Object with buffer protocol required.
Hello all,
I am trying to use the UART of a WiPy 3.0 to send data to a computer. I can read data in just fine but get an error when trying to transmit data stating object with buffer protocol required. Basically I send 0xA1 then 0xFE to the WiPy module from the computer and store it in a variable uart_Rx_buffer. Later, I wish to send the second byte 0xFE back to the computer.
definition of uart_Rx_buffer:
uart_Rx_buffer = [0, 0]The rest of my code:
if uart.any(): #check for data in stream receive buffer uart_Rx_buffer = uart.read(2) #read and store 2 bytes of data, this also clears the stream receive buffer if uart_Rx_buffer[0] == 0xA1: services = BluetoothConnection.services() #get services from connected device for service in services: chars = service.characteristics() #get characteristics from services of connected device for char in chars: #scroll through characteristics and write to any that have correct set properties if (char.uuid() == 22): #char.write(chr(int(bin(uart_Rx_buffer[1])))) #write UART data to characteristic #print(uart_Rx_buffer[1]) uart.write(uart_Rx_buffer[1]) #echo data back to MSP430I've seen this thread, but the answer is to convert the data to a string.. which outputs 3 bytes, in ascii 2, 5, 4.. which is correct 254 = FE but I want to transmit one byte that is 254. How can I do this?
@nick9995 said in Object with buffer protocol required.:
try this:
uart.write(bytes(uart_Rx_buffer[1]))i write from memory i heave not device currently on hand
Thanks for the reply. I did try it but I just get 0x00 transmitted out like 30 ish times...
I had it commented out but:
uart.write(chr(int(bin(uart_Rx_buffer[1]))))This line works to send the byte stored in uart_Rx_buffer[1] so long as the byte is stored as the decimal value.
For example, 0xFE = 254 in decimal. If I load uart_Rx_buffer[1] with 0xFE, I just get errors no matter what I try. If I load it with 254, it works just fine.
Since I am at my deadline for this project, I will just stick with my current solution since it is acceptable. I was hoping to solve this issue but it is more of a curiosity than necessity.
@nick9995
uart.write(bytes([uart_Rx_buffer[1]])) -
@livius Thank you so much!!! That works for me! Not sure how long it would have taken me to properly use brackets [ ].
