    New development firmware release v1.19.0.b1
    Scheduled Pinned Locked Moved Beta Announcements & Development News
    firmware
    22 Posts 10 Posters 5.7k Views 10 Watching
      soulsurfer
      Further to this thread:
      https://forum.pycom.io/topic/3207/uasyncio-support
      does the the new dev release include uasyncio support?
      T 1 Reply Last reply Reply Quote 2
      • bmarkusB Offline
        bmarkus
        Which file system used? Is it readable on WINDOWS/LINUX?
        • X Offline
          Xykon administrators @bmarkus
          @bmarkus said in New development firmware release v1.19.0.b1:
          We're now using LittleFS for the internal flash file system in the development firmware rather than FatFS. SD cards keep using FatFS. There is a Fuse wrapper available.
          Christian Ehlers
          bmarkusB 1 Reply Last reply Reply Quote 1
            timh @soulsurfer
            @soulsurfer Truly hope this has made it in.
            • bmarkusB Offline
              bmarkus @Xykon
              @xykon said in New development firmware release v1.19.0.b1:
              Thanks, I will try it. LittleFS looks good, however lack of timestamp can be an issue in certain applications, even if in many cases it is not important and device is not time synced.
              • X Offline
                We are more concerned about users loosing all their code on the device because the file system got corrupted and reformatted during boot. If you need an fs with timestamps, you can connect an external SD card which still uses FatFS (so you can update the content on a PC).
                Christian Ehlers
                • rcolisteteR Offline
                  rcolistete @iwahdan
                  @iwahdan
                  Any eletric current measurement already made on this light sleep mode ?
                  • I Offline
                    iwahdan @rcolistete
                    Hi @rcolistete , yes in light sleep mode the current consumption on a Lopy is 3.5 mA with RTC peripherals ON
                    Wahdan
                      Sympatron @Xykon
                      @xykon I looked into LittleFS and it supports custom attributes per file/folder. So I think timestamps can be implemented. Is there any plan to do so?
                      • X Offline
                        Xykon administrators @Sympatron
                        @sympatron said in New development firmware release v1.19.0.b1:
                        I will ask the developer who implemented LittleFS to look into that. It would help if you could provide a use case where this is relevant.
                        Christian Ehlers
                          Sympatron @Xykon
                          @xykon I don't have a specific use case. I just wanted to point out that it would not be too hard to implement, because @bmarkus said it might be an issue for some people.
                          For us it is a lot more important when this version will be available on GitHub. Since we use a custom firmware we cannot really use the new features until I can merge them with our fork.
                            gregcope @iwahdan
                            @iwahdan what is the assumed current category consumption in light sleep mode?
                            • I Offline
                              iwahdan @gregcope
                              Hi @gregcope for light sleep current consumption is 3.5 mA
                              Wahdan
                                robert-hh @iwahdan
                                @iwahdan machine.sleep(time): the time seem to be ms, not us.
                                • I Offline
                                  iwahdan @robert-hh
                                  @robert-hh yes it is a mistake in my post, I’ve corrected it
                                  Wahdan
                                    Sympatron @Xykon
                                      Colateral
                                      Do you push it in github for make build? There is still 1.18.0.
                                        Sympatron @Colateral
                                        @colateral It's in the development branch.
