    Changing LoRa parameters - Is necessary to restart device?
    lora classlora lopyloramac
    1 Posts 1 Posters 554 Views 2 Watching
      lsoria
      Hi all,
      I'm working with lopy4 in raw LoRa mode. I've implemented methods to change the radio settings (SF, CR, BW, among others) and store the configuration in a JSON file. The fact is that those changes are not visible after I reset both node and gateway (My code is based on LoRa-MAC Nano-Gateway). Is that correct? invoking the method lora.sf([sf]) for example does not make any changes.
      Here is my method implementation:
          def changeLoraSettings(self, lora_conf):
              # print('Changing LoRa configuration...')
              [lora_bw, lora_cr] = self.parseData(lora_conf)
              self.lora.frequency(lora_conf['frequency'])
              self.lora.tx_power(lora_conf['tx_power'])
              self.lora.bandwidth(lora_bw)
              self.lora.sf(lora_conf['sf'])
              self.lora.preamble(lora_conf['preamble'])
              self.lora.coding_rate(lora_cr)
              # print('done')
           def parseData(self, lora_conf):
              if(lora_conf['bandwidth'] == '125 KHZ'):
                  lora_bw = LoRa.BW_125KHZ
              elif(lora_conf['bandwidth'] == '250 KHZ'):
                  lora_bw = LoRa.BW_250KHZ
              elif(lora_conf['bandwidth'] == '500 KHZ'):
                  lora_bw = LoRa.BW_500KHZ
              if(lora_conf['coding_rate'] == '4/5'):
                  lora_cr = LoRa.CODING_4_5
              if(lora_conf['coding_rate'] == '4/6'):
                  lora_cr = LoRa.CODING_4_6
              if(lora_conf['coding_rate'] == '4/7'):
                  lora_cr = LoRa.CODING_4_7
              if(lora_conf['coding_rate'] == '4/8'):
                  lora_cr = LoRa.CODING_4_8
              return [lora_bw, lora_cr]
      lora_conf is a dictionary which is stored as a JSON file:
      def lora_default_config():
          lora_conf = {}
          lora_conf['region'] = 'AU915'
          lora_conf['frequency'] = 915000000
          lora_conf['tx_power'] = 20
          lora_conf['bandwidth'] = '125 KHZ'
          lora_conf['sf'] = 7
          lora_conf['preamble'] = 8
          lora_conf['coding_rate'] = '4/5'
          lora_conf_encoded = ujson.dumps(lora_conf)
          with open("/flash/lora.json", 'w') as conf_file:
              conf_file.write(lora_conf_encoded)
              conf_file.close()
      I will provide any other information you shall need. Thanks in advance!
