    I2C LCD: code inside
    41 Posts 8 Posters 28.2k Views 8 Watching
      brotherdust
      It works! Yay! Code later. Sleep now.
      D R 2 Replies Last reply Reply Quote 0
        DVE @brotherdust
        @brotherdust Its great :)
        I ordered 128x64 display too on Ebay, will be able to test next week.
        @brotherdust said in I2C LCD: code inside:
        The driver was using I2C "primitives" that were disabled in the esp32 version of machine_i2c
        How it works? Do you need to reload a firmware with enabled primitives?
          rskoniec @brotherdust
          @brotherdust Any chance for a code and answers for @DVE questions?
            brotherdust @rskoniec
            @rskoniec said in I2C LCD: code inside:
            @rskoniec, my apologies. I thought that I had answered this and didn't give it any more thought.
            The commit I referenced enables the I2C primitives. You'll need to recompile the firmware and upload it. Then the code will work.
            After reviewing the code a bit more, I think it can be refactored not to use the primitives (I2C.start, stop, etc). The primitives are already a part of other, more high-level routines. But the easiest way to get the driver going was just to enable those functions. =) I'm too lazy to re-factor and go through all the pull requests and justifications to get it included upstream.
            R R 2 Replies Last reply Reply Quote 0
              @brotherdust Thank you very much for quick reply. :o)
                DVE
                Got the 128x64 display this week. Stupid chinese seller sent SPI version instead of I2C.
                But I was able to add SPI support as well :)
                alt text
                Will update code soon.
                R 1 Reply Last reply Reply Quote 2
                  rskoniec @DVE
                    Jiemde Pybytes Beta
                    Very interested by your code version, thanks in advance.
                      rskoniec
                      @DVE Me too. :o) Btw, which version of SPI do you use (3 or 4-wire)?
                        DVE
                        Hi all.
                        Now its a very slow software implementation. Its just a code and connection diagram, converted to Python from here:
                        http://www.instructables.com/id/How-to-use-OLED-display-arduino-module/step2/Copy-the-code-in-Arduino-IDE-and-change-the-chars-/
                        I'll share code soon, want to improve it a bit.
                          rdixey @brotherdust
                          @brotherdust Hey brother... I'm trying to use an Adafruit 128X64 OLED with both I2C & SPI, on the SPI bus of my LoPy. Working with the SSD1306 OLED driver, I quickly encountered the same problem as you, no framebuf module available on the LoPY.
                          I see in this thread that you were able to compile the framebuf module for the LoPy. Are you able to share that with me as a .py ? Or else give me some direction on how you accomplished that?
                          Thanks in advance.
                            brotherdust @rdixey
                            @rdixey said in I2C LCD: code inside:
                            Thanks in advance.
                            @rdixey :
                            The SSD1306 driver that comes with MicroPython references methods in the I2C class that aren't available by default in PyCom's ESP32 port. I applied the changes indicated in the commits from my git branch repo (links below) and recompiled the firmware. After that, I was able to use the driver just fine. I then combined the driver code with @DVE's font code and some other functions and it worked pretty well. I'd post the final script here, but I don't have access to it right now. Give my suggestions a shot first and see what you can come up with. =)
                            Enable framebuf
                            Enable I2C primitives
                              rdixey @brotherdust
                              @brotherdust I appreciate the straightforward answer. I'm thinking that by using SPI, I will avoid the I2C primitives issues that you encountered. And hopefully not run into other SPI related issues.
                              Since I've not ever recompiled the firmware before, this will be an adventure that should keep me occupied and out of trouble for a while.
