    Precise pulse duration
    lopy4pythonpulse
    4 Posts 3 Posters 703 Views 3 Watching
      berni
      I am trying to to do a pulse of a given duration (e.g. 2.000 ms) on a digital output. Ideally, I don't want to stop the code with a while True:
      At the moment, I am trying with Timer.Alarm but I have the feeling that I am not getting an accurate timing.
      p_out = Pin('P19', mode=Pin.OUT)
      def pulse_off(timer):
          p_out(0)
      # Perform a pulse of 2000ms
      p_out(1)
      pulse_timer = Timer.Alarm(self.pulse_off, ms=2000, periodic=False)
      Could anyone give some advice on the most accurate way to perform a pulse? Thank you in advance!
        robert-hh @berni
        @berni The RMT class could be used for that.
          jmarcelino @berni
          @berni
          Indeed RMT would be the best way to generate pulses, https://docs.pycom.io/chapter/tutorials/all/rmt.html.
          The maximum single pulse width is ~ 100ms but you should be able to chain multiple together
            berni
            Thank you @robert-hh and @jmarcelino! I will give it a go and report back. :-)
