    New Firmware Development release v1.19.0.b4
    Scheduled Pinned Locked Moved Beta Announcements & Development News
    firmwaredevelopment
    33 Posts 15 Posters 9.9k Views 15 Watching
      RodgerG
      Hi @catalin
      This LoRaMesh is great and just what I have been looking for!
      I tried downloading the example file and library and loaded them on to a LoPy4 on a PySense.
      However, I get a strange error on start up (or reset) as below...
      Initializing filesystem as LittleFS!
      LoRa MAC: 70b3d5499625b58c
        File "main.py", line 23, in <module>
        File "/flash/lib/loramesh.py", line 98, in led_state
      OSError: the requested operation is not possible
      Pycom MicroPython 1.19.0.b4 [v1.9.4-50f84dd] on 2018-07-13; LoPy4 with ESP32
      >>> mesh.led_state()
      The call from main.py is as follows
          mesh.led_state()
      and the code on line 98 of loramesh.py is the third line of the following method
          def led_state(self):
              """ Sets the LED according to the Thread role """
              pycom.rgbled(self.RGBLED[self.state()])
      When I just call mesh.led_state() from the command line, there is no such error, as you can see from the console log.
      I tried putting mesh.led_state() in a try-except clause, but still kept getting the same OS error.
      As a workaround, I have copied RGBLED to main, and replaced
      mesh.led_state()
      with
      pycom.rgbled(RGBLED[mesh.state()])
      and this works.
      I cannot see any obviouse reason for the error.
        RodgerG
        @ catalin
        Found the problem
        The example code was missing
        # Make sure heartbeat is disabled before setting RGB LED
        pycom.heartbeat(False)```
        • I Offline
          iwahdan @Harish kumar
          @harish-kumar yes it is possible, however you have to make sure that Arduino only use a single frequency, as Pycom devices can only listen on a single frequency, you should be implementing something like that
          https://docs.pycom.io/chapter/tutorials/lora/lorawan-nano-gateway.html#otaa-over-the-air-activation
          on Arduino.
          Wahdan
          • E Offline
            egimbernat @RodgerG
            @rodgerg When pycom.heartbeat is set to true (By default it is), creates a lock around led operations that's because the OSError. Even if you adquire a lock and iterate around led operations on main thread or an volatile thread pycom.heartbeat will have priority when turned on.
            The solution as you found is to set:
            When you want to gain control over led, sometimes you may need a very small delay in order the heartbeat lock to release. For example:
            pycom.heartbeat(False) #Assuming that it was True
            time.delay(0.05)
            mesh.led_state()
              cmisztur
              @iwahdan Thanks. Should importing uasyncio work in this release ?
              • I Offline
                iwahdan @cmisztur
                @cmisztur, We've done some updates in this Dev release to support including the uasyncio lib from micropython.
                The uasyncio library is provided by MicroPython under micropython-lib: https://github.com/micropython/micropython-lib/tree/master/uasyncio
                Unlike CPython's asyncio library it is splitted into several parts:
                • uasyncio.core
                • uasyncio.queues
                • uasyncio.synchro
                • uasyncio.udp
                • uasyncio.websocket.server
                The uasyncio library relies on the micropython-lib/collections (defaultdict, deque) and logging libraries.
                Note: I've updated my Release post as it was wrongly implying that the uasyncio already included in firmware
                Wahdan
                  soulsurfer @iwahdan
                  @iwahdan - Given the recent change in wording (and the fact that I'm a micropython noob!) are there explicit instructions anywhere on precisely how to "includ[e] uasyncio micropython module[s]" plus the required libraries?
                  I C 2 Replies Last reply Reply Quote 0
                  • I Offline
                    iwahdan @soulsurfer
                    @soulsurfer, using FTP or pymkr you can upload the uasyncio modules to your Pycom device with the following hierarchy :
                    • uasyncio sub-modules into /flash/lib/uasyncio
                    • websocket.server sub-module under: /flash/lib/uasyncio/websocket
                    • collections sub-modules into /flash/lib/collections
                    • logging sub-module into /flash/lib
                    And then you can import uasyncio library into your script and start using it
                    Wahdan
                    S S 2 Replies Last reply Reply Quote 1
                      Sympatron @iwahdan
                      @iwahdan I think it would be nice to have this as frozen modules by default in the future.