                                brotherdust @rdixey
                                @rdixey :
                                Here's the code I've been using. It's meant as more of a stress test on the I2C bus and the LoPy itself (watchdog issues over time). It does the following:
                                Set up I2C bus at 400,000 bps
                                Initialize BME280 sensor on default I2C address
                                Initialize SSD1306 display on secondary I2C address 0x3D
                                While True:
                                • Read sensor data
                                • Blank the display buffer
                                • Write some text to the buffer
                                • Write the buffer to the display
                                • Sleep for 1ms
                                # MicroPython SSD1306 OLED driver, I2C and SPI interfaces
                                from micropython import const
                                import framebuf
                                # register definitions
                                SET_CONTRAST        = const(0x81)
                                SET_ENTIRE_ON       = const(0xa4)
                                SET_NORM_INV        = const(0xa6)
                                SET_DISP            = const(0xae)
                                SET_MEM_ADDR        = const(0x20)
                                SET_COL_ADDR        = const(0x21)
                                SET_PAGE_ADDR       = const(0x22)
                                SET_DISP_START_LINE = const(0x40)
                                SET_SEG_REMAP       = const(0xa0)
                                SET_MUX_RATIO       = const(0xa8)
                                SET_COM_OUT_DIR     = const(0xc0)
                                SET_DISP_OFFSET     = const(0xd3)
                                SET_COM_PIN_CFG     = const(0xda)
                                SET_DISP_CLK_DIV    = const(0xd5)
                                SET_PRECHARGE       = const(0xd9)
                                SET_VCOM_DESEL      = const(0xdb)
                                SET_CHARGE_PUMP     = const(0x8d)
                                class SSD1306:
                                    def __init__(self, width, height, external_vcc):
                                        self.width = width
                                        self.height = height
                                        self.external_vcc = external_vcc
                                        self.pages = self.height // 8
                                        self.buffer = bytearray(self.pages * self.width)
                                        self.framebuf = framebuf.FrameBuffer1(self.buffer, self.width, self.height)
                                        self.poweron()
                                        self.init_display()
                                    def init_display(self):
                                        for cmd in (
                                            SET_DISP | 0x00, # off
                                            # address setting
                                            SET_MEM_ADDR, 0x00, # horizontal
                                            # resolution and layout
                                            SET_DISP_START_LINE | 0x00,
                                            SET_SEG_REMAP | 0x01, # column addr 127 mapped to SEG0
                                            SET_MUX_RATIO, self.height - 1,
                                            SET_COM_OUT_DIR | 0x08, # scan from COM[N] to COM0
                                            SET_DISP_OFFSET, 0x00,
                                            SET_COM_PIN_CFG, 0x02 if self.height == 32 else 0x12,
                                            # timing and driving scheme
                                            SET_DISP_CLK_DIV, 0x80,
                                            SET_PRECHARGE, 0x22 if self.external_vcc else 0xf1,
                                            SET_VCOM_DESEL, 0x30, # 0.83*Vcc
                                            # display
                                            SET_CONTRAST, 0xff, # maximum
                                            SET_ENTIRE_ON, # output follows RAM contents
                                            SET_NORM_INV, # not inverted
                                            # charge pump
                                            SET_CHARGE_PUMP, 0x10 if self.external_vcc else 0x14,
                                            SET_DISP | 0x01): # on
                                            self.write_cmd(cmd)
                                        self.fill(0)
                                        self.show()
