    Potential device lockdown - Network providers
    gpycat-m1fipytelstra
    42 Posts 12 Posters 11.1k Views 15 Watching
      timh @jcaron
      @jcaron I have confirmed with the Telstra Engineer that we need to be on band 28, in addition all connections must be access technology must be E-UTRAN
      How I might achieve that I am not sure. Tried many different things today but as I pointed out earlier Telstra don't see an attempt to connect in the traces.
      I will contact the engineer again tomorrow, and try and pin them down on possible network changes on the 15th. However I had gear online up to the 16th of June in Newcastle at 1:43pm WST. I can't be certain they disconnected at that point due to Telstra or our field staff turning the equipment off.
      So we have a few different dates and a fairly broad window for a change to have occurred.
        tealbrains @timh
        @timh I can't pinpoint the exact time but it definitely happened between the 15th-16th and the 18th. Things were working before the weekend: we drove around to measure the RSSI in different locations. I went back to work on Monday and that was it... no more connections were made.
          timh @tealbrains
          @tealbrains not having much luck with Telstra
          I received this response this morning.
          The INC has been closed due to the findings from WMO engineers.
          The engineers resolution is as follows:
          No network issue for any of the devices. We believe that the issue is the device configurations.
          This is due to not being able to see the service request coming onto the Telstra Network.
            timh @timh
            @timh I just spoke to the engineer I have reported to and they said hey isn't closing the issue.
            He understands that something has changed in the Telstra network that has caused the PyCOM devices to not be able to register.
            However he did say the PyCOM devices have not gone through an approval process for Telstra network.
            We really need some response from PyCOM people on this issue. (There are a lot of companies reselling the product in Australia which will not work here)
            T M 2 Replies Last reply Reply Quote 0
              tealbrains @timh
              @timh
              That is the bit that worries me. What does it mean exactly? I contacted Sequans but haven't heard anything back from them. No admin has chimed in, I guess Pycom is no longer an option for my current projects... I am happy to pay a premium price for hardware if we get suppport. If there is no support then...I don't know where the value is.
              EDIT:
              Just came across this:
              https://pycom.io/state-lte-m/
              So, in other words. Don't develop a commercial solution around Pycom+LTE. You'll have issues.
                robert-hh @tealbrains
                @tealbrains Being in Germany, one topic of this table is confusing. Pycom does not Talk to Deutsche Telekom, but is in discussion with T-Mobile, which is a brand of Deutsche Telekom, at least in Germany.
                But this is just a little inconsistency. More sad: T-Mobile does sell NB-IOT SIMs only to commercial customers. The smallest package you can get is 50 SIM cards. They announced a flat rate card (10€, 10 years, x MB data) last August, but no one at T-Mobile and Deutsche Telekom Sales & Shops knows how to get it.
                  micksta @timh
                  @timh
                  Hey timh & tealbrains, appreciate the contact & follow up with Telstra. I believe in the early day's Pycom had some chats with Telstra, hopefully they still have those contacts. I'm also on the tealbrains path & looking for a solid option for several projects. Thanks guy's - product had promise.
                    Apologies for the lack of response. We have a new Cat-M1 firmware which should solve the issues with Telstra. This firmware will be available in a few hours on this link: https://software.pycom.io/downloads/sequans.html (FIPY_GPY_CATM1_36417.dup). In order to connect, the attach command should be as follows:
                    AT!="RRC::addScanBand band=28"
                    After that, then send (do not call lte.attach() explicitly):
                    AT+CFUN=1
                    Regards,
                    T I 3 Replies Last reply Reply Quote 0
                      timh @daniel
                      @daniel Hi Daniel
                      Thanks for the update.
                      Can you provide the full connection details. As you can see the in the other threads we spent quite a bit of time trial and error working out how to connect to Telstra.
                      For instance we have all been sending
                      AT!="RRC::addscanfreq band=28 dl-earfcn=9410"
                      Is that relevant now ?
                      Some clear repeatable instructions would be really good.
                      Tim
                        timh @daniel
                        @daniel oh and the firmware isn't available yet (a few hours have passed ;-)
                        • X Offline
                          Xykon administrators @timh
                          @timh said in Potential device lockdown - Network providers:
                          The file is now only available.
