    LoRaWAN TTN Uplinks Ok, no Downlinks. Channel issue? Help! ;)
    lopy4lorawanttn
    20 Posts 4 Posters 3.2k Views 5 Watching
      AidanRTaylor
      Hey I got some bits! It's pretty intermittent though, the device is still missing the majority of downlinks, that's the first successful packet I have seen though!
        AidanRTaylor
        It's also missing most Uplinks now, whereas it was catching most with the previous code
          jmarcelino @AidanRTaylor
          @aidanrtaylor
          Maybe the gateway you're using or have access to is single channel?
          Expand the received packets on the Data tab and look at the frequency used. If they're all on the same frequency then your gateway is probably single channel.
            AidanRTaylor @jmarcelino
            @jmarcelino I have access to the gateway - is it something I can check on there?
              AidanRTaylor
              I can't consistently get packets up or down now that I have modified the code :( The original code only gets consistent uplinks. Is there anything else I have missed or 'fudged'?
              I haven't been able to get another Downlink to expand.
              # LoPy4_files/main.py
              from network import LoRa
              import binascii
              from machine import Pin
              import struct # no idea what this does - need to read up on it
              # Configure IO Pins:
              configPin = Pin('P21', Pin.IN, Pin.PULL_UP) # Pull low to exit to REPL
              LoRaPin = Pin('P22', Pin.IN, Pin.PULL_UP) # Pull low to enable LoRa
              #Set AppEUI and AppKey - use your values from the device settings --> https://console.thethingsnetwork.org/
              dev_eui = binascii.unhexlify('***')
              app_eui = binascii.unhexlify('***')
              app_key = binascii.unhexlify('***')
              # initial read from IO pins:
              config = configPin()
              radio = LoRaPin()
              # In 'config mode' exit to the REPL, and print the LoRa DevEUI:
              if not config:
                  print('Config Mode')
                  lora = LoRa()
                  print("DevEUI: %s" % (binascii.hexlify(lora.mac()).decode('ascii')))
              # Otherwise, we probably want to activate LoRa:
              if not radio:
                  pycom.rgbled(0x7f0000) #red
                  lora = LoRa(mode=LoRa.LORAWAN, region = LoRa.EU868)
                  # # Remove all the non-default channels
                  # for i in range(3, 16):
                  #     lora.remove_channel(i)
                  # print('Removed default channels')
                  # time.sleep(1)
                  # # Set EU ISM 868 channel plan for TTN Europe
                  # lora.add_channel(0, frequency=868100000, dr_min=0, dr_max=5)
                  # lora.add_channel(1, frequency=868300000, dr_min=0, dr_max=5)
                  # lora.add_channel(2, frequency=868500000, dr_min=0, dr_max=5)
                  # lora.add_channel(3, frequency=867100000, dr_min=0, dr_max=5)
                  # lora.add_channel(4, frequency=867300000, dr_min=0, dr_max=5)
                  # lora.add_channel(5, frequency=867500000, dr_min=0, dr_max=5)
                  # lora.add_channel(6, frequency=867700000, dr_min=0, dr_max=5)
                  # lora.add_channel(7, frequency=867900000, dr_min=0, dr_max=5)
                  # print('EU channels set')
                  time.sleep(1)
                  #Join TTN Network via OTAA
                  lora.join(activation=LoRa.OTAA, auth=(dev_eui, app_eui, app_key), timeout=0, dr=0)
                  print('Trying to join TTN Network...')
                  while not lora.has_joined():
                      pycom.rgbled(0x7f7f00) #yellow
                      time.sleep(5)
                      print('...')
                      pass
                  print('Network joined')
                  pycom.rgbled(0x009999) #teal
                  # Now let's send some data...
                  # create a LoRa socket
                  # set the LoRaWAN data rate
                  while lora.has_joined():
                      print('Sending some bits:', bytes([0x01, 0x02, 0x03]))
                      # make the socket blocking
                      s.setblocking(True)
                      time.sleep(0.5)
                      print('Listening for bits:')
                      s.setblocking(False)
                      data = s.recv(64)
                      print(data)
                      time.sleep(30)
                  print('Connection lost')
                @aidanrtaylor
                Can you look at the received frequencies on the TTN console?
                What is your gateway?
                  @jmarcelino Hey - I am getting successful downlinks now. I reverted back to my original code, but I changed the parameters for socket.setsockopt, I changed the last field (data rate?) from 5 to 1 and I am getting consistent robust results now.
                  In answer to your questions - the Gateway doesn't belong to me but the owner gave me access to it for troubleshooting - I'm not sure which parameters would be relevant to you.
                  Anyway, on the console I can't get any useful information from the successful downlinks as far as I can tell. But the metadata on the received Uplinks is showing different frequencies for each result - so I guess we are good there.
                  Onwards and upwards! For reference this is the code I have ended up with:
                  import binascii
                  radio = LoRaPin()
                  if not config:
                      lora = LoRa()
                  if not radio:
                      time.sleep(1)
                      time.sleep(1)
                          time.sleep(5)
                          print('...')
                          pass
                      s.setsockopt(socket.SOL_LORA, socket.SO_DR, 1)
                          s.setblocking(True)
                          time.sleep(0.5)
                          data = s.recv(64)
                          print(data)
                          time.sleep(30)
                  • Charly86C Offline
                    Charly86 @jmarcelino
                    @jmarcelino if you use another backend with OTAA, how can we check in lopy code if the GW has sent the other channels? I programmed them on the GW but want to be sure they were deployed to the end device ;-)
                      jmarcelino @Charly86
                      @charly86
                      If you set (add_channel) the first three channels (EU868 only) to the same, but alternate, frequency you can verify if the gateway is picking that frequency up.
                      lora.add_channel(0, frequency=FREQUENCY, dr_min=0, dr_max=5)
                      lora.add_channel(1, frequency=FREQUENCY, dr_min=0, dr_max=5)
                      lora.add_channel(2, frequency=FREQUENCY, dr_min=0, dr_max=5)
                      Is that you mean? Or do you mean reassigning the RX2 window?
                      Charly86C 1 Reply Last reply Reply Quote 0
                      • Charly86C Offline
                        @jmarcelino thanks
                        In fact, I mean you said for TTN, OTAA download all usable channels send by the backend.
                        But I want to be sure my LoPy received it and can use the 8 instead of forcing adding manually the 5 others on the LoPy Code
                        But I can see in GW log if is use the other frequencies
                          @charly86
                          Oh OK so if you do more than 3 sends in quick succession it should use the extra channels
                          Set it with a low DR to make sure, i.e.: s.setsockopt(socket.SOL_LORA, socket.SO_DR, 0)
                          There isn't a function to check the current channel map in use so I think this is the simplest way.
                            robert-hh @Charly86
                            @charly86 I see a problem at the moment with TTN, in that uplink packets using TCP show up at the Data tab of the console very late, wheres UDP packets pop up immediately. If the gateway is using TCP, the downlink messages may be sent too late,
                            • Charly86C Offline
                              @jmarcelino oh I see, thanks.
                              While writing, if after join I remove channel 0, 1 and 2 it should use the other? Should works for testing?
                                @charly86
                                Because those are mandatory channels you can't remove the 3 default channels in EU868, you can only change their frequency (but the frequency can be the same for all three)
                                Charly86C 1 Reply Last reply Reply Quote 1
                                • Charly86C Offline
                                  @jmarcelino Hey, got it, thanks
                                  As you suggested I'll write a prog to quick send data and looks on my backend for frequencies of received packet ;-)
                                  Look like the faster way