                                    def poweroff(self):
                                        self.write_cmd(SET_DISP | 0x00)
                                    def contrast(self, contrast):
                                        self.write_cmd(SET_CONTRAST)
                                        self.write_cmd(contrast)
                                    def invert(self, invert):
                                        self.write_cmd(SET_NORM_INV | (invert & 1))
                                    def show(self):
                                        x0 = 0
                                        x1 = self.width - 1
                                        if self.width == 64:
                                            # displays with width of 64 pixels are shifted by 32
                                            x0 += 32
                                            x1 += 32
                                        self.write_cmd(SET_COL_ADDR)
                                        self.write_cmd(x0)
                                        self.write_cmd(x1)
                                        self.write_cmd(SET_PAGE_ADDR)
                                        self.write_cmd(0)
                                        self.write_cmd(self.pages - 1)
                                        self.write_data(self.buffer)
                                    def fill(self, col):
                                        self.framebuf.fill(col)
                                    def pixel(self, x, y, col):
                                        self.framebuf.pixel(x, y, col)
                                    def scroll(self, dx, dy):
                                        self.framebuf.scroll(dx, dy)
                                    def text(self, string, x, y, col=1):
                                        self.framebuf.text(string, x, y, col)
                                class SSD1306_I2C(SSD1306):
                                    def __init__(self, width, height, i2c, addr=0x3c, external_vcc=False):
                                        self.i2c = i2c
                                        self.addr = addr
                                        self.temp = bytearray(2)
                                        super().__init__(width, height, external_vcc)
                                    def write_cmd(self, cmd):
                                        self.temp[0] = 0x80 # Co=1, D/C#=0
                                        self.temp[1] = cmd
                                        self.i2c.writeto(self.addr, self.temp)
                                    def write_data(self, buf):
                                        self.temp[0] = self.addr << 1
                                        self.temp[1] = 0x40 # Co=0, D/C#=1
                                        self.i2c.start()
                                        self.i2c.write(self.temp)
                                        self.i2c.write(buf)
                                        self.i2c.stop()
                                    def poweron(self):
                                        pass
                                class SSD1306_SPI(SSD1306):
                                    def __init__(self, width, height, spi, dc, res, cs, external_vcc=False):
                                        self.rate = 10 * 1024 * 1024
                                        dc.init(dc.OUT, value=0)
                                        res.init(res.OUT, value=0)
                                        cs.init(cs.OUT, value=1)
                                        self.spi = spi
                                        self.dc = dc
                                        self.res = res
                                        self.cs = cs
                                        self.spi.init(baudrate=self.rate, polarity=0, phase=0)
                                        self.cs.high()
                                        self.dc.low()
                                        self.cs.low()
                                        self.spi.write(bytearray([cmd]))
                                        self.cs.high()
                                        self.cs.high()
                                        self.dc.high()
                                        self.cs.low()
                                        self.spi.write(buf)
                                        self.cs.high()
                                    def poweron(self):
                                        self.res.high()
                                        time.sleep_ms(1)
                                        self.res.low()
                                        time.sleep_ms(10)
                                        self.res.high()
