    Exp Board 2.0 serial communication problem
    expansion boardcom portftdi
    45 Posts 3 Posters 8.8k Views 3 Watching
      szyba91
      Correction:
      Now I've noticed that one of the boards is v3.0 my mistake. They are very similar. Its because I've ordered 2.0V and I've got 3.0V
        szyba91 @robert-hh
        @robert-hh Now I'm able to update FiPy using 2.0 board- i forgot to unplug the usb cable after bridging P23 and GND.
        But I'm still stuck during serial port connection in VS Code
          robert-hh @szyba91
          @szyba91 Instead of re-plugging the USB cable, you can also push the reset button on the FiPy.
          About VS-Code: Windows sometimes re-assigns the COM ports. Please check in the device manager the number of the COM port. But .... using the wrong port you would not have been able to update the FiPy.
            szyba91 @robert-hh
            @robert-hh Exactlly, especially that I have the same issue alike Windows and Linux - the same.
            One more think that can be usefull, I can upload the project, I can see result of my code using 2.0V board but i can reach the terminal commands.
            Updating - works
            Uploading - works
            Operating system - recognize in both
            Run button /(>>>) - only with 3.0V
            2.0V worked just 2 days ago.
            -strange
              robert-hh @szyba91
              @szyba91 Dou you see the REPL prompt with simple terminal emulators like Putty on Windows or screen or picocom on Linux?
              With Putty, set the flow control to None.
                szyba91 @robert-hh
                @robert-hh I've check this and using 3.0V i can see REPL but with 2.0V - not. I've set boud rate 115200 in both chases.
                  robert-hh @szyba91
                  @szyba91 That's strange, especially since you can still update devices using that board.
                  S 2 Replies Last reply Reply Quote 0
                    szyba91 @robert-hh
                    @robert-hh Maybe I should contact with PyCom field support service ?
                      robert-hh @szyba91
                      @szyba91 You may do so. But since you can still use the boad for upload, it is hardly an electronic problem. And I understand, that the same FiPy works with expansion board V3. Just to ask a silly questions: did you remove the GND/P23 jumper after upload?
                        szyba91 @robert-hh
                        @robert-hh Yes, the both FiPys its self works with V3 board and sure - i removed jumper after updating
                        • danD Offline
                          dan
                          Hi @szyba91,
                          Just to confirming, when you switch between the expansion boards, you change the address in VSCode, right? (you can check it in the pymakr.conf file or the plugin settings. All commands -> 'Pymakr > Project | Global Settings')
                          Can you share your VSCode's and Pymakr plugin's version number?
                            szyba91 @dan
                            @dan Yes, I've been changing serial port numbers.
                            I have:
                            FiPys firmware version1.18.0.r1
                            Visual Studio version 1.25.1
                            Atom version: 1.29.0
                            Pymakrs version 1.0.1
                            Jumpers : RTS and CTS are removed, rest of them is on its place
                            Windows 10 64bit
                            The same on
                            Ubuntu 16.04 LTS
                              szyba91 @robert-hh
                              @robert-hh Update : I've noticed something. When i was trying to upload this code
                              https://github.com/pycom/pycom-libraries/blob/master/examples/lopy-lopy/lopy-A/main.py
                              Just near to end I've got the masseage form terminal something like this :" Pybytes library: v0.9.0" and that it stacks. And after it I can't reach the COM anyway.
                              What is interesting - I've lost connection with v3 now, then I've try with v2 (i was sure that it also be unreachable beacuse I had a problem with it before) Just imagine how supprised I was when I saw REPL on this board!
                              Again - I trid to upload the same code on this board, and unfortunately after makaing the same it also stacks.
                              I'm very confused now. Does anyone knows what is happning with this modules?
                                robert-hh @szyba91
                                @szyba91 Sorry I cannot tell you anything about working with VSC /Atom pymakr plugins or pybytes. I do not use these "tools". For uploading and file management on the devices I use ftp. The expansion boards, epscially V2.0, are dead simple devices. They should always work.
                                  szyba91
                                  Update : I just connect exp boards without FiPys. I was courious what will happend when i bridge TX i RX(physical pins 40 and 41) pin on board (should be an echo right?) and i've got echo. So boards it self works.
                                  Now i'm connect the fipy via USB-UART concerter and I can't reach the REPL on both FiPys :( :(
                                  robert-hhR S 2 Replies Last reply Reply Quote 0
                                    robert-hh @szyba91
                                    @szyba91 The USB/UART bridge must be set to 3.3 V output. And sometimes TX/RX has to be swapped. Please not also that the typcial USB/UART switch cannot supply a FiPy. The simply deliver not enough power.
                                      szyba91 @szyba91
                                      @szyba91 Now i've connected the fipy and exp board together and there is no REPL but when i push Reset rutton i'm having this:
                                      rst:0x1 (POWERON_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
                                      configsip: 0, SPIWP:0xee
                                      mode:DIO, clock div:1
                                      load:0x3fff8028,len:8
                                      load:0x3fff8030,len:1728
                                      load:0x4009fa00,len:0
                                      load:0x4009fa00,len:14584
                                      entry 0x400a059c
                                      And it stucks and this command during code uploding. I'm using PuTTY
                                        robert-hh @szyba91
                                        @szyba91 In putty, you have to disable flow control. It is in the Serial/conection tab.
                                          szyba91 @robert-hh
                                          @robert-hh No change after disable flow control. Maybe I have to wait longer to see >>> because it doesn't stuck?
                                            robert-hh @szyba91
                                            @szyba91 No, the prompt should show up immediately. If you do not care what's in the flashof the device, try installing the standard firmware again (stable, no pybytes) with the option to erase the flash first, at least to erase the filesystem.
                                            • 1 / 3
