    TTN can' show device data of LoPy
    lopy ttn abp
    1 Posts 1 Posters 459 Views 1 Watching
    • Y Offline
      Yunwei
      I'm using two LoPy - one as LoRaWAN nano gateway, another as node device - to test the commnicatoin with TTN.
      I'm using US915 frequency and ABP method.
      Right now I can see the uplink data in gateway data traffic, and also the device status shows it's connected. But there is no data in application data page.
      The status of TTN page shows below:
      1. Gateway traffic
      2. Device overview
      3. Application data:
      My code is below:
      1. config.py
      """ LoPy LoRaWAN Nano Gateway configuration options """
      import ubinascii
      WIFI_MAC = ubinascii.hexlify(machine.unique_id()).upper()
      # Set  the Gateway ID to be the first 3 bytes of MAC address + 'FFFE' + last 3 bytes of MAC address
      GATEWAY_ID = WIFI_MAC[:6] + "FFFE" + WIFI_MAC[6:12]
      SERVER = 'router.us.thethings.network'
      PORT = 1700
      NTP = "pool.ntp.org"
      NTP_PERIOD_S = 3600
      WIFI_SSID = ''
      WIFI_PASS = ''
      # for EU868
      #LORA_FREQUENCY = 868100000
      #LORA_GW_DR = "SF7BW125" # DR_5
      #LORA_NODE_DR = 5
      # for US915
      LORA_FREQUENCY = 903900000
      LORA_GW_DR = "SF7BW125" # DR_3
      #LORA_NODE_DR = 4
      1. main.py
      #####ABP example#####
      from network import LoRa
      import binascii
      import struct
      import config
      # initialize LoRa in LORAWAN mode.
      # Please pick the region that matches where you are using the device:
      # Asia = LoRa.AS923
      # Australia = LoRa.AU915
      # Europe = LoRa.EU868
      # United States = LoRa.US915
      lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.US915)
      # create an ABP authentication params
      dev_addr = struct.unpack(">l", binascii.unhexlify(''))[0]
      nwk_swkey = binascii.unhexlify('')
      app_swkey = binascii.unhexlify('')
      # remove all the channels
      for channel in range(0, 72):
          lora.remove_channel(channel)
      # set all channels to the same frequency (must be before sending the OTAA join request)
          lora.add_channel(channel, frequency=config.LORA_FREQUENCY, dr_min=0, dr_max=3)
      # join a network using ABP (Activation By Personalization)
      lora.join(activation=LoRa.ABP, auth=(dev_addr, nwk_swkey, app_swkey))
      # create a LoRa socket
      # set the LoRaWAN data rate
      s.setsockopt(socket.SOL_LORA, socket.SO_DR, 3)# last parameter is 3
      s.setblocking(False)
      for i in range (200):
          pkt = b'PKT #' + bytes([i])
          print('Sending:', pkt)
          s.send(pkt)
          time.sleep(4)
          rx, port = s.recvfrom(256)
          if rx:
              print('Received: {}, on port: {}'.format(rx, port))
          time.sleep(6)
      I have deleted the data as device address, Network session key,etc.
      Moreover, the OTAA can't work for me, always shows "Not joined yet" when using the sample code from pycom github...
      The firmware version is :
      sysname='LoPy', nodename='LoPy', release='1.17.5.b6', version='v1.8.6-849-56d00234 on 2018-05-18', machine='LoPy with ESP32', lorawan='1.0.2'
      Hope you guys could help me!
