the matter? We have 5 FiPys laying in the box as we cannot connect them to our Amarisoft NB-IoT test network. We had contact Pycom's sales department before buying the modules and we were assured that we would be able to connect them to our network.
                Aris
                any update on this?
                • N Offline
                  nalexopo
                  @jmarcelino I am still in need of a way to use NB-IoT on fipy. Is there a way to achive it? As I can see others have the same problem as me, so can we have some update on the state of the matter?
