    Multitech Conduit
    41 Posts 12 Posters 25.5k Views 12 Watching
      arneme @arneme
      @arneme I took the global_config.json generated by the Network server (when using Daniels original setup of the Network server) and using this file (modified with our network server DNS name) to configure the basic packet forwarder (and setting the Conduit in basic packet forward mode) I actually managed to connect the LoPy. Our network server is now receiving packets from the LoPy after successful join.
        @arneme that's good news. Were you able to understand what part of the config is affecting the behavior of the join procedure?
        • E Offline
          egnoske
          I see some folks report that they can connect their LoPy to the Multitech Conduit however I have 0% success on LoPy while I have 100% success on mDot. Are there any absolutely working py scripts with matching conduit configs out there?
          I currently have an identical setup as jubbs and identical results...
            stuart
            I recently purchased a second LoPy as I previously thought I may have damaged the first one by not immediately attaching the external RF aerial.
            However, I'm still experiencing the same issues on the second LoPy (my LoRaWAN configuration is further down this thread). I still can't connect to the network using OTAA with the Conduit gateway which is pretty frustrating (especially given that other folk seem to have achieved this).
              arneme
              After upgrading my LoPy to the latest firmware (release='0.9.6.b1', version='v1.8.6-40-gd10463e on 2016-11-25') I am not able to connect to a Multitech gateway (in basic packet forwarder mode) anymore :-(
                @arneme Can you provide any logs from the Multitech Gateway? That might help understand the problem.
                We are working this week on fine tuning the timing of the LoRa stack and we are sending our modules for LoRaWAN certification.
                  arneme @daniel
                  @daniel I can provide you with logs, just tell me what you want. I can even allow you to login and install software on the gateway if you want to use your own customised packet forwarder (i.e. to get more verbose log output) or monitoring tool.
                    arneme
                    Upgrading the LoPy to the latest version (0.9.7.b1) and getting the order of the parameters right in the auth part of lora.join() call fixed the problem (yes, the order of the parameters actually changed between versions). The LoPy is now again working towards our Multitech stations :-)
                    K G 2 Replies Last reply Reply Quote 1
                    • K Offline
                      kiwi64ajs @arneme
                      @arneme said in Multitech Conduit:
                      Ok, so what was the order previously and what order did you have to make it to work now?
                      Regards
                      Alex Shepherd
                        arneme @kiwi64ajs
                        @kiwi64ajs said in Multitech Conduit:
                        For new revisions of the firmware just follow this (scroll down for the OTAA part):
                        https://docs.pycom.io/pycom_esp32/library/network.LORA.html?highlight=lora
                        As you can see there the DevKey is now implicitly set to the MAC of the device and the order of the remaining parameters in the authorisation part of parameters in join is: AppEUI, AppKey
                        The join used to take three parameters in the authorisation part and the order used to be: AppKey, AppEUI, DevEUI
                          gertjanvanhethof Pybytes Beta @arneme
                          @arneme Just a question: Did you test the max range of these stations? I thinking about buying one, but I have thoughts about the range it can cover.
                            cmsedore
                            @gertjanvanhethof Our testing of the Multitech Conduit has given range out to about 10km, depending on the intervening geography. We have been using the Multitech mDots for our testing thus far because the LoPy is not transmitting on the right frequencies as best I can tell. We have the Conduit installed on the roof of a four story building with an omnidirectional outdoor antenna. It is moving to another building roof 20 stories up in a few weeks and I expect range to improve.
                            We coupled the mDots to GPS receivers and have them beacon their location every 5 seconds--we can then drive around and generate a coverage map. I would like to use the LoPy for this, but the add/remove channel function doesn't seem to quite work (or I am not using it correctly) to get the frequencies set for the correct sub-band. In the US, we have 64 channels and the Multitech will only receive on 8, so the channels need to be configured for sub-band 2. I can get the LoPy to join via OTAA and send data, but only 1 out of 5 to 8 attempts/messages are successful.
                            Our gateway forwards to The Things Network. TTN works well and we pick up the transmitted data via MQTT and stick it in a database. (And, in the case of the GPS beacons, use a little PHP to generate a KML file to overlay the data on a Google map).
                              Thxs for your answer.
                              I thinking about buying one.
                              I talked a guy yesterday and gave me some advice about which antenna to use and which cable.
                              But regarding the error you talked about: I connected my LoPy to a TTN gateway successfully but had to slow down the sending with a sleep(2) a bit. Not doing this caused an LoRa error.
                              Probably the same you have. So try a sleep(2) between each message.
                                cmsedore
                                Thx--I'm not actually getting any errors: from monitoring the logs on the gateway, it seems that the RF packet is not seen/received by the gateway. If it does not approve after the firmware update this week, I plan to set up an RF sniffer and see if I can track down what frequencies are actually being used.
                                  arneme @gertjanvanhethof
                                  @gertjanvanhethof We are experiencing LOS of up to 20km using the standard (20cm) antenna on devices.
                                  • H Offline
                                    harish
                                    • 2 / 3