                                # Author: Paul Cunnane 2016
                                # This module borrows heavily from the Adafruit BME280 Python library
                                # and the Adafruit GPIO/I2C library. Original copyright notices are reproduced
                                # below.
                                # Those libraries were written for the Raspberry Pi. This modification is
                                # intended for the MicroPython and WiPy boards.
                                # Copyright (c) 2014 Adafruit Industries
                                # Author: Tony DiCola
                                # Based on the BMP280 driver with BME280 changes provided by
                                # David J Taylor, Edinburgh (www.satsignal.eu)
                                # Based on Adafruit_I2C.py created by Kevin Townsend.
                                # Permission is hereby granted, free of charge, to any person obtaining a copy
                                # of this software and associated documentation files (the "Software"), to deal
                                # in the Software without restriction, including without limitation the rights
                                # to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
                                # copies of the Software, and to permit persons to whom the Software is
                                # furnished to do so, subject to the following conditions:
                                # The above copyright notice and this permission notice shall be included in
                                # all copies or substantial portions of the Software.
                                # THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
                                # IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
                                # FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
                                # AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
                                # LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
                                # OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
                                # THE SOFTWARE.
                                # BME280 default address.
                                BME280_I2CADDR = 0x77
                                # Operating Modes
                                BME280_OSAMPLE_1 = 1
                                BME280_OSAMPLE_2 = 2
                                BME280_OSAMPLE_4 = 3
                                BME280_OSAMPLE_8 = 4
                                BME280_OSAMPLE_16 = 5
                                # BME280 Registers
                                BME280_REGISTER_DIG_T1 = 0x88  # Trimming parameter registers
                                BME280_REGISTER_DIG_T2 = 0x8A
                                BME280_REGISTER_DIG_T3 = 0x8C
                                BME280_REGISTER_DIG_P1 = 0x8E
                                BME280_REGISTER_DIG_P2 = 0x90
                                BME280_REGISTER_DIG_P3 = 0x92
                                BME280_REGISTER_DIG_P4 = 0x94
                                BME280_REGISTER_DIG_P5 = 0x96
                                BME280_REGISTER_DIG_P6 = 0x98
                                BME280_REGISTER_DIG_P7 = 0x9A
                                BME280_REGISTER_DIG_P8 = 0x9C
                                BME280_REGISTER_DIG_P9 = 0x9E
                                BME280_REGISTER_DIG_H1 = 0xA1
                                BME280_REGISTER_DIG_H2 = 0xE1
                                BME280_REGISTER_DIG_H3 = 0xE3
                                BME280_REGISTER_DIG_H4 = 0xE4
                                BME280_REGISTER_DIG_H5 = 0xE5
                                BME280_REGISTER_DIG_H6 = 0xE6
                                BME280_REGISTER_DIG_H7 = 0xE7
                                BME280_REGISTER_CHIPID = 0xD0
                                BME280_REGISTER_VERSION = 0xD1
                                BME280_REGISTER_SOFTRESET = 0xE0
                                BME280_REGISTER_CONTROL_HUM = 0xF2
                                BME280_REGISTER_CONTROL = 0xF4
                                BME280_REGISTER_CONFIG = 0xF5
                                BME280_REGISTER_PRESSURE_DATA = 0xF7
                                BME280_REGISTER_TEMP_DATA = 0xFA
                                BME280_REGISTER_HUMIDITY_DATA = 0xFD
                                class Device:
                                    """Class for communicating with an I2C device.
                                    Allows reading and writing 8-bit, 16-bit, and byte array values to
                                    registers on the device."""
                                    def __init__(self, address, i2c):
                                        """Create an instance of the I2C device at the specified address using
                                        the specified I2C interface object."""
                                        self._address = address
                                        self._i2c = i2c
                                    def writeRaw8(self, value):
                                        """Write an 8-bit value on the bus (without register)."""
                                        value = value & 0xFF
                                        self._i2c.writeto(self._address, value.to_bytes(1))
                                    def write8(self, register, value):
                                        """Write an 8-bit value to the specified register."""
                                        self._i2c.writeto_mem(self._address, register, value.to_bytes(1))
                                    def write16(self, register, value):
                                        """Write a 16-bit value to the specified register."""
                                        value = value & 0xFFFF
                                        self.i2c.writeto_mem(self._address, register, value)
                                    def readRaw8(self):
                                        """Read an 8-bit value on the bus (without register)."""
                                        return int.from_bytes(self._i2c.readfrom(self._address, 1)) & 0xFF
                                    def readU8(self, register):
                                        """Read an unsigned byte from the specified register."""
                                            self._i2c.readfrom_mem(self._address, register, 1)) & 0xFF
                                    def readS8(self, register):
                                        """Read a signed byte from the specified register."""
                                        result = self.readU8(register)
                                        if result > 127:
                                            result -= 256
                                        return result
                                    def readU16(self, register, little_endian=True):
                                        """Read an unsigned 16-bit value from the specified register, with the
                                        specified endianness (default little endian, or least significant byte
                                        first)."""
                                        result = int.from_bytes(
                                            self._i2c.readfrom_mem(self._address, register, 2)) & 0xFFFF
                                        if not little_endian:
                                            result = ((result << 8) & 0xFF00) + (result >> 8)
                                        return result
                                    def readS16(self, register, little_endian=True):
                                        """Read a signed 16-bit value from the specified register, with the
                                        first)."""
                                        result = self.readU16(register, little_endian)
                                        if result > 32767:
                                            result -= 65536
                                        return result
                                    def readU16LE(self, register):
                                        """Read an unsigned 16-bit value from the specified register, in little
                                        endian byte order."""
