    Cellular radio firmware release (SQN3330) for both Cat-M1 and NB-IoT
    firmware
    48 Posts 18 Posters 17.6k Views 22 Watching
      jmarcelino @flo242
      @flo242
      Please note the modem firmware update process takes quite some time to complete - possibly over the 5 minute mark.
      Please let it do it's thing. Unfortunately its hard to tell what's the state of your modem now without running some diagnostics through the test points.
        JDeclerfayt
        Hi everyone,
        Is there a reason why sequans cellular radio is not upgraded with the gpy last firmware?
        I ask this as the sequans upgrade method never work with our 3 gpy. ( Issue created on https://pycomiot.atlassian.net/servicedesk/ but no answer for now ).
        We waited months for the sequans upgrade so we could use Nb-IOT and progress in our R&D but now we're stucked with 3 pycom we can not use anymore...
        Is it normal people have so much problems with this upgrade?
        Thanks in advance
          danielm
          I successfully managed to upgrade my FiPy. I don't have any GPy but I have custom board with G01 ready. I am not able to try the upgrade, because there is no SD card slot on that board. About 10 days ago Daniel wrote me that they are working on scripts for upgrade through serial interface.
          There was no new firmware release for about a month already. I just hope that there is not any hardware flaw in boards equipped with Sequans LTE modem.
            DDA @danielm
            @danielm
            Could you shed some details on how you resolved the problem?? By manully mounting card-folder (/sd) using script via serial REPL?
            I am having similar similar ussue:
            https://forum.pycom.io/topic/3142/firmware-upgrade-tool-for-the-sequans-monarch-sqn3330
            Thanks a lot.
              Prawnhead
              Hey Guys, I see this has been a problem for a few people and I have battled it for a few hours today. Initially, I was unable to get the firmware update to occur under any conditions. Always the same result:
              <<< Welcome to the SQN3330 firmware updater >>>
              Entering recovery mode
                File "/flash/lib/sqnsupgrade.py", line 100, in run
              OSError: AT+SMSWBOOT=3,0 failed!
              I have now performed the upgrade three times successfully and each time under slightly different conditions. Here's my setup:
              • Pycom GPy (w/ firmware 1.17.5.b2)
              • LTE antenna attached
              • nano SIM for Telstra (Australia)
              • Expansion Board 2.0
              • SanDisk Ultra 16GB microSD card
              Procedure:
              • Remove all partitions from SD and format as single FAT32 partition
              • Copy to SD, FIPY_GPY_CATM1_33988.dup from https://software.pycom.io/downloads/sequans.html. Check file size 5,533KB.
              • Put SIM in GPy. Put SD card in Expansion Board 2.0. GPy on EB2.0
              • Power from USB. Join Wi-Fi AP provided by GPy with password www.pycom.io.
              • Create Atom IDE project folder. Use Settings - Project Settings to set Address: 192.168.4.1. Connect. Do not use Reset button: if reset is required, power down by unplugging, wait 10 seconds, reconnect.
              • Use REPL to check contents of SD card:
              >>> import os
              >>> from machine import SD
              >>> sd = SD()
              >>> os.mount(sd, '/sd')
              >>> os.listdir('/sd')
              ['System Volume Information', 'FIPY_GPY_CATM1_33988.dup']
              • In the Atom project, create a 'lib' folder, add files from https://github.com/pycom/pycom-libraries/tree/master/lib/sqnsupgrade
              • Synchonise with the microcontroller Ctrl-Alt-S
              • Disconnect Atom IDE. Unplug GPy. Wait 10s. Reattach USB power. Reconnect Atom IDE, again, don't use Reset.
              • Begin SQN3330 update at REPL per documentation:
              import sqnsupgrade
              sqnsupgrade.run('/sd/FIPY_GPY_CATM1_33988.dup', 921600)
              • If successful, expect:
              >>> import sqnsupgrade
              Resetting.
              Starting STP (DO NOT DISCONNECT POWER!!!)
              STP started
              Sending 5665583 bytes: [#########################               ]  63%Sending 5665583 bytes: [#########################Sending 5665583 bytes: [########################################] 100%
              Code download done, returning to user mode
              Resetting (DO NOT DISCONNECT POWER!!!).
              Deploying the upgrade (DO NOT DISCONNECT POWER!!!)...
              Upgrade completed!
              Here's the current firmware version:
              UE5.0.0.0c
              LR5.1.1.0-33988
              OK
              Since the first update I also tried the above conditions with the following changes:
              • Serial connection instead of Wi-Fi ... OK
              • Expansion Board 3.0 instead of Expansion Board 2.0 ... OK
              Honestly I think one of two things made the difference: Getting all the libraries loaded and the firmware image on the SD card before powering down. On first power up everything seemed to work the first time. If I reset, or if I'd had a failed attempt, only powering down and restarting made it work again.
              The other option that might have had effect is doing the initial update using Expansion Board 2.0 (no firmware, FTDI only). Maybe once the first firmware update took hold subsequent updates were more likely to succeed.
              Hoping that helps anyone still stuck with this. Chris.
              • K Offline
                kevin
                Is the new NB1 firmware at https://software.pycom.io/downloads/sequans.html ready to use? Are there release notes detailing new feature support?
                I tried to upgrade a GPY to FIPY_GPY_NB1-37365, but it stalled toward the end of the process. I waited about 30 minutes, then reset it. The previous NB1 firmware loads correctly. Any idea why it would hang at the final reset?
                >>> import sqnsupgrade
                >>> sqnsupgrade.run('/sd/FIPY_GPY_NB1-37365.dup', 921600)
                Resetting..
                STP started
                Sending 5050226 bytes: [########################################] 100%
                Resetting (DO NOT DISCONNECT POWER!!!)..............................
                Resetting (DO NOT DISCONNECT POWER!!!)...........................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
                D le_wildfoxL 2 Replies Last reply Reply Quote 1
                  danielm @kevin
                  @kevin
                  I received this info from Daniel:
                  New features compared to release LR6.0.0.0-ER9-36571
                  • Support of standalone mode of operation
                  • Support of Guard-band mode of operation
                  • Non IP PDN data delivery (NIDD)
                  • Support of 3.75KHz NPUSCH Format 1
                  Did not try to update myself yet.
                  F K 2 Replies Last reply Reply Quote 0
                  • le_wildfoxL Offline
                    le_wildfox @kevin
                    @kevin hi! Same issue here. Did you manage to sort it out?
                    Cheers!
                    • F Offline
                      flo242 @danielm
                      @danielm Would you happen to have any changelog for the new Cat-M1 firmware as well?
                      Thanks in advance!
                        danielm @flo242
                        @flo242
                        No, I asked Daniel Campora specifically regarding NB-IoT firmware. I suggest to contact him by email.
                        • K Offline
                          kevin @danielm
                          @danielm Thanks! Anything about band support?
                          • 3 / 3
