    LoPy as LoRaWAN Basestation?
    57 Posts 14 Posters 38.2k Views 18 Watching
      remcohn
      *) it will not be able to function as a gateway for TheThingsNetwork
      *) you need a fair amount of software to handle the tasks that TTN normally does for you (OTAA registration etc)
      *) it will be able to handle less nodes as it only has 1 frequency instead of 8
      and may be some other things i missed :)
        beyonlo @remcohn
        @remcohn said in LoPy as LoRaWAN Basestation?:
        But my main reason to get the LoPy is just to be a gateway - a gateway for TheThingsNetwork. Apart client mode, my intention with LoPy is a full LoRa gateway. I would like to construct a large, very large LoRa network to offer the LoRa network service for all, in many cities and states, and after in all the country. I'm so sad. :(
        alt text
        And what if you could build your own LoRa network?
        Here is the clever part, you can use the module to switch a comms signal from WiFi to LoRa (and vice versa) thus making the LoPy both a LoRa Receiver / Transmitter and a Nano gateway capable of handling comms with up to 100 other LoRa nodes!
        • K Offline
          KDHeard @daniel
          @daniel said in LoPy as LoRaWAN Basestation?:
          We first want to sort out all the issues around basic LoRaWAN and the firmware updates
          Hey Daniel - could you share the timeline for when the API will be ready for the nano-gateway?
          Kind regards
          Kevin
          Kind regards
          Kevin Heard - Founder
          DLI Systems
          www.dli.systems| Do - Learn - Improve
            bioagbob
            @daniel Same question here. What's the time frame for nano-gateway documentation?
            Roberto posted some demo code, but that's far from complete. Does Pycom plan to support the 100-node, 22km nano gateway featured in the KS?
              beyonlo @bioagbob
              @bioagbob said in LoPy as LoRaWAN Basestation?:
              I'm insterest too to do a very large network using LoRa (in this case LoPy), as gateway and client. So, I need to know if LoPy can be works as a complete LoRa gateway for others LoPy (as clients) and if are there some restriction. And, how many LoPy clients one LoPy gateway support.
              Thanks.
              bmarkusB B 2 Replies Last reply Reply Quote 0
              • bmarkusB Offline
                bmarkus @beyonlo
                @beyonlo said in LoPy as LoRaWAN Basestation?:
                Thanks.
                If you want to deploy a very large LoRa network, use LoRaWAN compatible gateways equipped with SX130x chips. You can get an indoor GW for cca. 200 EUR. LoPy is not soutable for LoRaWAN compatible GW.
                Also for end devices LoPy in its current state doesn't work. Use a proven, certified module using e.g. RN2483 or similar.
                Actually LoPy is not a matured solution. Hope it will be but it will take 6 mionths or so if ever will get documentation and a working LoRaWAN stack as I see.
                B J 2 Replies Last reply Reply Quote 0
                  borjam @beyonlo
                  The problem is: LoRaWAN uses several channels and different coding rates which, crudely said, trade speed for range.
                  LoRaWAN nodes, when transmitting, must chose a channel at random (there are several of them). This makes it easier for different users to share the spectrum.
                  So, in order to build a real LoRaWAN gateway you need a receiver capable of listening to several channels simultaneously and decoding several coding schemes rather than being fixed on one.
                  The LoRa subsystem you need to to this is far more complex than the "node" oriented chip present in the LoPy (and other LoRa devices) which is configured for one channel and one coding rate. That's the reason why LoRaWAN gateways are much more expensive than end nodes with an average price of around 500 euro.
                  That said, you can still do LoRa, which means using the interesting transmission methods employed in LoRaWAN, but just not the whole protocol stack.
                  The number of devices you can support will depend on how often your nodes communicate with the nano gateway, how much data they send of course, and your coding rate which will depend on your intended range.
                  bmarkusB B 2 Replies Last reply Reply Quote 1
                  • bmarkusB Offline
                    bmarkus @borjam
                    @borjam said in LoPy as LoRaWAN Basestation?:
                    A TELCO grade outdoor GW is costing cca. 1,000 EUR. Good news is that cheap professional indoor gateways are coming to the market in 2017Q1 thanks to the new Semtech SX1308 chip, you can expect them around 250-300 EUR.
                    Another solution to get a LoRaWAN concentrator board e.g. from IMST for cca. 150 EUR and connect it to a Raspberry Pi. It is just a board, so I would wait for the new indoor generation.
                      Dear all,
                      I am not able to offer a time frame for the LoRaWAN nano-gateway example and the documentation, as we are still working on the implementation. The example Roberto posted is for a raw LoRa nano-gateway.
                      The way the LoRaWAN nano-gateway works requires the node to only transmit on one channel, for this the LoRa stack needs to be modified a bit to make the 3 default channels the same and remove the rest. There's going to be a third mode on the LoRa class called NANO_GW. At first only joining via ABP will be supported on the nano-gateway so there will be a method to add the node and its keys.
                      bmarkusB J 3 Replies Last reply Reply Quote 0
                      • bmarkusB Offline
                        bmarkus @daniel
                        Dear all,
                        Daniel,
                        that's fine. But please, do not call it LoRaWAN gateway to avoid misunderstandings, there are too much already. It will not compatible with standard LoRaWAN devices (nodes).