                                        return self.readU16(register, little_endian=True)
                                    def readU16BE(self, register):
                                        """Read an unsigned 16-bit value from the specified register, in big
                                        return self.readU16(register, little_endian=False)
                                    def readS16LE(self, register):
                                        """Read a signed 16-bit value from the specified register, in little
                                        return self.readS16(register, little_endian=True)
                                    def readS16BE(self, register):
                                        """Read a signed 16-bit value from the specified register, in big
                                        return self.readS16(register, little_endian=False)
                                class BME280:
                                    def __init__(self, mode=BME280_OSAMPLE_1, address=BME280_I2CADDR, i2c=None,
                                                 **kwargs):
                                        # Check that mode is valid.
                                        if mode not in [BME280_OSAMPLE_1, BME280_OSAMPLE_2, BME280_OSAMPLE_4,
                                                        BME280_OSAMPLE_8, BME280_OSAMPLE_16]:
                                            raise ValueError(
                                                'Unexpected mode value {0}. Set mode to one of '
                                                'BME280_ULTRALOWPOWER, BME280_STANDARD, BME280_HIGHRES, or '
                                                'BME280_ULTRAHIGHRES'.format(mode))
                                        self._mode = mode
                                        # Create I2C device.
                                        if i2c is None:
                                            raise ValueError('An I2C object is required.')
                                        self._device = Device(address, i2c)
                                        # Load calibration values.
                                        self._load_calibration()
                                        self._device.write8(BME280_REGISTER_CONTROL, 0x3F)
                                        self.t_fine = 0
                                    def _load_calibration(self):
                                        self.dig_T1 = self._device.readU16LE(BME280_REGISTER_DIG_T1)
                                        self.dig_T2 = self._device.readS16LE(BME280_REGISTER_DIG_T2)
                                        self.dig_T3 = self._device.readS16LE(BME280_REGISTER_DIG_T3)
                                        self.dig_P1 = self._device.readU16LE(BME280_REGISTER_DIG_P1)
                                        self.dig_P2 = self._device.readS16LE(BME280_REGISTER_DIG_P2)
                                        self.dig_P3 = self._device.readS16LE(BME280_REGISTER_DIG_P3)
                                        self.dig_P4 = self._device.readS16LE(BME280_REGISTER_DIG_P4)
                                        self.dig_P5 = self._device.readS16LE(BME280_REGISTER_DIG_P5)
                                        self.dig_P6 = self._device.readS16LE(BME280_REGISTER_DIG_P6)
                                        self.dig_P7 = self._device.readS16LE(BME280_REGISTER_DIG_P7)
                                        self.dig_P8 = self._device.readS16LE(BME280_REGISTER_DIG_P8)
                                        self.dig_P9 = self._device.readS16LE(BME280_REGISTER_DIG_P9)
                                        self.dig_H1 = self._device.readU8(BME280_REGISTER_DIG_H1)
                                        self.dig_H2 = self._device.readS16LE(BME280_REGISTER_DIG_H2)
                                        self.dig_H3 = self._device.readU8(BME280_REGISTER_DIG_H3)
                                        self.dig_H6 = self._device.readS8(BME280_REGISTER_DIG_H7)
                                        h4 = self._device.readS8(BME280_REGISTER_DIG_H4)
                                        h4 = (h4 << 24) >> 20
                                        self.dig_H4 = h4 | (self._device.readU8(BME280_REGISTER_DIG_H5) & 0x0F)
                                        h5 = self._device.readS8(BME280_REGISTER_DIG_H6)
                                        h5 = (h5 << 24) >> 20
                                        self.dig_H5 = h5 | (
                                            self._device.readU8(BME280_REGISTER_DIG_H5) >> 4 & 0x0F)
                                    def read_raw_temp(self):
                                        """Reads the raw (uncompensated) temperature from the sensor."""