                        cmisztur @soulsurfer
                        @soulsurfer here, I documented the process https://medium.com/@chrismisztur/pycom-uasyncio-installation-94931fc71283
                        1 Reply Last reply Reply Quote 5
                          tuftec
                          It is good to see that RTC memory support has been added.
                          Is there a mechanism that can keep the RTC operational when the device is in deep sleep?
                          I need a way to maintain system time but require to deepsleep regularly to save power (battery operated).
                          My original solution for this was to implement a s/w RTC and to save its state every time I go into deepsleep. I would then use my knowledge of the time in deepsleep (set by the deepsleep timer) and measuring execution time of the start up code (using the chrono functions) to then update my s/w RTC upon waking.
                          Very messy but it sort of works. Not very accurate though.
                          If there was a way to keep the RTC running (power still applied) then I could hopefully have a much better solution. Using other ESP32 based devices running standard Micropyrhon, it would appear that the RTC function actually continues to operate during deepsleep.
                          Have I missed something???? Is there a suggested way to use the RTC when using deepsleep?
                          Peter.
                          J I 2 Replies Last reply Reply Quote 0
                            jcaron @tuftec
                            @tuftec you may want to let us know which hardware combination (module + board) and what deep sleep mode you are using.
                            If you are using one of the “older” boards (e.g LoPy, not LoPy 4) with a Pysense, Pytrack or the deep sleep shield, and the PIC-controlled deep sleep, then the ESP32 is indeed completely powered down during deep sleep.
                            If you are using one of the more recent boards (e.g LoPy) and machine.deepsleep, I believe the RTC keeps running during deep sleep.
                              soulsurfer @iwahdan
                              OK - Thanks @iwahdan.
                              • I Offline
                                iwahdan @tuftec
                                Hi @tuftec, well as @jcaron mentioned if you are using a Pycom device with Deepsleep shield you cannot keep track of time using RTC as the device is completely powered Off, however if you are using the newer boards that don't require the Deepsleep shield you can keep track of time using the RTC module in Micropython, you would set the time once using RTC.init() and the RTC would keep counting from that time even in deepsleep , you can check time after wakeup using RTC.now()
                                Wahdan
                                  soulsurfer
                                  Triple thanks @cmisztur!
                                    tuftec
                                    Sorry about the scant information.
                                    I am building custom hardware around the LoPy4 and FiPy devices.
                                    So, based on the post by @iwahdan , does this imply that the RTC should keep going in DeepSleep for both the LoPy4 and FiPy modules? This is contrary to information I was given some time ago.
                                    If the RTC keeps going that would be a big advantage for my application.
                                    Peter.
                                    • I Offline
                                      iwahdan @tuftec
                                      @tuftec , Also you have to take into consideration the fact that if board resets or power is lost the Time is rested to unix epoch , you can use RTC.ntp_sync() to Sync time using an NTP server in case of hard resets.
                                      Wahdan
                                      • rcolisteteR Offline
                                        rcolistete
                                        Any measure of time (in ms) to wake up from light sleep mode ?
                                        I'd like to know if a wake on pin (external signal) from light sleep mode would be fast enough for some signal frequencies : 10 Hz ? 50 Hz ? 100 Hz ? 1000 Hz ?
                                        rcolisteteR 1 Reply Last reply Reply Quote 0
                                          rcolistete @rcolistete
                                          Measured using only software : about 16 ms to wake up from light sleep. Both using wake on pin (interrupt) or timed light sleep.
                                          Need to confirm with external measurement : i(t) powering LoPy4 by using oscilloscope + shunt resistor.
                                            martijnthe
                                            @iwahdan or @Xykon what's the timeline for a non-beta release of v1.19.0?
                                            Mostly interested in LittleFS (for robustness and wear-levelling) and the newer micropython.