                          Christian Ehlers
                            timh @Xykon
                            @xykon Awesome. Thanks
                              micksta @timh
                              @timh
                              Telstra still no go (for me anyway'z), seems to find tower but then issues out - tried several location around town.. Some notes below.
                              Modem f/w --> FIPY_GPY_CATM1_36417.dup
                              (sysname='GPy', nodename='GPy', release='1.17.5.b6', version='v1.8.6-849-56d00234 on 2018-05-18', machine='GPy with ESP32')
                              I'm not calling lte.attach(), use 'AT+CFUN=1' for that --> snippet of below below was definitely working before changes to telstra network
                              'AT!="addscanfreq band=28 dl-earfcn=9410"' # lte frequency band - from forum
                              AT+CGDCONT=1,"IP","mdata.net.au"' # Aldi sim / Aldi APN (aka Telstra network)
                              FSM (loops through the below)
                              SCANNING
                              SYNCING
                              STOPPED
                              -------- e.g. --------------------------------
                              SYSTEM FSM
                              | RRC TOP FSM              |SYNCING             |
                              | RRC SEARCH FSM           |WAIT_SYNC           |
                              | RRC ACTIVE FSM           |NULL                |
                              | PMM PLMN FSM             |NORM_WAITCELL       |
                              | EMM AUTH FSM             |KASME_DEFINED       |
                              DL SYNCHRO STATISTICS (loops through some of the below but random)
                              CELL_SEARCH
                              FAST SCAN
                              FRAME_UPDATE
                              MIB_DETECT
                              IDLE
                              RSRP
                              Synchro state                         : CELL_SEARCH
                              PPU SIB1 ACQ watchdog                 : 0
                              Frequency Hypothesis RF  (Hz)         : 0
                              RSRP (dBm)                            : -21474836.00
                              RSRQ  (dB)                            : 0.00
                              Channel estimation state (Cell-spec.) : LOW CINR
                              Channel estimation state (UE-spec.)   : LOW CINR
                              Channel estimation state (MBSFN)      : LOW CINR
                              Channel estimation CINR               : 5.62
                              Channel length                        : SHORT
                              AGC
                              AGC RX gain (dB)                      : 60.22
                              RX PSD BO (dBFs)                      : -23.42
                              RX PSD (dBm)                          : -111.79
                              Noise level RS (dBm)                  : -128.24
                              Digital gain (dB)                     : 4.78
                              CINR RS (dB)                          : 0.00
                              NARROWBANDS
                              Last DL NB                            : Central
                              Last UL NB                            : 0
                              AFC
                              Frequency offset RF  (Hz)             : -379
                              Frequency offset BB  (Hz)             : 0
                              PBCH
                              MIB received quantity                 : 21
                              MIB timeout quantity                  : 0
                              WITH CREG SHOWING
                              +CREG: 2,0
                                timh @micksta
                                @micksta bugger ;-( I haven't had a chance to test myself yet. Up to my eyeballs. Hoping later this afternoon.
                                Some my guidance on specifics from @daniel or @xykon would help a lot.
                                  tealbrains
                                  Not only it is not working for me but it is even worse now (I did not think it could get any worse but it did.)
                                  I am not able to get a CCID from the (M2Mone) SIM card when issuing:
                                  send_at_cmd_pretty('AT+SQNCCID')
                                  I thought it would maybe be an issue with the SIM card itself so used a GPY that still had the previous modem firmware (FIPY_GPY_CATM1_33988.dup) with the same SIM card and it worked.
                                  So, summarising:
                                  • GPy on stable 1.18.0 with FIPY_GPY_CATM1_33988 -> Lost Telstra connectivity a few weeks ago but it can talk to the SIM card.
                                  • GPy on stable 1.18.0 with FIPY_GPY_CATM1_36417 -> Can't talk to SIM card, which I believe is what is producing an ERROR response when issuing
                                  send_at_cmd_pretty('AT!="RRC::addScanBand band=28"')
                                  It would seem we are taking one step forward and two steps backward...
                                  If @micksta, @timh and @Prawnhead can confirm this behaviour the problem is still there.
                                  P T 2 Replies Last reply Reply Quote 0
                                    tealbrains
                                    @tealbrains said in Potential device lockdown - Network providers:
                                    So, summarising:
                                    If @micksta and @Prawnhead can confirm this behaviour the problem is still there.