                                        meas = self._mode
                                        self._device.write8(BME280_REGISTER_CONTROL_HUM, meas)
                                        meas = self._mode << 5 | self._mode << 2 | 1
                                        self._device.write8(BME280_REGISTER_CONTROL, meas)
                                        sleep_time = 1250 + 2300 * (1 << self._mode)
                                        sleep_time = sleep_time + 2300 * (1 << self._mode) + 575
                                        time.sleep_us(sleep_time)  # Wait the required time
                                        msb = self._device.readU8(BME280_REGISTER_TEMP_DATA)
                                        lsb = self._device.readU8(BME280_REGISTER_TEMP_DATA + 1)
                                        xlsb = self._device.readU8(BME280_REGISTER_TEMP_DATA + 2)
                                        raw = ((msb << 16) | (lsb << 8) | xlsb) >> 4
                                        return raw
                                    def read_raw_pressure(self):
                                        """Reads the raw (uncompensated) pressure level from the sensor."""
                                        """Assumes that the temperature has already been read """
                                        """i.e. that enough delay has been provided"""
                                        msb = self._device.readU8(BME280_REGISTER_PRESSURE_DATA)
                                        lsb = self._device.readU8(BME280_REGISTER_PRESSURE_DATA + 1)
                                        xlsb = self._device.readU8(BME280_REGISTER_PRESSURE_DATA + 2)
                                        return raw
                                    def read_raw_humidity(self):
                                        msb = self._device.readU8(BME280_REGISTER_HUMIDITY_DATA)
                                        lsb = self._device.readU8(BME280_REGISTER_HUMIDITY_DATA + 1)
                                        raw = (msb << 8) | lsb
                                        return raw
                                    def read_temperature(self):
                                        """Get the compensated temperature in 0.01 of a degree celsius."""
                                        adc = self.read_raw_temp()
                                        var1 = ((adc >> 3) - (self.dig_T1 << 1)) * (self.dig_T2 >> 11)
                                        var2 = ((
                                            (((adc >> 4) - self.dig_T1) * ((adc >> 4) - self.dig_T1)) >> 12) *
                                            self.dig_T3) >> 14
                                        self.t_fine = var1 + var2
                                        return (self.t_fine * 5 + 128) >> 8
                                    def read_pressure(self):
                                        """Gets the compensated pressure in Pascals."""
                                        adc = self.read_raw_pressure()
                                        var1 = self.t_fine - 128000
                                        var2 = var1 * var1 * self.dig_P6
                                        var2 = var2 + ((var1 * self.dig_P5) << 17)
                                        var2 = var2 + (self.dig_P4 << 35)
                                        var1 = (((var1 * var1 * self.dig_P3) >> 8) +
                                                ((var1 * self.dig_P2) >> 12))
                                        var1 = (((1 << 47) + var1) * self.dig_P1) >> 33
                                        if var1 == 0:
                                            return 0
                                        p = 1048576 - adc
                                        p = (((p << 31) - var2) * 3125) // var1
                                        var1 = (self.dig_P9 * (p >> 13) * (p >> 13)) >> 25
                                        var2 = (self.dig_P8 * p) >> 19
                                        return ((p + var1 + var2) >> 8) + (self.dig_P7 << 4)
                                    def read_humidity(self):
                                        adc = self.read_raw_humidity()
                                        # print 'Raw humidity = {0:d}'.format (adc)
                                        h = self.t_fine - 76800
                                        h = (((((adc << 14) - (self.dig_H4 << 20) - (self.dig_H5 * h)) +
                                             16384) >> 15) * (((((((h * self.dig_H6) >> 10) * (((h *
                                                              self.dig_H3) >> 11) + 32768)) >> 10) + 2097152) *
                                                              self.dig_H2 + 8192) >> 14))
                                        h = h - (((((h >> 15) * (h >> 15)) >> 7) * self.dig_H1) >> 4)
                                        h = 0 if h < 0 else h
                                        h = 419430400 if h > 419430400 else h
                                        return h >> 12
                                    @property
                                    def temperature(self):
                                        "Return the temperature in degrees."