                        Béla
                        • bmarkusB Offline
                          bmarkus @daniel
                          Daniel, can you make a clarification what is the functionality of the nano gateway?
                          In the LoRaWAN terminology a gateway is a device which forwards packets received by the radio board and sends them to a network server without evaluating them, just checking sync byte, 0x34 for public networks and CRC and transmitting packets from the network server to the air. By default a GW is is using the Semtech Packet Forwarder UDP protocol to communicate to network server.
                          ABP has nothing to do with GW, it is a higher network server layer. When you say nano gateway, it is a gateway which can be connected to a network server of a service provider like Loriot or TTN or/and it has a built in network server?
                            I just called it that way here to explain the difference with the raw-LoRa one. During the KS campaign we said it was not going to be LoRaWAN compatible and we made it clear that it was going to have the single channel limitation.
                              @bmarkus
                              Yes, that's how it will work. With ABP I meant that we won't be supporting OTAA joins (this involved replying with the join accept and handling the proper timing). Sorry for the confusion.
                              As a first stage it will just be an UDP packet forwarder, but the ultimate goal is to provide a small built-in network server as well in order to connect to TTN.
                                beyonlo @bmarkus
                                @bmarkus said in LoPy as LoRaWAN Basestation?:
                                Thanks.
                                All right. Now I understand that LoPy is not possible to works as LoRaWAN GW. It is a chip limitation.
                                What means indoor GW, what is difference to the outdoor GW? Why I can't to use a indoor GW as outdoor GW? Just because the indoor is not rain proof, or what?
                                I like so much of LoPy as device because I can write software in Python.
                                But what is the problem with LoPy as device? The chip is not capable (there are limitations) to be a real LoRaWAN device, like as GW? Or the chip is fine to works as a real/compatible LoRaWAN device, but just software/firmware from Daniel is still missing features?
                                Thank you.
                                  beyonlo @borjam
                                  All right, I will need a real LoRaWAN gateway, that LoPy can't to do that because the chip limitation.
                                  1. So, my idea for now is to use LoPy as gateway just for other LoPy devices. And when I have many LoPy devices that LoPy not support more, I will to buy one real LoRaWAN gateway and change all LoPy devices to connect to the new 200/500 euro LoRaWAN gateway. That's is fine?
                                  2. But for start in this way, I still would like to know how many LoPy devices can one LoPy (as gateway) to support?
                                    Project 1: The idea is that each LoPy device send 100KB each 5-10 minutes.
                                    Project 2: The idea is that each LoPy device send ~20bytes each second.
                                    Project 3: The idea is that each LoPy device send 100KB each day.
                                  Thank you.
                                  • bmarkusB Offline
                                    bmarkus @beyonlo
                                    1. But for start in this way, I still would like to know how many LoPy devices can one LoPy (as gateway) to support?
                                    Thank you.
                                    No way.
                                    Project 1: It is not for LoRaWAN even not for an 8-channel professional GW. LoRaWAN is not for 100KB data transmission, it is for sensor network sending low volume data in most cases in one direction w/o confirmation much less frequently..
                                    Propject 2: Channel usage, transmit duty cycle is limited to 1.0/0.1% depending on channel.
                                    I kindly advice to read basic documents and FAQ on LoRaWAN and redesign your projects. You need something else than LoRaWAN. It is not about LoPy.
                                      beyonlo @bmarkus
                                      Thank you.
                                      No way.
                                      Hello.
                                      Sorry for my ignorance, but yes, I already read about the Technology (data rate specifically), from here https://www.lora-alliance.org/what-is-lora/technology and say : "LoRaWAN data rates range from 0.3 kbps to 50 kbps. "
                                      Yes, I know that 50 kbps is a theory and/or with a perfect environment. But if I have just ~5kbps, is fine for Project1, Project2 and Project3, see?
                                      Thank you.
                                      • bmarkusB Offline
                                        bmarkus @beyonlo
                                        Thank you.
                                        No way.
                                        Hello.
                                        Thank you.
                                        GW's support SF7-SF12 which means cca. 5kbps max. But do not design for SF7. Really, what you want is not a LoRaWAN use case. I can't tell you more.
                                          beyonlo @bmarkus
                                          Thank you.
                                          No way.
                                          Hello.
                                          Thank you.
                                          All right. So, please, going to the point: "how many LoPy devices can one LoPy (as gateway) to support?"
                                          A real and valid scenario (project): send 100 bytes each 10 minutes.
                                          Thank you.
                                            beyonlo @beyonlo
                                            Thank you.
                                            No way.
                                            Hello.
                                            Thank you.
                                            Thank you.
                                            From: https://www.thethingsnetwork.org/forum/t/limitations-data-rate-packet-size-30-seconds-uplink-and-10-messages-downlink-per-day-fair-access-policy/1300
                                            Fair Access Policy: Practice
                                            • Golden rule: 30 seconds air-time per device per day
                                            • For 10 bytes of payload, this translates in (approx.):
                                              20 messages per day at SF12
                                              500 messages per day at SF7
                                              more for SF7BW250 and FSK (local-area)
                                            • If your application requires more bandwidth, think of another solution
                                            • This allows for >1000 nodes per gateway
                                            • Downlink bandwidth is even more restricted
                                              you can’t send all messages as ‘confirmed uplink
                                            • 2 / 3