                                    EDIT:
                                    The SIM command does work, eventually. I think the new pycom firmware blocks some commands sometimes if the modem is busy.
                                    @daniel
                                    A bit of extra info would be nice. The way the first command you mentioned needs to be sent is slightly different.
                                     send_at_cmd_pretty("AT!=\"RRC::addScanBand band=28\"")
                                    It must include the escape characters, otherwise it seems to produce an ERROR. The modem won't attach though.
                                      micksta @tealbrains
                                      @tealbrains
                                      Here works no probs, have 2 GPY's - different revs of modem f/w.
                                      Using (Aldi Sim aka Telstra & below GPy f/w)
                                      send_at_cmd_pretty('AT+SQNCCID?') # reads the ICCID ID on the SIM card.
                                      I'm also using (as @Daniel suggested below AT!)
                                       - System FSM & Synchro Stats still loops with no connection (although it does seem to see the tower) . CREG still stuck  --> +CREG: 2,0
                                        tealbrains @micksta
                                        @micksta I am guessing the AT+SQNCCID is what works without problems, right? It's a different story for the Cat-M1 connection. If you can't connect either I guess the issue is not resolved then...
                                          micksta @tealbrains
                                          @tealbrains
                                          Sure CCID no prob's --> same no Connection. Had a look at some alt. LTE M1 products (googled "Certified Modules and Devices - Telstra") & ordered several SIM7000E. Will be interesting to compare.. Hopefully the Pyboards make the list soon.
                                            Prawnhead @tealbrains
                                            So, summarising:
                                            I'm using this as minimum viable code:
                                            from network import LTE
                                            def at_cmd(command):
                                                print("Command:  {}".format(command))
                                                result = lte.send_at_cmd(command)
                                                print("Response: {}".format(result))
                                            print(os.uname())
                                            lte = LTE()
                                            at_cmd('AT+CGDCONT=1,"IP","telstra.internet"')
                                            at_cmd('AT!="addscanfreq band=28 dl-earfcn=9410"')
                                            at_cmd('AT+CFUN=1')
                                            for x in range(20):
                                                print("Attached? {}".format(lte.isattached()))
                                                time.sleep(1)
                                            machine.reset()
                                            Result is always:
                                            >>> Running Z:\Content\Content2\Chris\Pycom\Pycom GPy\Pycom Forum 2878\connect0.py
                                            (sysname='GPy', nodename='GPy', release='1.18.0', version='v1.8.6-849-046b350 on 2018-06-01', machine='GPy with ESP32')
                                            Command:  AT+CGDCONT=1,"IP","telstra.internet"
                                            Response:
                                            OK
                                            Command:  AT!="RRC::addScanBand band=28"
                                            Response:
                                            OK
                                            Command:  AT+CFUN=1
                                            Response:
                                            OK
                                            Attached? False
                                            Attached? False
                                            Attached? False
                                            Attached? False
                                            Attached? False
                                            Attached? False
                                            Attached? False
                                            Attached? False
                                            Attached? False
                                            Attached? False
                                            Attached? False
                                            Attached? False
                                            Attached? False
                                            Attached? False
                                            Attached? False
                                            Attached? False
                                            Attached? False
                                            Attached? False
                                            Attached? False
                                            Attached? False
                                            ets Jun  8 2016 00:22:57
                                            rst:0x7 (TG0WDT_SYS_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
                                            configsip: 0, SPIWP:0xee
                                            mode:DIO, clock div:1
                                            load:0x3fff8028,len:8
                                            load:0x3fff8030,len:1728
                                            load:0x4009fa00,len:0
                                            load:0x4009fa00,len:14584
                                            entry 0x400a059c
                                            Pycom MicroPython 1.18.0 [v1.8.6-849-046b350] on 2018-06-01; GPy with ESP32
                                            I have tried 1 x FiPy and 1 x GPy on firmware FIPY_GPY_CATM1_33988.dup and FIPY_GPY_CATM1_36417.dup and have not had a successful lte.isattached() in 20+ attempts. However, I'm not completely confident I've got the minimum viable code right. If someone using Optus or Vodafone could post their minimum code or confirm mine (with whatever settings changes are required) I'd appreciate it!
                                            • Chris
                                            • 1 / 3