                                        t = self.read_temperature()
                                        ti = t // 100
                                        td = t - ti * 100
                                        return "{}.{:02d}C".format(ti, td)
                                    @property
                                    def pressure(self):
                                        "Return the temperature in hPa."
                                        p = self.read_pressure() // 256
                                        pi = p // 100
                                        pd = p - pi * 100
                                        return "{}.{:02d}hPa".format(pi, pd)
                                    @property
                                    def humidity(self):
                                        "Return the humidity in percent."
                                        h = self.read_humidity()
                                        hi = h // 1024
                                        hd = h * 100 // 1024 - hi * 100
                                        return "{}.{:02d}%".format(hi, hd)
                                from machine import I2C
                                i2c = I2C(0, I2C.MASTER, baudrate=400000)
                                sensor = BME280(address=119, i2c=i2c)
                                display = SSD1306_I2C(width=128, height=64, i2c=i2c, addr=0x3d)
                                	temperature = "T: {}".format(sensor.temperature)
                                	humidity = "H: {}".format(sensor.humidity)
                                	pressure = "P: {}".format(sensor.pressure)
                                	display.fill(0)
                                	display.text(temperature, 0, 0)
                                	display.text(humidity, 0, 28)
                                	display.text(pressure, 0, 56)
                                	display.show()
                                	time.sleep_ms(1)
                                I left it running for a couple of days and it's proven pretty stable. One thing to note is that the SSD1306 (at least mine) requires additional initialization before it will start working. It took me a while to puzzle it out! What happens on startup is the display will show the contents of the memory buffer. If it's unpowered for more than a few seconds, it just looks like static. Setting the RESET pin to LOW clears this and makes the display ready.
                                I'm curious to know why you selected SPI over I2C. I haven't had a chance to play with SPI yet because all my stuff supports I2C and it's sufficient for my purposes. What are your thoughts @rdixey ?
                                  DVE
                                  2 All:
                                  Hardware SPI support was added to the library. Now the library should support SPI/IIC displays as well.
                                  Sources address is the same: https://github.com/dmitryelj/LoPyI2CLCD
                                    rdixey @brotherdust
                                    @brotherdust Hey Brother...I appreciate you sharing your Python code and the advice on recompiling the microcode to add framebuf. Have not had a chance to try it yet since I am still trying to understand how to recompile the microcode. Once I've done that I'll let you know how this worked out for me. BTW - chose to use SPI for this display as a way to learn SPI. Could not get SPI to work on my Gumstix Overo running OMAP Linux / Yocto. Thought it might be easier to learn on the LoPy.
                                      rdixey @DVE
                                      @DVE Hey Dmitrii ...... I see your 128X64 OLED has a SPI CS Pin but when I look at your code it appears that you do not connect it to a GPIO Pin. The Adafruit ssd1306 lib sequences the OLED CS signal high to low to do write operations. How did you eliminate having to do that with your configuration? I ask because I have tried your code using your default pin config (no connection to OLED CS) but it will not turn on for me. On my OLED pcb the CS pin is high (3.3V) by default, did you pull it low all the time on your OLED pcb?
                                        rdixey @rdixey
                                        @rdixey Dmitri.....I went ahead and tied my 128X64 OLED CS Pin to ground, and now the code you provided is working for me as SPI Master. I'm now able to write text to the display. Nice Job :) Many Thanks!
                                          DVE
                                          Cool :) I didn't connect CS pin at all, maybe ground is really better.
                                            leelive
                                            I tried this code on the i2c 128x64 version of this oled. All the characters are missing the top and bottom pixels. They're the correct characters, but are clipped. Example: The capital 'L' in LoPy is just 3 vertical pixels, and the lower case 'o' is just 2 vertical pixels on for each side. Been messing with it all day and haven't found an obvious problem in the code. I don't have another display to try, but don't think the displays the problem. Any ideas?
                                            • 2 / 3
